Hi , my Karcher water blaster makes a horrible repetitive surging noise when its powered on but not when its actualy blasting. I suspect its the pump bypassing. Pressure is also down on what it used to be. Is the pump at fault here?
  • 1 more comment
  • kiwihunt Aug 11, 2008
    Thanks for the help. I stripped the pump down and the piston seals are worn.
  • number1IFA Apr 07, 2009
    Pump doesnt properly work on full pressure, sounds like it is stopping and starting, does this from half pressure upwards. It will pump out at low pressure, but doesnt **** from detergent resevoir. I have tried the inlet filters and lance to make sure they are all clean, I have also tried the power supplies
  • Anonymous Mar 30, 2014
    Motor runs OK, water flows through but motor surges and no pressure
Is there dribbling water coming out of the casing if you plug in the incoming hose but don't switch it on? This is usually the case. Either the seals have worn on the pistons (usually 3) or you have a cracked pump casing.
Posted on Aug 10, 2008
Will not heat we replaced both elements but still no hot water rheem model no.82v522marlene we suspect we had a power surge during last storm because the furnace went out also at the same time
Hi I suspect your thermostat will have also been damaged if you had a surge I always replace thermostats at the same time as the elements
Also check the wiring as sometimes surges can melt the copper core of the wiring, but be careful always turn off the power first before any electrical works!
Mar 06, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
I purchased a reconditioned Karcher 4000 and upon first use, the spray surges. It will go down to almost nothing then back up to full blast in about 5 second increments. Any advice?
Bleed the system by running water without the unit on, You have an air lock, open the drain cocks and allow water to run slowly for 2 minutes, then close everything and try it
Mar 06, 2010 | Honda Karcher G4000RH Pressure Washer
Karcher K2.91M nlets water in and out but won't
wot like a buzzing noise if so try and turn the fan at the rear of the motor if you can do this it is more than likley the capacitor
Dec 04, 2009 | Karcher K2.26 Electric Power Washer
The motor keeps surging
If there's a lot of sediment in your water supply, there's a chance that sediment has gummed up the pressure switches. I'm assuming it has a full power switch and high power switch. It runs on full power until a pressure switch is satisfied, and runs on low power to slowly build the pressure back up, at which a second switch is satisfied from the pressure and turns the motor off. These things are not easy to work on, and are made of metal probably too fragile to try any chemicals. You should probably contact the manufacturer.
Sep 19, 2009 | Karcher 1750 psi Electric Pressure Washer
Karcher Power Washer that surges up and down with water pressure.
Before you start it up:
1. Disconnect the high pressure hose 2. Connect the water supply and turn on 3. Make sure water is flowing through the pump
Start the motor, run for about 10 seconds and then turn off.
Turn off the water supply, connect the high pressure hose, turn water back on, start the motor and away you go.
May 29, 2009 | Karcher 2500 PSI Pressure Washer
I own a karcher water blaster 449M and needs an expert to solve the pomblem It does not bring out the presure required to the right job and makes a noise as well when you start it can someone please let...
sounds as if you have a pump problem. your best bet is to go online to maker or a dealer near you for service help.you may wind up having to replace pump.
Jun 20, 2008 | Karcher 2500 PSI Pressure Washer
Karcher KB 499
Hi the pump surges when there is a leak on it find the leak that should sort your prob.
Hope this helps. Sean
Feb 17, 2008 | Karcher 2500 PSI Pressure Washer
No water pressure
Plugged in but does not work
Nov 12, 2007 | Karcher 2500 PSI Pressure Washer
Washing Machines Logo
347 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
