Question about Microsoft Windows Vista Ultimate Edition
I'm Having problem with Vista, not detecting Pen Drive
Hello Sir,
I'm Currently Using vista ultimate. The problem is when i'm inserting any pendrive, my system got hang. This is the Second time i'm Dealing with this problem. The same thing happened earlier but it got solved by "System Restore" Tool. I had saved that Restore Point where my system was healthy. Now i did the same thing i.e Restored my system from Healthy Point of system Restore but resulting no effect, even i tried from other System Restore Point but no change in the system, still getting the same problem.
What would be causing the problem and what will be it's solution.
  • Romy  Decostza
    Romy Decostza Aug 04, 2008
    Actually it was the problem creating by Stopped COM Surrogate(dllhost.exe) in Data execution program.
    But thanx for suggesting
    Problem Solver:
  • 11 Answers
Unplug the pen drive before booting (newer laptops support booting from a USB drive, and they restore your "healthy restore point".
Format the Pen drive from Disk Management (right click on computer, choose manage, select Disk Management) to 32 bit fat, this leaves it compatible with Windows 98 SE, but the 16 Bit seems to give Vista fits. Good luck.
Posted on Jul 31, 2008
Hello Sir I have a 2gb kingstone pendrive when i insert in my pc and after i just open but there is a problem they want first formate and than open any folder when i formate my pendrive they erro was ...
your pendrive is infected with Autorun virus
to remove this virus install malwarebytes (It is a antimalware software )
scan your whole computer with your pendrive
when you remove the virus format your pendrive .
If the above method is not work
Try to format in other operating system
like in vista or in 7 but not in xp
Dec 17, 2009 | Pen Drive IVO MP3 Player
How to install vista from pendrive
Its very difficult to install windows vista if you are not having a DVD drive, Especially when you are planning to upgrade your windows xp system you would like to see how vista looks. So you need to install it and see. Requirements: USB pen drive 4GB or more
Windows vista DVD
Step 1: Download HP USB storage format tool from here and install on your computer.
Step 2: Once you finish installation, double click on HP USB storage format tool and format your pen drive in NTFS
For this, select NTFS from File system option and Check quick format option and click on start.
While doing the format the data stored on your Pen drive will be lost. You keep a back if needed. Press YES on the warning message
Once the format finished you will get a message with the details and Click
on OK
Now insert Windows vista DVD in to DVD Drive and go to command prompt.
For that go to start -> RUN and type CMD and press enter or OK
You will see the command prompt with black back ground
Now you need to change the directory to your DVD drive where you put the windows vista DVD.
For that type G: and press enter (here I am using G because in my system DVD drive letter is G. So you need to check your DVD drive letter and type accordingly)
So the directory will change to G:>
Now type cd boot and press enter
Now the interface will be like G:boot>
Then type bootsect.exe /nt60 h: (where h is the drive letter of your pen drive)
Now you will get a successful message like below
Now you can close the command prompt and copy all the contents from the windows vista DVD to the pen drive
It will start copying now
Once it’s finished, you need to restart your pc and access the bios of your system and make first boot device as USB pen drive.
That’s it, now you can see installation starts from the USB pen drive.
on Mar 02, 2010 | Microsoft Windows Vista Ultimate Edition
Transcent 8gb pendrive formatting problem
Try the drive on different machines. If you get the same error on all machines, you'll have to format the drive to reset the File system
Aug 14, 2009 | Electronics - Others
My 4GB pen drive is not formating...
Your pendrive is infected with Autorun.inf virus
to remove this virus install malwarebytes (It is antimalware software)and scan your whole computer as well as your pendrive when you scaning finish remove all threats
IF the above method is not work
Try to format in other operating system like windows vista or in windows 7 because in vista and 7 you can force format your pendrive
Jun 26, 2009 | RCA TH1101 MP3 Player
Dear sir, I am having Transcend 2 GB pendrive but when I insert it in my computer, it gives message THIS DEVICE CAN PERFORM FASTER IF U CONNNECT IT TO HIGH SPEED USB 2.0 PORT and its speed is also ver
If you have a USB port on the back of computer plug it in there. Or use USB extension if it is uneasy for you to plug your pen drive from time to time. From there you can hook up your pen drive much easy.
Apr 13, 2009 | Computers & Internet
Pen drive not detecting
If you have any other Computer with XP operating System. Connect the Drive. Check if detected then format the drive by checking full format on the menu.
Then connect it the Vista computer and Use it.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
Mar 12, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
How to format a pen drive?
Try HP formatting tool with administrator previliages in vista
Nov 29, 2008 | Kingston Technologies 512MB DataTraveler I...
Transcend pen drive 2GB not getting detected
Sir: Transcend pen drive 2GB not getting detected Can you suggest anything?
Feb 27, 2008 | Transcend (589307) Media
Problem detecting transcend pendrive
On opening my pen drive it displays "Pl insert a disk in drive G
Feb 16, 2008 | Transcend T.sonic 612 MP3 Player
Microsoft Windows Vista Ultimate Edition Logo
197 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
