To change your region code you need to go to NANO options, then ID Storage tools, then Change region. It will give you 3 options: Europe' Japan, and America. Choose one. After that you will be prompted; "Do you want to continue?" Click "Yes" and you should be all set! Good luck!
CHANGE THE REGION TO FAKE REGION. THAN CHANGE CHANGE UR UMD READER TO SAY READ FROM MEMORY CARD FROM THE RECOVERY MODE IN THE CONFIGURATION MENUE. HOW TO GET TO THE CONF. MENU PRESS SELCT GO TO RESET THAN HOLD TH R TRIGGER TILL IT COME BACK ON CONF MENU IS THE SECOND ONE CHANGE USB LOAD TO READ FROM MEMORY
this trick might illegal on your country but almost website and social network already done it. NOTE! DO IT ON YOUR OWN RISK: 1st make sure if your using a custom firmware by pushing and Holding power button wait to shutdown your PSP and you will here some sound like tick! 2nd while your PSP is Shutdown Press and Hold R + Power until a recovery menu show up and GoTo Configuration you will see there you can change the region from what region you like then your done!
or
1st. try press and hold select while on PSP Menu where the games and music and setting and etc. is there 2nd. from doing that you'll open up the VSH MENU you can change the region there if there are nothing happen VSH MENU is not enable on the Recovery Menu try enable it.
or
if theres no recovery menu and VSH MENU?
try download Custom Firmware for your PSP or if you think you may brick your PSP try go to expert so they will do change region for you
well buddy u brought PSP frm Dubai and frm wer did u buy the Movie UMD.if its not frm Dubai it wont work.well there r other ways to work it out like change the Firm wire.all these changes wont assure that it show work.better buy UMD frm wer u brought the PSP
the other way round is to remove the Firmwire of Sony and Load the Firm wire of ND33.after u have dont this any UMD will work.
If your running custom firmware, change your driver from M33 to one of the others except normal. ISOFS may not work either. Also if your running custom firmware check your cold boot's configuration, it has a region faker built in there. If you haven't cracked the PSP you might need an official firmware update which I DO NOT recommend, instead look at getting your PSP custom firmwared.
If you have a custom firmwared PSP there is a hack that changes the region, put battery in and hold R (custom firmwared PSP), then configuration, fake region:
If you need help, feel free to E-Mail me: [email protected]
