Question about Denon Audio Players & Recorders
Denon RCD-M35DAB has tuner drift on AM, tap side of unit on rear righht hand side then ok for a while.
  • 2,071 Answers
Loose connection or cold solder and cleaning problem this is the main caused of no sound..Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....
Good luck:
Regards,
VOTIT
DON'T FORGET TO RATE
Posted on Jul 30, 2008
Denon user manual model RCD-39
Try Googling (denon)(RCD-39)(manual) without parens.
Aug 28, 2017 | Denon Audio Players & Recorders
My denon rcd-m35dab, there is disc in and plays ok but cannot open the drawer it just shuts down/turns itself off
Check the belt or drive that is responsible for opening up the disk tray. If it is slipping the disk will not come out.
Mar 07, 2015 | Denon Audio Players & Recorders
No sound when i connect my denon-dp 29f turntable to denon rcd-m39 receiver. what might be the reason? Wrong receiver?
If your receiver ain't has a phono input and the tt has only a phono output, you'll need a phono to line line riaa amp , between the units.
Oct 26, 2013 | Denon DP-29F Turntable
My Denon Audio precision am fm DRa 435R Reciever will not stay on station very long. After about 30 or sometimes 45 minutes it get off station. I have it set to a local FM Station, 97.9 and it plays good...
OK,this is a fairly common problem with digital tuners, I get them from time to time in my shop, you see, what is happening is the voltage that's used to tune the set, usual;y stays rock solid, your device however is drifting off station due to this voltage changing, usually it is in the powers supply or the actual tuner itself. It can be bad capacitors, bad IC's, bad transistors, bad tuner module. Sometimes it maybe a "Dry Joint" too.
The only fix is either a replacement PSU or Tuner or indeed maybe both? One simply cannot tell exactly without examining the unit.
You need to take this unit into a Denon repair center and ask for a "Quote" as to costings etc. Once appraised of that one can proceed from there?
Contact a Denon head or local office and ask them there, for a referral to an authorised service center.
Jul 18, 2011 | Audio Players & Recorders
Hi can you tell me that impedence on JBL TLx4 speakers- i need to know if they are compatible with my denon RCD M37 dab player thanks
hi,
Is it JBL TLX 420 then its impedance is 4OHMS. You cant connect these speakers to denon rcd m 37, because its output impedence is 6 to 16 ohms.
ok
Jul 04, 2011 | JBL PSW-D110 Speaker
Tuner not working - denon AVR 3805
turn left hand knob to select tuner (round knob on top left front side)
Dec 31, 2008 | Denon AVR-3805 Receiver
Have a Denon 685 receiver. Purchased a Sony HD tuner (tuner only --$99). Hooked it up to phono input and it worked. After a while protection circuit clicked in. Used integrated tuner in unit. Worked longer...
if you disconnect speaker wire from rear and the problem is solved you will have a real problem in speaker wiring-you must fix it first or disconnect it from receiver and put new wires instead of.
Jul 16, 2008 | Denon Audio Players & Recorders
CD tray not opening on Denon RCD-M35DAB
there are tthere are two transparent plastic switches under the tray
there (a gray plastic piece, intcasing the loading motor is nonot rotated enough, not allowing the necessry pressure on the switch.
you must in either case disassemble the reading module comprising the tray, otics annd spindle, so you gain access to the underside of it, from ence coperatrepositioning the tray or the lrotating the trigger\eloading motor.
May 14, 2008 | Audio Players & Recorders
Audio Out from Samsung LE40F86BD
check your samsung owners manual for audio settings to see if this model has a audio time delay setting .
Feb 26, 2008 | Hitachi 51F510 51" Rear Projection...
182 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
