Question about IBM ThinkPad R51 Notebook
Laptop can't aquire IP address
My laptop connects to my wireless network at university, but will not connect to the network at home. I have tried repairing the network connection,but it still says signal strength excellent and is aquiring IP address. I have tried setting the IP address instead of it aquiring automatically- this seems to connect for a few seconds and then disconnects again. I have a different laptop which connects to the wireless network fine. When my laptop is aquiring the address automatically and I do run, cmd, ipconfig/all it states:
IP Address. . . . . . . . . . . . : 0.0.0.0
Subnet Mask . . . . . . . . . . . : 0.0.0.0
Default Gateway . . . . . . . . . :
DHCP Server . . . . . . . . . . . : 255.255.255.255
I have looked at the DCHP client and it is started and set to run automatically.
My laptop is an IBM Thinkpad model R51 and we have a Netgear router.
Any suggestions would be appreciated.
Thanks
  • matty88 Oct 24, 2008
    sometimes it works and sometimes it gets stuck. It can "see" the wireless network and gets stuck in a loop trying to obtain an IP address. When I press the button to identify available wireless networks it can't "see" any. The wireless symbol on the laptop case is lit up. "sees" a 54 mb network. Can connect directly on an ethernet cable. Restarting sometimes works, but not sure if that is the cuprit. Looked through MS CONFIG to see if anything had been accidentally turned off. No luck there.
    Any thoughts?
    Matty88
    Genius:
  • 2,028 Answers
This sounds to be a compatibility issue with either the wireless software or wireless card. Check to see if there are any updated drivers for the wireless card at IBM's support site. If there aren't any or the card still doesn't work after the updated drivers are installed, then you might try a different/newer internal wireless card, or a universal external wireless card for use with your home system.
Posted on Jul 30, 2008
I had the same problem, went to Microsoft and found this solution on line.
1. Click Start, click Run, type %SystemRoot%\system32\services.msc /s then click ok.
2. Double-click Wireless Zero Configuration.
3. In the Startup type list, click Automatic (if it shows Automatic already, change it, then put it back to Automatic, that will activate the Apply button) then click apply.
4. In the service status area, click Start, and then click OK.
That fixed it for me after fighting it for about a month.
Posted on Mar 16, 2009
Suddenly unable to connect to wireless network
If you get a 'Limited connectivity" on you wirelessconnection on your laptop, it means that the wireless card on your laptopprobably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and thenclick Repair.
This will force the wireless router to issue a IP address to the wireless cardon the laptop.
Apr 02, 2012 | Dell Inspiron M501r Laptop Computer (AMD...
Our laptop won't connect to our network set up on our desktop home computer. The desktop is running Windows XP Home Edition V2002, and the laptop is running Windows Vista Home Premium V2006. When we try to...
if you have wireless acces point or 802.11 known as wi-fi,
there might be a problem in your laptop internet protocol, you laptop have an ip address already.
you can fix it by using your desktop, open your desktop go to control panel/network connection/status/
details.
copy the details information and put it to your laptop internet protocol. you can found it in network connection properties you can see Internet Protocol (tcp/ip) open it configure it manually. the last number of the ip address must bigger than the desktop. ex, 192.168.1.2 in desktop. the ip address of the laptop must be 192.168.1.3.
Feb 02, 2011 | Acer Computers & Internet
Laptop won't connect to wireless internet
wat is the Ip address
default gateway
????? Fast reply needed for a quicker resolution
Mar 18, 2010 | Google Chrome
Nx6110 network not working
have you installed proper drivers,if not download it from the below mentioned link
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=449878&prodTypeId=321957&prodSeriesId=449877&swLang=8&taskId=135&swEnvOID=1098
and installing the drivers check for the further configuration.
if dhcp not enabled in your modem then you have give the static ip address
Regards,
pp
Dec 02, 2009 | HP Compaq nx6110 PC Laptop
Problems connecting, stuck on aquiring network/renewing IP addres
i want to down load the mother board drivers and utilities c.d,how will down load
Sep 01, 2009 | Intel 2915ABG 802.11a, 802.11g/b Wireless...
Cant connect router & dsl modem, cant aquire ip address
Try typing another website on the address bar.
Try checking on your router advaced setting make sure that Mac filtering is off under network filter.
Make sure all other settting on the advaced setting are also in default setting.
Jan 06, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Cannot aquire IP address through my Desktop using Lynksis Wireless Router
sounds like you need to reenter the password/key
go to network connections and disconnect from it. then try to reconnect after the refreshes.
is it asking for a password/key?
Dec 26, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Setup
If that is the report that the laptop gives for an IP address, then you have to change the IP address settings.
Go into your network settings, and tell it to automatically aquire an address, and DNS.
Once you click OK, it should sense the DCHP from the router.
If the IP is already set to automatically aquire, then the router needs to be reset to factory defaults. That should put you back to the 192.168.2.xxx settings.
Jul 27, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Internet connnection
Access your wireless router by typing it's ip address in your browser. Log in and change your netkey password.
May 23, 2008 | NetGear WGR614 Wireless Router
IBM ThinkPad R51 Notebook Logo
1,154 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
