I have a pansonic dvd recorder model number DMR-E85H. For some reason the G code does not bring up the channel to record, all else appears to be fine it brings up the time and length of the program but cannot find the channel
  • 979 Answers
I need to know your source signal and whether a set-top box is being used.
Posted on Jul 31, 2008
Hi My Panasonic DMR-E85H Won't let me record to the Hard Drive it is displaying NO REC message on the Display ? Any ideas are most welcome .
it's the same problem with panasonic dmr-e55 recorder ; must we slack them for another one !!! we need help seriously
Jan 13, 2013 | Panasonic DMR-E85H DVD Recorder
How do you re-tune the panasonic DMR E85H DVD Recorder. I have done exactly as it says in the manual and still it does not find any channels? Is it digital?
The tuner in the DMR-58H is a NTSC tuner (analog). Unless you have a low power station in your area, you will need a digital-to-analog converter box to record OTA stations. It can record analog cable without a box as well. (Digital cable will require a box.)
The manual for the DMR-E85H is available from Panasonic here: http://service.us.panasonic.com/OPERMANPDF/DMRE85H.pdf .
I hope this helps.
(at least in my area there is only one station broadcasting an analog signal; it is a low-power transmitter and thus wasn't required to upgrade to digital with the rest of the stations.)
Mar 27, 2012 | Panasonic DMR-E85H DVD Recorder
Why won't dmr e85h pick up all the digital channels the tv attached to it will? Is it outdated technology? Do you need a digital set top box or completely replace the unit? Anyone...?
You most likely will need a set top box connected to this recorder in order to receive digital channels, Assuming the DVD recorder works besides this detail, you should not need to replace the unit. Only replace it if it DOESN'T work.
The DMR-E85H is a 2005 model so it is more than 5 years old.
Mar 13, 2011 | Panasonic DMR-E85H DVD Recorder
My Panasonic DMR-E85H DVD Recorder's hard drive has failed, can I replace it with one from the computer store?
yes thy are usually just common 2.5 standard drives.
dont exceed the storage capcity without checking the unit can address that value via its cmos.
Please rate my help ++++Thanks for using FIXYA
May 13, 2010 | Panasonic DMR-E85H DVD Recorder
My Panasonic DMR-EX85 is locked into region 2 Can you help to to make is Region Free please Thank you Roger
TRY DMR-E85 DVD Recorder Firmware Update
Version DL-106
  • Compatible Models DMR-E85HS
  • Issues Addressed Issues Addressed
    1. Corrects DVD Recorder hang-up or freezing during DVD playback caused by connection to Scientific Atlanta cable box model # 3250.
    2. Improves playability of discs with high reflection detected.
    3. Improves playability of discs with fingerprints.
    4. Improves disc playability corresponding to CPRM.
    5. Improves playability of DVD-RAM x16 discs
  • http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/Drivers-Downloads/model.DMR-E85HS.D#ts
    Oct 26, 2009 | Panasonic DMR-E85H DVD Recorder
    How do I connect DMR-E85H to a VHS to copy tapes? How do I 'finalize' the DVD when I'm finided recording (i.e.- how do I connct the lines to be ableto accomplish this/view the process)?
    I assume you are using a seperate vcr,you need to connect a scart lead into av1 on the vcr,then the other end into av2 on the dvd,you then select av2 as your recording channel on the dvd,to finalize if you go into the disc menu it will tell you what to do.
    Sep 29, 2009 | Panasonic DMR-E85H DVD Recorder
    PANASONIC DVD RECORDER DMR-E85HP
    Check caps on P/S C1270 and C1271 if puffy replace with {2} 1000uf 35vdc and you should be fine.
    Jan 12, 2009 | Panasonic DMR-E85H DVD Recorder
    Trouble with remote
    This happened to me twice before, I forgot the solution but it's in the owners manual, if you dont have it, go view it on pansonic's site.
    Oct 14, 2007 | Panasonic DMR-E85H DVD Recorder
    Televison & Video Logo
    57 people viewed this question
    Top Televison & Video Experts
