Question about Belkin Computers & Internet
I have a belkin wireless adapter which connects to an BT Voyager ADSL router. This has been working fine for a number of years. Recently the adapter has failed to connect to the router and doesn't seem to pick up a strong signal - when it does wventually connect, it takes forever to get an IP address and when it does seem to connect, it's allocates an arbitrary address - in effect it doesn't connect. Tried powering off/on PC and ADSL, rechecked encrytion keys all OK but no success. Yesterday, I corrected the problem by powering off the PC, plugging in the Belkin adapter into a diferrent USB port and booted up. When the adapter didn't connect, I placed it back into the original USB port and it worked ! I suspect the adapter is f**ked, but would welcome opinions. Unfortunately I don't have another wireless computer to test out the ADSL modem connection (that would prove if it was the adapter or the ADSL router)
    Problem Solver:
  • 42 Answers
Hi charisa12, before losing your temper pl delete the driver for wireless adapter and try to reload the OEM driver if possible, it may work fine.
Posted on Jul 30, 2008
Dont have a cd everything else is working
http://download.cnet.com/bt-voyager-205-adsl/3000-2112_4-68694.html
http://download.cnet.com/palladia-300-400-usb/3000-2112_4-65588.html if these packages are not the right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
eg: motherboard name wireless or ethernet driver
you might have to try a few times to get it right
hope this helps
Sep 11, 2012 | Belkin ADSL Modem / Wireless Router - UK /...
New Belkin router wont connect to internet.
your user name and password have been entered incorrectly, they are case sensitive and must be exact. Make sure your ADSL settings are set at 0/38 (you'll see where)
Nov 12, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin Wireless G Plus MIMO router - connectivity problem
  • this problem can be ISP releted they may have some issues on the ADSL line connection
Aug 10, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How do i connect my router to my adsl filter?
Reset your adsl and connect your LAN cable from your adsl to your wireless router. you should have wireless all over the place if not let us know
Jan 14, 2009 | Belkin (F5D9230-4) Wireless Router...
Wireless G Desktop Card Connection to BTHome Wireless Router
uninstall the bt desk top help first then the bt wireless connection , if ur wireless card has an utility use it to configure . the connection might be due the conflict between the wireless software. checked if ur getting limited or no connectivty if so delte and recreate  the wireless profile, if ur using bt router like home hub or voyager go the router page with the ip for hub its 192.168.1.245 and navigate to advance and keep the wireless channel to 9 or 11  for voyager the its 193.168.1.1
Oct 21, 2008 | Belkin 802.11g Wireless Desktop Network...
I am replacing BT 105 modem with a Belkin adsl2 modem with wireless g router. The 105 has a blue cable with a square connector. I tried to put the yellow supplied cable in the back of my computer but it...
no, but you need to configure the router to connect to the internet, you should have a "quick start guide" that will help you connect to your router and set your ADSL dial settings (as it needs this to connect you to your internet service)
once these connection settings are set you should be able to connect to the internet
you can then explore the other settings including the wireless configuration of your router
Oct 03, 2008 | Belkin Computers & Internet
Can't even connect to "setup assistant"
it sounds like you need to keep using your usb modem to connect to the internet. then setup internet sharing on the computer and connect the wireless router to the network plug on the computer.....
then basically you are sharing the internet to the plug on the back of the pc into the router and then wirelessly out to the network and PS3
Aug 18, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Acer Aspire 4315 can't connect to internet through wireless ADSL router
netsh int ip reset reset.log
netsh winsock reset catalog
Reboot
Jun 09, 2008 | Acer Aspire 4315 Notebook
Belkin f5d7633-4 wireless g modem/router
when you upgraded did any settings from your isp change like passwords or usenames that your router may not be registering at your isp's server, or the line speed that you are now getting is not suported by the router.
type 192.168.2.1 in your web browser and check the connection settings.
Oct 20, 2007 | Belkin (F5D7633UK4A) Wireless Router
Belkin wireless G USB adaptor 802 11g
Correct installation of this cheap little piece of kit from Belkin might be the worst thing you ever do! If you find that Windows XP is freezing 10 times per day, just remove the wirelss adaptor and you will find that the problem disappears... The conclusion will be as obvious to you as to many other users.
Jul 13, 2007 | D-Link AirPlus G DWL-G122 802.11g/b...
Computers & Internet Logo
90 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
