Question about Plumbing
Its a water pump for our house and barn pumps probably close to 300 to 400 gallons a day over the course of the day was wondering if it is wired for 220 if using it with 110 will ruin it
    Sergeant:
    Novelist:
  • 177 Answers
Unless the pump motor has provision on it specifically for running on 110, then yes, running a 220 motor on 110 will ruin it. It will cause the motor to overheat, if you can get it to work at all. Some 220 motors are designed so that you can run them on 110. If yours is, it should have instructions and a wiring diagram for that. Even if it IS designed for 110 or 220, running it on 110 WILL cause it to run hotter, and will shorten its life.
Posted on Mar 04, 2011
Why is their about 15 gallons of water built up under my house within a couple of days, but no visible leaks?
Drain pipes might go under the ground. You have slab leak. Plumber will figure it out, or check blue prints of Your house if You have those(will show You "What Where")
Jan 29, 2015 | Plumbing
PRIME A GOULD PUMP
whats your question how to prime the pump? if so at the bottom is a 3/4 inch plug screwed into it, or at top, once the pump is hooked up to the lines turn off the power, and unscrew the prime plug fill with water, then screw in tight DO NOT USE THREAD SEALANT THEN THROW THE POWER TO THE PUMP, of course house supply valve must be off 3/4 turn valve off until the line is primed then open the supply line to house slowly to supply the water to all the lines, NOTE WHEN YOU FIRST INSTALL A NEW PUMP, HAS TO BE PRIMED, HAVE TO HAVE SUPPLY LINES FROM WELL TO HOUSE CLOSED TO PRESSURE THE TANK AND TO FILL THE LINES.
Apr 27, 2014 | Jet Flo 04325143A Marine Heavy Duty Water...
Model #SD-20-2N11CC WATERWAY PUMP (2HP) - Trying to find out how many gallons per minutes pumped on high & low speeds
Rule of thumb for a 2 HP pump using a 2 inch pipe is between 60 and 80 gallons per minute. Factors affecting flow rate is the distance between the pump and the pool, how many bends and turns and of course the condition of the filter. If you need to meet a specific turn-over rate, use the lower number to determine in the event you sould be called on the carpet.
Low speed? I am sorry. I don't know the rule of thumb on this.
You could install a flow meter, available at your professional pool supply. They are easy to install and not a lot of money. Follow the installation instructions as best as you can.
Incidently, comercially speaking, the 'turn over rate' should be around 8 hours for a public pool. Your jurisdiction may have other standards. Commercial pools should run 24 hours a day at that rate during the open season. Turn over rate means all the gallons of the pool should go through the filter in 8 hours, or all the gallons should go through the filter three times per day. Example: 16000 gallons of water in the pool, your filter and pump should be pumping 2000 gallons per hour. Studies show that it actually takes up to 5 days to get every actual 'chunk' of water to go through the filter, so, many of the 'chunks' of water go through the filter multiple times per hour. BTW, I use the word "chunks" in an effort to better paint a mental picture of what is happening. I am not suggesting your water has "chunks" in it.
Thanks for your question @ FixYa.com
Jul 07, 2011 | Waterway 2hp Hi - Flo 2 Speed Above Ground...
I am assumimg that when the plastic peg is pushed down the recirculater for the hot water is off. When up, it is on. The Build set the timer and no manual was left. Hot water comes onwhen it should be...
Do you have the auto-circ recirculation pump with timer?
If so, here is manual for that specific product:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
http://waterheatertimer.org/Auto-circ-manual.pdf
Manual gives instructions for a different timer dial than timer than shows on unit, so they must come with different dials.
Instructions say pegs pulled out = timer on
Conversely, pegs pushed in = timer off
You might be able to hear the pump operating to see if these instructions are correct for your recirculation timer. The kids would love a listening assignment under the sink.
To see images showing how recirculation system operates:
http://waterheatertimer.org/Water-heater-recirculation-system.html
Setting times:
Try 1/2 hour ON in morning and 1/2 hour ON in evening. Warm water will stay in pipe for a while.
Recirculation system with timer costs $10-17 per year to operate, assuming timer runs 1 hour per day with electric prices at 10 cents per kilowatt hour. Operation cost is straight line ... so if timer runs 2 hours per day, cost is $20-34 per year at 10 cents per Kwh.
Water saved might equal 5 gallons per day, or 1825 gallons per year depending on usage. Average water wasted waiting for hot water is 1/2- 2/3 gallon depending on length of pipe. Set a bucket under spigot to test your home when circulation system is not ON.
Cost of water depends on local billing rate. The municipality saves purifying water, pumping water to your home, and finally pumping and processing sewage drainwater.
If you are on a water well, the pump electricity from saving 2000 gallons a year is a dollar or two per year since water well generally consumes less than 1Kwh per day for ordinary house.
Sep 29, 2010 | Hardware & Accessories
How do i replace a water pump on a 1997 vw passat
Water Pump REMOVAL & INSTALLATION 1.8L Engine NOTE: The coolant pump is bolted to the brackets for the generator, power steering pump, and cooling fan.
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Position the lock carrier into the service position as follows:
    1. Remove or disconnect:
      • Front bumper.
      • Any wiring or connector that would inhibit locking the carrier.
      • 3 quick-release screws on the front noise insulation panel.
      • Air guide between the lock carrier and the air filter.
