Question about Epson Stylus Photo R320 InkJet Printer
Epson R320 Hi there, The carriage belt on my Epson R320 has snapped - I want to replace - does anyone know where I can get a replacement belt? It looks like vene though its fiddly it would be fixable. Liza
  • Epson Master
  • 691 Answers
You are correct - it is fiddly. You should be able to get a part through an Epson Express center if there is one near you. Otherwise search the web for "Epson Parts Suppliers" and you should find one.
You can get a service manual for your machine from HERE to give instructions on how to get it apart and replace the belt properly. BE CAREFUL with the fitting behind the head carriage - it can easily break off if you are too heavy handed.
The belt for the R300, R200 series is the same as is some other models.
Posted on Sep 19, 2008
Lost my instruction book how do i change ink cartridges in Epson r320?
just press the ink button (with the drop symbol) once and the carriage will move to change ink position, you can now change the cartridge. when your done, just press the ink button once again.
Aug 15, 2010 | Epson Stylus Photo R320 InkJet Printer
I have a error on my epson cx6400 and don't
the best way to solve the problem is to replace the printheads or
Turn the printer on and pull the plug when it starts its initialization process. Can you move the carriage by hand at this point? If not, sounds like you may have a carriage motor\belt issue.
or clear the error message.
Thanks,
Nov 18, 2009 | Epson Stylus CX6400 All-In-One InkJet...
General Error Message
The "General error" message on the Epson R320 (as with most other Epson inkjets) can mean a whole host of things.
The most common ones are:
  • Printhead carriage blocked
    (something is blocking the printhead from moving left and/or right properly)
  • Cleaning/Parking pad area blocked
    (the printhead can't reach it's normal resting position)
  • Disconnected sensor
    (a ribbon cable has become disconnected or a sensor has failed so the printhead or paper location is not detectable)
  • Cartridge chip sensor issue
    (one or more of the cartridges has not been installed properly, has a "bad" chip or the sensor wires in the printhead carriage [where the cartridges sit] have been damaged)
If you can provide a bit more information on the error, possibly from the status monitor software that might give a bit more of a clue but hopefully the points above will give you a few places to look for possible causes.
Mar 15, 2009 | Epson Stylus Photo R320 InkJet Printer
I have the epson R200 and the ink carriage will not move across the printer anymore. You can manually move it back and forth freely.
Does anyone of you have a diagram that shows how to replace anEpson R320 Inkjet Printer Carriage Delivery Belt ? I have two of them. One has a belt broken and the other the black cartridge does not print (I have replaced it with a new cartridge and have cleaned the heads etc.) Any suggestions? If so, please email me at ril-2000@surewest.netThank you
Feb 28, 2009 | Epson Stylus Photo R200 InkJet Printer
R200 jammed carriage Grinding belt
Hi-
That's interesting... try to reseat the cartridges and make sure cartridge cover snaps when you close it. check for foreign objects inside the printer. You can check for parts if you need to replace one from a distributor, go to compassmicro.com
Hope this helps
Nov 08, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson R320 carriage jammed
The ink cartridge is probably not inserted correctly.  Unplug the printer and manually move the carriage to a location where you can take the ink cartridge out.
Remove it and reinsert it, making sure that it is fully located, before applying the power.
Make sure that there is nothing blocking the carriage movement, such as some remnant of paper.
Oct 21, 2008 | Epson Stylus Photo R220 InkJet Printer
Here is how to get the ink cartridges to move to the changing position on the R320.
1. Press the paper jam/ink button on the printer control panel.
2. A menu comes up. 1st item is ink cartridge replacement. Press
OK button.
3. Another menu with ink cartridge replacement. Press OK button.
4. Thats it, ink cartridges move to the changing position. Change your cartridge as you normally would and follow prompts on screen to finish process.
Hope this helps.
Aug 21, 2008 | Epson Stylus Photo R320 InkJet Printer
Turn off the power and look inside the machine to the right hand side. Just in front to f the print head you will see a white plastic dowel (see photo). Use something technical - like a finger, pen or screwdriver - to push this dowel in. You can then move the print head by hand to the middle of the carriage.
Once moved, turn the printer on and watch it travel back to the home position. If after returning home the dowel pops back out and does not retract itself, you will need to strip the machine out and rebuild the ASF section. Sounds hard but its just a few plastic parts to take apart and reassemble whilst looking to see if anything is broken.
Get a service manual; for the machine HERE if you need to strip it out.
Apr 01, 2008 | Epson Stylus Photo R320 InkJet Printer
Epson Stylus Photo R320 InkJet Printer Logo
288 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
