Question about Hotpoint WMA76 Front Load Washer
No power When switched on there is no power. Red light doesn't come on. Plug and fuse ok.
  • 3 Answers
Have you check the continuity in the main swich...????
Check it out...!
Posted on Jul 31, 2008
When I press power it will not turn on there is no red light it will simply not turn on
hi so the tv is totally dead, if so check the power switch if has one you may have knocked it off, if ok check the fuse in the plug if ok the fuse inside could have blown thanks
shaun
Jun 26, 2017 | Televison & Video
No dry heat
Sounds like ur heating element has blown but because u also say light doesn't work check 4 power at plug or wall socket if this ok then check ur fuses in plug and fuse box on the wall if all ok then un screw bulb and replace like 4 like also same applys 4 the heating element hope this helps u
Sep 03, 2012 | KitchenAid 24 in. KUDM01TJ - Multiple...
I HAVE A 50 INCH PLASMA TV THAT WAS GIVEN TO ME WITH NO POWER PLUG OR REMOTE . I WENT AND BOUGHT A POWER PLUG ,PLUG IT IN AND NOTHING HAPPENED . DO I NEED THE REMOTE TO OPERATE THE TV ON AND OFF/
Hi
If the set doesn't power ON, what is the use with a remote control? If it power ON properly, the power indicator light at its front panel will light up. Look for this. If it doesn't, make sure that you have got a set which has to be repaired. If it does power up, just get a remote control to operate it. OK.
Jul 11, 2011 | Hitachi P50H401 50 in. Plasma HDTV
Brand new Whynter ARC 12 SD, just plugged in and red warning light about power button is blinking. Booklet says the light will blink when water reservoir needs to be emptied. But, it's brand new, no...
Check the positioning of the water bucket It may be slightly out of place and is not triggering the switch. If that doesn't solve the problem. Turn the Master ON/OFF Switch to OFF, unplug the unit for 12 - 15 minutes. Then plug it back in and turn the Master Switch ON/OFF Switch to ON. Set the controls and it may have reset itself.
If none of the above soled the problem contact the manufacture's Customer Support or Tech Service Dept.
Hope this helped you to solve the problem. Please let me know. Thanks.
May 05, 2011 | Whynter Portable Air Conditioner
Tv will not power on!!!
most likely will need a new power supply, google it
Jan 01, 2010 | LG 32LG30 32 in. LCD HDTV
Brake lights not working even though the brake peddle is pushed down The switch still goes in and out. Fuse box has some fuses missing. The fuse box does not have a desription on every plug of what it is...
Here are the numbers on your fuseblock and fuses coresponding to the number that is on your fuse block.
1-20 amp (yellow)
Hazard flasher
2-10 amp (red)
back up lights, A/C clutch cycling Switch
3-30 amp (green)
Power windows
4-30 amp (yellow)
A/C or heater blower motor
5-20 amp (yellow)
Panel Lights, Side marker lights, Park, Taillights, Clock & radio display Intensity, License & panel lights.
#6-10 amp (red)
Stoplight, buzzers, Anti-lock brake module
#7-15 amp (lt. Blue)
Tachometer, horn & Relay
#8-8 amp (yellow)
Power Door locks
#9-10 amp (red)
Radio
#10-10 amp (red)
Rear Wheel Anti-lock module, Turn Signals
#11-20 amp (Yellow)
Windshield wiper & washers
#12-15 amp ( LT. Blue)
Cigarette Lighter
#13-5 amp (tan)
Speed Control, warning buzzers, gauges, indicator lights
#14-5 amp (tan)
Time/delay relay & under-hood light, dome light, power mirrors, readio & clock Memory, Interior lights, reading lights
#15-blank
Not used
#16-4 amp (pink)
Radio Lights & overdrive switch light 1989-91, Cluster lights, Cigarette Lighter light & as tray light, Cluster lights, A/C & heater controls.
#17-relay
Hazard Flasher warning
#18-relay
Relay
#19-Circuit breaker
#20-relay
Turn signal Flasher
#21-buzzer
Warning
#22-Relay
Horn
Aug 04, 2009 | 1991 Dodge Dakota
Onkyo tx-ds676 dead no power up
power down the amp totally to reset processor, then try again. If still no go, may have blown internal fuses- replace and try again
.... or failed thermal fuse in mains transformer. this is a workshop repair as it involves mains voltage that can kill :)
Nov 24, 2007 | Onkyo TX-DS676 Receiver
Not switching on...
Ok, so you get the light but no power.  Try re-seating the ribbon cable to and from the power switch and on the mother board.  If you had the box open it may have been pulled loose.  If this does not work then it may be a bad switch or ribbon.  I do not think it is a fuse or the board since you are getting the red light.  You would normlly not get this if that was the case.
Oct 22, 2007 | Sony PlayStation 2 (PS2) Console
Panasonic TX14S2T
What are the symptoms? Is the set dead? Please clarify
model number from back of set...The red power light coming on means the AC fuse is OK, but the B+ fuse may be bad. If that
is true,check the horiz o/p xistor and get back to me....T.
Oct 20, 2007 | Panasonic CT-27G14 27" TV
Hotpoint WMA76 Front Load Washer Logo
41 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
