Question about Xerox Phaser 8560DN Laser Printer
Xerox 8560 printer
My printer keeps jamming what could cause this?
  • apseo Aug 07, 2008
    my printer will print 2-3 sheets just fine then go on a spree of jams for no apparent reason with the paper always getting stuck in the front rollers behind the front cover. . . this happens from both the main paper tray as well as the manual feed tray.
  • 2,071 Answers
I have had the same problem for months and it drove me mad!
Today I found the solution!
It is true that the printer jams all the time because of its incapability to get a grip on the paper.
If you look over the paper tray inside the machine and you start printing, just before it jams you will see some sort of rotating device, trying to pick up the paper for transportation. This little piece seems to be the problem, because you will see that it is unable to lift the paper.
The problem is, that the surface of this part isn't rough enough.
It used to be, when you just bought it, but over a certain time it got too smooth.
Here is what I did;
I took out the paper tray, so that the rotating device was clear to work on.
With a little sharp knife I started to scrape and make little cuts on the surface too make it rough again. And guess what, it worked!
I have just printed thirty pages without problems, Yes!!!!!!
I guess that the problem will return when the surface of that rotating device gets too smooth again, but now you know what to do.
The worst thing is that in the end it feels even very logic.
Why didn't I think of this much sooner?
Anyway I hope this will work for you as well, any many others.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;..
Posted on Jul 30, 2008
Settings for Xerox Phaser 8560 to avoid Avery label jams
Don't use old labels as I think the glue tends to seep out from the edges and get trapped, either in the IBT belt or in the fuser.
Don't use none recommended as the temperature can also cause a problem with labels getting stuck inside.
Good Luck.
Jun 12, 2014 | Xerox Phaser 8560DN Laser Printer
Xerox 8560 error code 07,007.40
That error signifies a problem with the printhead tilt, you need to replace the Process motor camshaft pivot kit, part number 8560-Z2.
http://www.iteminconline.com/8560-z2_8560-z2-xerox-8560-process-motor-camshaft-kit.htm
Feb 07, 2014 | Xerox Phaser 8500/DN Printer
Xerox 8560 duplex paper jam
your machine should show where the paper is jammed. Open that compartment and pull the paper out.
Jul 15, 2013 | Xerox Phaser 8560MFP Laser Printer
Xerox phaser 8560 says "paper jam - open front
try cleaning the microswitches. it may also have a sensor and if the little plastic piece that crosses between them has broken off it will throw codes. mine is ok so i cant say for sure but you can try to glue a suitable piece in there to trick the printer if thats the case or bypass the sensor. just a few suggestions from my experience with electronics
sensor is kind of this: gap is where the plastic part is supposed to go in between.
Oct 12, 2011 | Xerox Phaser 8560MFP Laser Printer
Printer keeps jamming even when paper is removed, unable to print may be something to do with the paper guide because it is crooked.
I was having problems with slow copy start-up. I was going to move my 8560 upstairs because I couldn't get the wireless to work. After I got the printer broken down and tried io replace the wax tray, it wouldn't go all the way in. When I got a flashlight and looked inside, to my horror there was a piece of paper wnd gobs of wax which had been unable to be cleaned out. After manualy removing all this, my 8560 warmed up more quickly. I must remind you there was no indication of anyt jam. Hope this helps, RD Price
Jul 19, 2011 | Xerox Phaser 8560MFP Laser Printer
The printer goes through the start up process and then gives the code on phaser 8560
Xerox Phaser 8560: Error Code 09,037.45 That's a ink loader error, due to the 8200 ink stick; to fix it:
- Power down the printer.
- Hold the back button and the info button at the same time, without letting go, power up the printer.
- Keep holding down the buttons until the XEROX logo comes fully to the center of the screen, keep holding for 2 more seconds, then let go. I'll take about a minute or two for the Diagnostic screen to come up, the display will turn blank and black.
- When the Diagnostic screen comes up go to down to the Function or Exercise option, there will be an option that says "clear ISC faults" it'll ask you to press OK to confirm, after you do then you will exit Diagnostics and the printer will reboot.
It should be fine until it happens again. Until all the 8200 ink is gone you will probably be doing this a few more times. Also make sure the 8200 ink is not jammed inside the ink loader, if it is then you have to un-jam it some how hope this helps
Mar 16, 2011 | Computers & Internet
Xerox Phaser 8560 - error code 09 037 45 108564
Hi there
It should be fine until it happens again. Until all the 8200 ink is gone you will probably be doing this a few more times. Also make sure the 8200 ink is not jammed inside the ink loader, if it is then you have to un-jam it some how.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 30, 2009 | Xerox Phaser 8560DN Laser Printer
Xerox 8560 died after installing new maintenance kit.
The error is caused by the printhead not being able to tilt, the maintenance kit (oil roller) is driven round by the drum and has no physical connection to the tilt mechanism. Having said that I did once have a machine that had waste wax loose in the machine and when the customer replaced the maintenance kit the loose wax was pushed into the tilt drive gears which are located on the inside frame left hand side, right behind the oil roller. The wax jams the gears making a noise like a machine gun and tilt error 07,010 was the result.
Oct 21, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Apr 15, 2009 | Xerox Phaser 8500/DN Printer
Repeated paper jams
These errors are usually caused by a cracked DM Camshaft (Drum Maintenance). This was a very common problem for Xerox, they usually broke while under warranty, but there a heck of a lot out there that are just now going bad after a year.
You may or may not need to replace the "Motor Process Drive Gears" as well as the DM camshaft.
You might be able to talk Xerox into doing this as a warranty repair, if you ***** real loud.
Mar 12, 2009 | Xerox Phaser 8550DX Laser Printer
Xerox Phaser  8560DN Laser Printer Logo
446 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
