Question about Whirlpool Calypso GVW9959K Top Load Washer
LL SIGNAL ON CONTROL PANEL
THE LL SIGNAL APPEARS ON THE CONTROL PANEL AND THE WASHER STOPPED WORKING. I RESET THE BUTTON BY TURNING OFF THE MACHINE, BUT IT STILL WON'T WORK AT ALL AND SO I HAVE SIMPLY UNPLUGGED IT UNTIL THE PROBLEM CAN BE DETERMINED.
  • 2,071 Answers
WHAT IS WRONG WITH YOUR WASHING MACHINE?
LL SIGNAL ON CONTROL PANEL - small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load WLL SIGNAL ON CONTROL PANEL - redarrow.gifle
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Jul 30, 2008
My washer error message unit detect a problem
The most common solution for this message is to turn the machine OFF and then ON. If the error resets, you are done.
However, this message will sometimes cause the control to stop the machine from working. With this type of error, the control panel will need to be reset. The following steps will allow you to reset your control.
Solution:
  1. Clear the ERROR from the screen: Press and hold the MY CYCLES and BACK buttons simultaneously for 3 seconds. The control will display any recorded errors. Please write down what error codes are shown on your screen in case service is needed. If a MORE icon is displayed on the screen, press MORE to list additional errors. When the EXIT button appears, press EXIT.
  2. Remove Power: Follow the onscreen instructions to remove power (unplug unit) and then immediately plug unit back in.
  3. Clear Setup Mode: After power is restored, a setup screen that begins with "Congratulations..." will be shown. DO NOT PRESS the OK button shown at the bottom of the screen. Press the START/STOP and POWER buttons simultaneously until the Home Screen is displayed. Your unit is ready to function normally.
Mar 02, 2015 | GE Profile WPRE6100G Top Load Washer
Tip
CONTROL LOCKED on Whirlpool/Kenmore Washers/Dryers
The Whirlpool duet washer needs a reset to resolve the control lock problem. To reset the washer you have to Press and hold the END OF CYCLE/CYCLE SIGNAL button for 20 seconds. This button is usually located on the right side of the panel facing the front of the washer.
Similarly, if it is a Kenmore Washer you can press and hold the DRAIN/SPIN button for 20 seconds.
To reset the Kenmore Dryer for this Control Lock problem you have to Press and Hold the AUTO DRY LEVEL button for 20 seconds to unlock the Controls.
Kevin
on Mar 06, 2011 | Washing Machines
Control lock lit, no other buttons work
Instructions
    • 1 Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
    • 2 Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked, and the washer is ready for use.
    • 3 Lock the washer again by pressing and holding the "End of Cycle Signal" button until the "Control Locked" indicator light turns on.
Read more: How to Unlock the Control on a Whirlpool Duet ' eHow.com http://www.ehow.com/how_5701217_unlock-control-whirlpool-duet.html#ixzz2HVS4i8hL
Jan 09, 2013 | Kenmore HE4t 3.8 Cu. Ft. King Size...
FH appears
The FH error code on your Kenmore Elite washing machine is an indicator that there is a problem with incoming water. When there is little water coming into the machine, the FH code will appear and the washer will stop. There are a couple of common problems you can check while you are resetting the FH error code. You will need to remove the power supply to the washer to reset the code
Look for the "Pause/Cancel" button on the washer control panel. The button will be below the digital time clock and to the lower right of the wash cycle selector.
  • 2
    Press the "Pause/Cancel" button twice to cancel the wash cycle. Unplug the Kenmore Elite washer from the wall outlet.
  • 3
    Check for kinks in the water supply hose while the washer does not have power. Turn off the water supply spigots and remove the hoses from the back of the washer. Check the port screens at the hose connections for sediment buildup and clean as necessary.
  • 4
    Connect the water supply hoses back to the washer and turn on the water spigots. Plug the washer cord back into the wall outlet.
  • 5
    Select the wash cycle and press the "Start" button.
  • If the error code come back you will probably have to change the water inlet valves. No hard to do and you can fdo this yourself
  • Dec 14, 2010 | Whirlpool Washing Machines
    Control Panel is locked
    Is the control panel locked or just not working ??? If its actually locked push and hold for three to four seconds the (cycle signal ) volume selection button on the far right of the control panel.if the panel is locked that will unlock it... If you are still having problems we will no its not a panel lock issue.... Good Luck
    Sep 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    My ge profile harmony washing machine has a message that says "a problem has been detected with this unit."
    Washers - Harmony Washer Error Message or Code
    The Harmony washer electronics can automatically determine if problems exist with the machine. Sometimes an error code can also be present because of things the machine cannot control: like changes in house voltage, water pressure, or temperature.
    "A problem has been detected with this unit" will be displayed on the screen.
    The most common solution for this message is to turn the machine OFF and then ON. However, this message will sometimes cause the control to stop the machine from working. With this type of error, the control panel will need to be reset. The following steps will allow you to reset your control.
    Solution:
    GOOD LUCK. TIMOTHY DO 714-334-1998
    Aug 04, 2010 | GE Washing Machines
    My washingmacine stopped working completely. it started with one cycle going out , then a week later another cycle stopped working. now none work. when i turn the machine on i can here a hum , but nothing...
    This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
    This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
    Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
    Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
    Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
    Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
    These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
    NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
    If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.))))
    Feb 13, 2010 | Maytag Atlantis MAV6000 Top Load Washer
    Samsung washing machine F1245 control panel stuck??
    I have Samsung/korea-SW905Washer.When power is switched on the Fault-'1E' appears. what could be the reason.( narrate list of control component failure).
    Bought in the year 1996 at India ( voltas mega washer top loading-7.5kg) and working till last month.
    after few wash cycles the machine stopped at aforesaid indication and it is not functioning due to above fault indication'1E'
    provide me remedial measures or electronic control board circuit.
    May 29, 2009 | Samsung WE356A5W Washer/Dryer Laundry...
    Washer atarted but the water is not come into the washer
    Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
    * Unplug or turn the circuit breaker off for 30 seconds.
    * Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
    * Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
    * Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
    Feb 25, 2009 | Kenmore Elite 45986 Front Load Washer
    Washing machine suddenly stopped working during cycle
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
    Jan 01, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
    Whirlpool Calypso GVW9959K Top Load Washer Logo
    99 people viewed this question
    Dan Webster
    Dan Webster
    Richard Roth
    Richard Roth
    Mike Cairns
    Mike Cairns