      • Retaining clamps for the wiring harness at the left side of the radiator frame.
      • No. 2 bolts and install Support tool 3369 or equivalent.
      • Remaining bolts and pull the lock carrier out to the stop.
    2. To secure the lock carrier, install the appropriate M6 bolts into the rear of the lock carrier and fender.
  3. Remove or disconnect
    • Negative battery cable.
    • Accessory drive belt, then the engine driven cooling fan.
    • Coolant.
    • Clamps for the coolant hoses at the water pump.
    • Intake air duct between the intake manifold and the charge air cooler.
    • Generator mounting bolts and slide it forward.
    • Wiring from the generator once it is removed.
  4. Unbolt the following supports and brackets for the generator, power steering pump, and engine cooling fan:
    1. Intake manifold support
    2. Support for the engine torque bracket
    3. Brace to the cylinder block (remove completely)
  5. Remove or disconnect:
    • Brackets for the generator, power steering pump, and engine cooling fan, positioning the brackets to the left side using a piece of wire
    • Coolant hoses from the pump and thermostat housing
    • Coolant pump housing from the timing belt cover
    • Coolant pump mounting bolts, then the pump
    • Impeller housing from the pump housing
    To install: Fig. 1: Exploded view of the water pump, housing and related components — 1.8L engine 9301wg04.gif
    Fig. 2: Assembly bracket with water pump mounting bolt tightening sequence — 1.8L engine 9301wg05.gif
  6. Using a new gasket, mount the new coolant pump to the pump housing. Mounting bolts: 84 inch lbs. (10 Nm).
  7. Using a new gasket and O-ring, install the coolant pump. Mounting bolts in alphabetical sequence: 18 ft. lbs. (25 Nm).
  8. Tighten the coolant pump housing to the timing belt cover to 84 inch lbs. (10 Nm).
  9. Install or connect:
    • Coolant hoses to the pump and thermostat housing.
    • Brackets that were removed. Mounting bolts: 18 ft. lbs. (25 Nm).
    • Wires to the generator, then install the generator.
    • Air intake duct between the intake manifold and the charge air cooler.
  10. The remaining steps are the reverse of the removal.
  11. Fill the engine with coolant
  12. Fully close all power windows to stop, operate all window switches for at least 1 second in the close direction to activate the one-touch opening/closing function
  13. After installing the lock carrier, check the wiring for proper routing near the cooling fan
Aug 11, 2010 | 1997 Volkswagen Passat
I have a 15 gallon Fimco trailer sprayer. Last
Bleach gives off corrosive vapors, so the internal parts of the pump may have corroded over time. Least expensive fix is to disassemble the pump, find and replace any corroded parts, but you'll be tinkering for a day and it may not be repairable anyway. More expensive but faster is to replace the pump - check the GPM rating and find it here for about $60 - $100. Good luck!
Jul 05, 2010 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
My pump is no longer working my pool water is starting to turn green, I shut down the power but I can't seem to open up the pool pump to clean the basket can you give me any suggestions?
First get some liquid chloriene in the pool start with about four gallons. Loosten the lid ring then turn the pump on and back off after a few seconds. If your trying to get the pump housing open do the same thing with the lock ring that holds it closed.
May 06, 2010 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
Code LC, I cleaned the filter, won't stop beeping
you need to flush out the rinnai. to do this you will need 4 gallons of white viniger & a circulating pump. #1 disconnect the power. #2 close both incoming & outgoing water valves under the unit. #3 conect a drain hose to the out going flush valve ( flush valves are under the unit & have brass caps) #4 connect pump outlet hose to ingoing flush valve. #5 put pump incoming hose & drain hose from outgoing flush valve in a 5 gallon bucket. #6 pour 4 gallons of vinager into the bucket. #7 open both flush valves. #8 turn on the circulating pump & let viniger pump in the incoming flush valve through the rinnai & out the outgoing flush valve back into the bucket for 45 min. #9 disconct pump from incoming side & close incoming flush valve.( don,t close outgoing vaves at this time) #10 put out going hose in empty bucket. #11 open incoming water to flush viniger out of unit. # 12 disconct outgoing hose , close outgoing flush valve & open outgoing water valve. #13 clean filter & turn on power.
Jul 08, 2009 | Rinnai Water Heaters
I have installed a 4 gallon inline water heater close to the bathroom. The main hot water heater is at the other end of the house. Now the hot water in the bathroom runs luke warm when the washing machine;...
you don't have a circulating line in it,, there for it is pulling the hot only,, when you have the 2 systems you have to have it circulationg or take 1 out, it being it is hot water they will vapor lock,, meening no hot water , you could get a circulating pump that actually hooks to the cold and hot side under the sink far away from the water heater and it has a timer on it that will circulate the water at certain times of the day,,, this would solve your problem
Jul 02, 2009 | Jacuzzi RapidHeat In-Line Heater U395000 [...
96 chevy cavalier water pump empellar
Cnbarr, Although it is possible, it is not probable. Of course NEW only means "Nerver Even Worked". That being said, you might want to go to your local parts house and take a look at another water pump and see if the impeller is facing or looks the same. If it is, yours is probably OK.
Let me know what you find and we can go from there.
Regards,
Feb 25, 2009 | 1996 Chevrolet Cavalier
Plumbing Logo
118 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
