My LG front load washing machine makes a loud buzzing/vibration when I think it is trying to fill up with water. Prior to this problem water was leaking from underneath when the washing machine was filling up. It seems to spin ok and when I checked underneath the machine there was one small black hose that was not connected, but I could not find a spot whre it would connect to.
  • 833 Answers
Rick...this sounds like a problem with the fill valve or the water supply to it. The buzz should be a valve opening. I assume you have noted no kinked water hoses.
First, set the machine on either hot or cold water wash and try to fill the machine. Then do the other. That will tell you which of the two valves is not performing. Now that you know which one is malfunctioning, turn the water off at the spigot side and then remove the hose from the back of the machine for the non-functional feed. Turn on the spigot on to see if you are getting water flow. If not, check for a clogged filter washer on the spigot side. If so, do the same on the machine inlet valve side. If both are clean, replace the valve...it is jamming.
I don't know what the black hose you describe is. It may be an overflow drain.
Posted on Jul 31, 2008
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
My new LG front loader washing machine makes humming-buzzing noise when starting (only hot washing from 60C and above)
it is buzzing because it is try to let in hot water and is activating the hot water inlet valve/solenoid
Sep 06, 2015 | LG Washing Machines
LG WD1433RD Washing comes out with black lines and sometimes even worse Have cleaned rubber seal repeatedly Same problem for years every few washes
My LG Front Loader Washing Machine WD-1433RD having a leakage from Front when it fills the water up to ~70% of water. There is no leakage prior to that level. Please help me to fix this.
Feb 19, 2011 | LG WD14311RD Front Load Washer / Dryer
Whirlpool cabrio-buzzing noise when water runs
i think the problem that you have is one of the electric coils from the entrance valve from water. Check if there the vibration comes from there.
Oct 05, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Thor 806 washing machine buzzes, doesn't fill
Check the water supply. Possible problem with the solenoid on inlet. Or timer if old machine.
Sep 20, 2009 | Whirlpool WFW9200S Front Load Washer
WM3988HWA Error NO Water Source
CHECK THE WATER FILTERS AT THE BACK OF THE UNIT THEY ARE PROBABLY DUE FOR A CLEANING.
Feb 28, 2009 | LG WM3988HWA Front Load Washer / Dryer
Indesit WI 121 washing machine
If this is a front loader it could be the up/down motion causing machine to vibrate against the floor. You can pick up some cushion pads for front load washer and dryers at the dealers to go under the four corners of the machines.
Dec 29, 2007 | Washing Machines
Front loading wash machine
It sound like door lock unit is broken or removed from the door. Good luck !
Jun 17, 2007 | Kenmore 44042 Front Load Washer
Washing Machines Logo
147 people viewed this question
Top Washing Machines Experts
