Yahoo Messenger Logo
Posted on Mar 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have down loaded yahoo messenger but when I sign it it tells me my application is not found
Mike
Level 3:
  • Master 4,383 Answers
  • Posted on Mar 04, 2011
Mike
Master
Level 3:
Answers
4383
Questions
Helped
1261576
Points
17064
Try removing Yahoo messenger, from teh control panel, and then reinstall it again.
Anonymous
Level 2:
Scholar:
  • Expert 122 Answers
Anonymous
Expert
Level 2:
Scholar:
Answers
122
Questions
Helped
32670
Points
344
Hello, try going to program and features for vista and win7 and if you have XP you can go to add & remove program in control panel, uninstall yahoo messenger if it is there, try getting the new version run the download manager for yahoo messenger it will be installed automatically in the computer just follow the prompt. this is the link for to download yahoo messenger "http://messenger.yahoo.com/" note: downloading the installed is different from installing the software. Thank you for using Fixya.
It will not let me sign in
Make sure that your internet connection is working. Try to access an internet site. If your connection is not working for some reason you will get the application not found message.
2answers
When ever i click on to any thing inmessenger it says application not found have tried to re down load at least a dozen times still no good
Hi, it is a bit odd problem. Try with installing "all-in-one" messenger called Trillian. You can download it HERE.
God luck, Kobac
3helpful
How to down load yahoo messenger
Sometimes proxy setting or a firewall or even the antivirus can stop Yahoo Messenger from downloading. If you've turned off the firewall, you may want to have a look into your proxy settings or antivirus.
Alternatively, you can download the application from a different website like Softpedia. Yahoo will only give you an installer which will download the application and cause one of the above problems. Here's a link to Yahoo Messenger 10.
1helpful
I was having problems with my yahoo messenger so i uninstalled it and installed messenger 10. i can receive IMs but cant open any other programs in messenger. ex: fishville, match.com, etc. can you tell me...
1. Reboot your computer.
2. Press Ctrl+Alt+Del on your keyboard. This will bring up the Windows Security window. Click the "Task Manager" button and then click the "Task Manager" tab.
3. You will see a list of files/applications. These are the applications running in the background on your system, whether they show on your taskbar or not. Any one of these applications could be causing a conflict with the Yahoo! Messenger installation.
4. Click the top item on the list to highlight it. Then hold the "Shift" key down and click the last item on the list. This should highlight the whole list.
5. Click the "End Task" button. This will temporarily close all background applications on your system.
6. Click the "X" in the upper right corner to close the Task Manager window.
7. Install Yahoo! Messenger. You should not experience the same issue that you had before.
8. After Yahoo! Messenger is installed,run registry cleaner reginout also reboot your system. All other background applications will return to their original configurations.
I cannot go through to my yahoo mail using my yahoo messenger,that i usually did before.when i'mclicking it now a messages comes up and say that application cannot be found. so what i am doing now is i go...
You may need to uninstall and reinstall your yahoo messenger.
If you are still signed into your messenger and try to uninstall; it may not work.
Go to start menu at bottom left
Go to control panel
Click on add/remove programs
Select the Yahoo Messenger
Uninstall it.
You can reinstall it at this link
http://messenger.yahoo.com/download/
I never recommend people reinstall programs/applications over top of the old ones. It usually causes issues.
I also recommend you clear your cache.
If you need further help, reach me via phone at https://www.6ya.com/expert/carolyn_427ff26936286336
1helpful
2answers
I have been diconnected from the chat, because i signed in to yahoo messenger. how do i disconnect from the yahoo messenger
You disconect fromchat because you signed in the yahoo messenger
Messenger is a different applicatio from chat. yahoo considers the user of the application as different, so yahoo disconects you from one application from the other
Every time i log into my yahoo messenger it says that it has encounterd a problem and needs to close. Its been a real hassle for me. Ive tried everything Including deleting and redownloading it. It still...
This issue is related to the traces found after the removal also,
so try rebooting the machine after removing the application.as the reboot will remove the traces and no identity related to application will be found.
then reinstall the latest application.
2helpful
2answers
Cannot open yahoo messenger, yet i am signed in
Try using the below website for signing in:
http://webmessenger.yahoo.com/
If that work than the issue is with the Messenger application reinstall the messenger.
1helpful
2answers
Yahoo messenger problem
you might have installed third-party plug-ins, audibles or emoticons on your yahoo messenger. these programs are automatically loaded everytime yahoo messenger starts. they work fine, not until you reinstall yahoo messenger or upgrade it to a newer version causing an internal error when they are loaded. first, remove/uninstall all these programs from the add/remove programs in the control panel, be very careful when doing so and be very sure of what you are removing. then uninstall yahoo messenger. if error still occurs during the uninstallation process, you haven't removed every program/emoticons/plugins connected to your yahoo messenger. when uninstallation is successful, restart your computer and then delete the yahoo messenger folder in the programs folder on your system hard drive. then you can reinstall yahoo messenger before adding/installing your emoticons or plug ins again.
Top Yahoo Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
