Question about Tomtom ONE GPS Receiver
Help downloaded free upgrades.. told me to unplug it from pc did so..thats all i get now is a picture of a tom tom with a red circle with a white x.. turned it off and pressed reset button..nothing happens..
  • 515 Answers
My tomtom fell on the floor and i get aflashing red and white cross. How do i correct this and get my device working again?
Internal memory was damaged when dropped.. OR the SD card if it has one. Replace the sd card and copy data over from back up
Feb 23, 2013 | Tomtom ONE XL GB Car GPS Receiver
Tom tom go 700
Can be sofware problem or internal memory.
try to conect to pc if you see the dataa from the tomtom is just software if not can be from memory,if you dont know how just send it to a repair centre.
\try this www.satnavservice.com
Aug 29, 2009 | Tomtom GO 930 GPS Receiver
Large white X in red circle flashing
This works for most tomtoms so there is nothing to loose and everything to gain
Remove the SD card
The card needs to be formatted properly first that's all,
formatting is better done in a card reader.(opionions vary)
Right click on it and select format select FAT32 as the files system
Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
You now ned to select your tom tom which will also show as a drive.
In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
then just copy ALL the files from the tom tom to your sd card
DO NOT USE CUT AND PASTE !
Once all the files are on switch off the tom tom and insert the sd card
It should now work
Aug 27, 2009 | Tomtom GO 930 GPS Receiver
Screen deactivated & a red circle with an 'X' flashing
First turn your firewall off (if you have one). You need to go into your 720 with the TomTom Home software and erase the downloaded software (with the remove items from my device) and reset the device (little reset button under the unit keep it pressed for 5 seconds), place it back in the cradle and restart your computer and than restart the 720 , bring the TomTom Home program up, and when the TomTom Home software in your computer restarts and detects the 720 it will tell you that you need to update the application, if it doesn't than you force the update by going to the add maps option, select items on my computer, select applications and press the add button, when done, go back and to device (option in top of your screen) and select disconnect device, restart your 720 and it should be back to life with the upgraded software.
Aug 01, 2009 | Tomtom Go 730 GPS
My tomtom 125 won't install. When it turns on, the only screen it shows is a picture of the tom tom with a red circle with a white X in it. It seems to have install in tomtom home however.
At tomtom.com I found a link to download the new version of tomtom home. For some reason when I plugged in my tomtom to my computer it wanted to download an old version of home and that would not install the applications to my tomtom. After downloading the new version of tomtom home everything worked fine.
Mar 23, 2009 | Tomtom ONE GPS Receiver
Brand new Tom Tom One 125 showing blinking red X when turned on
I was able to speak with Tech Support at Tom Tom and got sent some links for solutions to these problems.  I was able to solve the problem following directions from this website.  Without that response of the support person to this specific problem, I would still be without my new GPS system.  Turned out that there is a conflict with the MAC OS and updates to Tom Tom, but there is a solution to this that worked for me.
If you get the continual red circle with blinking "X" and recently tried updating either your maps or most recent app, here are the two web links that will solve the problem:
www.tomtom.com/10324 (to disable SPOTLIGHT from causing a conflict on the Tom Tom ONE)
www.tomtom.com/9091 (general info for removing software and re-installing software to the Tom Tom ONE)
Do the disabling of SPOTLIGHT first, then remove and re-load software for Tom Tom ONE.  Good Luck.  This did the trick for me.
Jan 25, 2009 | Tomtom ONE GPS Receiver
Tom Tom One XL Europe
Thanks for all your help guys!!
Aug 16, 2008 | Tomtom ONE 3RD EDITION GPS Receiver
Tom tom go 720
I have exactly the same problem. Everything worked fine until I did a software upgrade. I have tried the reset suggestion but it has not fixed the problem. I have been told that a possible solution is to install the version of the OS that was there prior to the upgrade but I cannot find this anywhere
Jan 04, 2008 | Tomtom GO 700 GPS Receiver
Tomtom ONE GPS Receiver Logo
60 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
