Can't turn on my SONY PCG-6F1L
Can't turn it on even when connected to the electricity.
What could be the problem?
  • PyroPornStar Nov 28, 2008
    I have the same Problem, but i do get some lights, i get a power light and a battery light, and a Wi-FI light, and the cd-rom spins for a split second and will open. but no power to the screen or hard drive, no bios. all i get are the few lights.
Right this aint a solution but it works for me while u press the power button press a couple keys at same time. just keep doin it couple times and it will tern on i have the same problem and yes its a power short somewere on the motherboard
Posted on May 20, 2009
  • 51 Answers
When you plug the ac adaptor in to your laptop dous any lights come on the laptop if not it may be the motherboard because i have the same problem with my dell inspiron 1200
Posted on Jul 30, 2008
Hi i have a sony vaio pcg-505gx laptop and once i turn it on it ak me to press f1 to continue and then it takes me to ascreen that sayd invalid system disk replace the disk, and then press any key what...
windows cant find the operating system to boot from check that there are disks in usb cd/dvd or floppy if there is an external floppy drive if there is nothing in these drives
test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem
follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working hope this helps also it could be a dirty computer clean all of the dust from your computer you could use a vacuum cleaner but whatever you use make absolutely sure there is no moisture gets to anything in your computer
also check the Cmos battery and computer ram make sure they are securely seated
hope this helps
Jun 16, 2011 | Sony VAIO PCG-505 PCG-671L PCG-700...
Need to download all drivers for a Sony VAIO PCG-6F1L notebook with Windows XP Pro SP3 installed.
Cant find that model anywhere, the support page is here
If this is not your country just take another look at your model number and go to the sony vaio support site for your country.
Aug 20, 2010 | Computers & Internet
Sony pcg-6f1l lokking for Disassembly instructions, trying to repair power plug. Need to know how to get there.
sony do not give out service manuals. they will only tell you to send the computer for repair
Jan 30, 2010 | Sony Computers & Internet
How do I remove the hard drive on a Sony Vaio model PCG-6F1L laptop?
u need to remove it from the bottom of the notebook...u may need a diagram of the notebook for it...remove some screws and remove the cover etc...
Dec 25, 2009 | Computers & Internet
How do i replace the hard drive on a sony vaio pcg-6f1l
on the bottom of the laptop where the battery is there are different panels under one of those panels is the hard drive the panel will be about 10cm to 15 cm long.
Dec 24, 2009 | Sony Computers & Internet
I need drivers for the sonvy vaio PCG-6F1L!
That is because the actual Sony model is VGN-S360.or VGN-S360P You should be able to verify it. The model nember is not on the bottom it is on the RH LCD hinge. I do not think you can download the drivers anywhere but you can try:
or just buy aa set of recovery DVDs from Sony
If you have the VGN-S360:
If you have the VVGN-S360P then
Mar 22, 2009 | Sony Computers & Internet
I would like to replace the hard drive in my Vaio PCG-6F1L notebook and can not figure out how to open the case. there is one release I am missing. Bruce
Usually there is a side or a bottom part of the case where you can pop the hard drive out. My best advice is to refer to a manual or sony directly.
Jan 26, 2009 | Sony VAIO GRX550 Notebook
Sony vaio pcg 6F1L
Do you mean clean inside the LCD itself?? did it get water in it??
Not a fun thing to take apart an LCD and hard to reassemble as well. If you break the circuit boards while taking it apart you have to buy a new LCD.
Here is a good example of what replacing a backlight involves including disassembly pictures:
Dec 23, 2007 | Computers & Internet
Computers & Internet Logo
255 people viewed this question
David Payne
David Payne
