Question about Canon PIXMA iP4000 InkJet Photo Printer
Error my printer says.. The waste ink absorber is full. Contact the service center for the replacement of the waste ink absorber. what will i do..? our printer has no service administrator...
Service mode reset - but beware resetting the counter without replacing the waste ink absorber may cause ink to overflow out of the printer.
1) With the printer power turned off, while pressing the Resume/Cancel button,
press and hold the Power button. (DO NOT release the buttons.
The LED lights in green to indicate that a function is selectable.) .
2) While holding the Power button, release the Resume/Cancel button. (DO NOT
release the Power button.) .
3) While holding the Power button, press the Resume/Cancel button 2 times, and
then release both the Power and Resume/Cancel buttons.
(Each time the Resume/Cancel button is pressed, the LED lights alternately in
orange and green, starting with orange.) .
4) When the LED lights in green, press the Resume/Cancel button 4 times. (Each
alternately in orange and green, starting with orange.) .
5) Press the Power button. The LED lights in green, and the reset is performed.
(When the operation completes, the printer returns to the
menu selection mode automatically.) .
6) Press the power button to exit service mode.
Note:- if you accidentally press the Resume/Cancel button more than 4 times in
step 4 then just press the Resume/Cancel button at least 10
times and the printer will be returned to step 4 automatically.
BTW the other functions that are available at step 4 are -
press 0 times = power off
press 1 time = Service Test Print
press 2 times = EEPROM information print
press 3 times = EEPROM initialisation
press 5 times = Destination settings (country information, do not play with
this)
press 6 times = Printhead Deep Cleaning
press 7,8 or 9 times = not used in servicing so do not play with these.
press 10 times or more = return to menu (step 4)
Posted on Oct 11, 2008
Ink absober is full
Eight flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber for the ink used during Print Head cleaning. Eight flashes indicates that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink absorber becomes completely full, contact a Canon service representative.
Important
Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing will no longer be possible
Jan 11, 2011 | Casio Office Equipment & Supplies
Computer says"Waste ink absorber is
What is the make and model of your printer (I'm guessing it is a Canon?)
May 06, 2008 | Office Equipment & Supplies
What is e 27 and e 8??
Those two are error codes, and they mean the following:
E8 - The waste ink absorber is almost full. Press the OK button to clear the error.
Printing can be done until the waste ink absorber becomes full. If the waste ink absorber becomes full, please contact your local Service Center for replacement of the absorber and machine maintenance.
The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations, etc.
E27 - Manual does not specify what this means, but tells you what you should do: Turn the machine off, and remove the power plug from the outlet. About ten minutes later, plug it in again, and turn the machine on. If the problem is not resolved, the machine may require servicing. Please contact your local Service Center.
You can read more about the error codes on Canon website.
Dec 02, 2010 | Canon PIXMA MP150 All-In-One InkJet...
"ink absorber is almost full, contact service center" - what does this mean?
Inkjet printer has waste ink absorber inside, sponge alike. The function of waste ink absorber is to localize and keep waste ink safe inside the printer and does not harm the electrical parts.
Waste ink is produced from print head cleaning process and borderless printing. When capacity of the ink absorber raise to about 90% then warning message appears.
You need to bring your printer to the nearest service center to get waste ink absorber replaced.
Source:
Printer Clinic: Printer Tips,tricks,troubleshooting
E-manualshop: Online source of service manual
Aug 08, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Canon MP460 Printer - the ink absorber is almost full. What do I do?
Before the waste ink absorber becomes completely full, contact a Canon service representative. (You will need to replace a particular part of the printer.) Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing cannot be performed until the Waste ink tank is replaced.
Feb 20, 2010 | Canon PIXMA MP460 All-In-One InkJet...
Printer won't print. Says to contact service
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Dec 10, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Triangle and ON/OFF switch both flashing. Window reads 'CHECK PRINTER'. What exactly do I check? Window had been reading 'WASTE INK NEARLY FULL' for a fortnight, but I couldn't find out how to deal with...
The waste ink absorber is getting full.
The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations, etc. http://support-nz.canon.co.nz/contents/NZ/EN/8000137103.html
Nov 09, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Its appear " The ink absorber is full. Contact the service center."
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you.
May 11, 2009 | Office Equipment & Supplies
Printer says ''waste Ink absorber is full'' see service center
This is what the manual says: Ink used for cleaning is absorbed in a waste ink absorber placed in the machine. Press [OK] to cancel the error so that you can continue printing. Once the waste ink absorber becomes completely full, printing cannot be done until the waste ink absorber is replaced.
Canon recommends to contact a Canon service representative as soon as possible.
Nov 12, 2008 | Canon PIXMA MP150 All-In-One InkJet...
ERROR MESSAGE 2
How do I change the ink cartridge for the Canon Pixma 150
Sep 01, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA iP4000 InkJet Photo Printer Logo
106 people viewed this question
old marine
old marine
