Question about Western Digital Caviar WD2500BB 250 GB Hard Drive
My PC is not recognizing my WD Passport 120GB USB external drive. I used just few days ago and connected the usb cable to my computer and the WD Passport drive and not recognized on my 2 laptop and 2 other laptops. not recognised by computer
  • lendogz Sep 09, 2008
    it not working
  • dH-IDJak Sep 16, 2008
    With WD1600E1MS-00 ...running all with Win.XP SP2..tried to attached with my DELL Optiplex GX620 & HP NC4960....have also connected with 1 to 1 USB port Cable and 1 to 2 USB port Cable..have downloaded all USB2 drivers but seems not working at all ..
  • 95 Answers
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it.
If not - try to remove the drive from the enclosure and connect it directly to the computer to recover your files.
Posted on Nov 30, 2008
3 Suggested Answers
SOURCE: My PC is not recognizing my WD Passport 120GB USB external drive.
These WD Passport external drives are junk. This happened to two of mine, switched to Maxtor.
Posted on Sep 01, 2008
I had the same issue. Its not a power issue because it shows up in device manager. Heres what I did.
Right-click on my computer and click Manage>Disk Management
Your drive should show up there. Right-click on it. If explore is not grayed out, assign a drive letter to it and you should then be bale to see it in my computer.
In my case explore was grayed out. I had to click on the option to format the drive. After re-formatting the passport explore was available. I then assigned a drive letter to it and I have access again.
I guess somehow using it on multiple computers srcewed up the file-system on it. I was using it between windows and linux.
This fixed my problem.
Posted on Jan 02, 2009
I have a 320gb toshiba external hard drive, i've been using it around 3 years without any trouble. A few days ago i lost the cable connecting it to the PC. I bought a few cables but no use. Doesn't...
This is because there is a connection problem between the external drive and the computer. If you have changed cables to no avail, you can open the casing of the external drive where you will find the hard disk inside. Unplug the two cables connected to the harddisk and replug it after a minute. Then try again. If it still does not work, then you need to buy just a usb enclosure and plug the harddisk there to be able to use it again.
Hope this helps. Thank you for using FixYa.
Jan 13, 2011 | Toshiba 120GB USB 2.0 Portable External...
Wont recognize usb anymore
if the external hard disk drive powers on, perhaps replacing the USB cable could help ?
i had WD extrenal, and it crapped out on me -- i had so much vital information that i lost . i finally discovered that the power modeul inside the housing that encases the drive was bad.. i coul not get the PC board replaced.
i hope you can resolve this with new USB cable.
have you tried another computer -- see if that PC recognises the WD external drive
let me know how it works out for you
Nov 03, 2010 | Western Digital WD Passport 250GB Portable...
My computer does not recognize my WD external drive
You've tried different USB cables; so, that cannot be the problem.
You've tried connecting to different computers; so, the problem is _not_ your computer.
What's left is "inside" the case:
* the USB-to-disk-drive adapter,
* the disk-drive.
Open the case, and remove the disk-drive, and connect it as a "slave" drive to some computer.
If it is detected, then the USB-to-disk-drive adapter that has failed.
If it not detected, then the disk-drive itself has failed.
FInd the serial-number on the Western Digital disk-drive, and enter it onto Western Digital's web-site, on the "check-warranty" page. If it's older than 3 years, the warranty probably has expired, unless you were "lucky" and got a 5-year warranty.
Western Digital has a "Customer Loyalty" program -- just buy a new Passport through their web-site, and cite the serial-number, and you'll get a significant discount on _their_ price (could be higher than your local retail computer-store) for a new (probably larger) Passport.
Apr 05, 2010 | Western Digital WD Passport 250GB Portable...
My Passport Drive is no longer recognized by windows
Check to see if the drive is available in disk management, if so and it's got a blue bar at the bottom, try changing the drive letter. If not, try the following:
Normally with the passport drives, you receive a shorter USB cable (this is because the drive relies on power from the PC, which your normal length USB cannot offer sufficiently. If you are using a short cable, try connecting the drive to the back of your desktop PC, this generates more power than the ports on the front (the ports on the front are actually hubs). If none of these options work try it on another PC, using the steps above.
If you still have an issue, the drive has most likely failed and you will need to get data recovery done to retrieve your data. If you do so, contact samsung for warranty information, so that your warranty doesn't become void.
Jan 24, 2010 | Samsung Portable 120GB USB 2.0 External...
WD External Drive-USB recognize, but no icon, can't access
1. Right click on My Computer > Manage;
2. On the new window click on Disk Management, on the right side, right click in the USB Volume and chose "Change Drive Letter and Path..."
3. In the new window click on "Add..." to assign a letter to your USb drive.
Best Regards
Jun 24, 2009 | Western Digital Passport WDXML800UE...
My PC is not recognizing my WD Passport 120GB USB external drive. I used just few days ago and connected the usb cable to my computer and the WD Passport drive and not recognized on my 2 laptop and 2 other...
Oct 28, 2008 | Western Digital Passport WDXML800UE...
WD Passport appear as an unknown device
try it again, after going to wd dot com, and getting and installing a new set of drivers..
Oct 13, 2008 | Western Digital Computers & Internet
I have the 80GB WD passport and it suddenly stopped working one day.  The unit lights up but nothing else.  Finally I cracked the case open and found, as I suspected, that the drive is simply a SATA laptop drive with a SATA-to-USB conversion card built in.  I suspected that the card was **** so I disconnected it and used a USB hard drive adapter (http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=3770&name=USB_Hard_Drive_Adapter) and I can read/write to the drive just fine.  Best part is that the adapter I use has its own power supply so I'm not pulling juice through the USB cable for a SATA drive.
Even though mine "works" again I don't recommend these drives to anyone.  They're just not sturdy enough or well designed.
Sep 09, 2008 | Western Digital Passport WDXML800UE...
WD Passport not recognized anymore
Change your USB cable, I had same problem...changing the USB cable woked for me.
Jul 30, 2008 | Western Digital Passport WDXML800UE...
I had a similar problem with my WD passport 320GB. When I connected it to my laptop it never showed up on My Computer even though the blue light on the hard drive came on.
Here is what I did:  Right click on "My Computer" and click on "Manage" and then "Disk Management",. you should see your WD hard drive listed. then click on "change driver letters and paths"  and change it from the listed to another drive. I changed mine from G to F drive and it worked for me.
Jul 29, 2008 | Western Digital Passport WDXML800UE...
Western Digital Caviar WD2500BB 250 GB Hard Drive Logo
1,406 people viewed this question
Top Western Digital Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
