PHILIPS DVDR3460 Anyone had a problem not recieving a signal with this unit and no setup (welcome) screen/menu when first turned on?
  • jalil_louhin Aug 19, 2008
    Do not get signal with AV wires. also about finalizing DVD+r I followed user manual step by step on page 40 but still didn't work.
Mines the same,under warrenty,getting fixed,its been a month now, i had a samsung dvdr130 and it wasnt any good either.pos,any good dvd recorders thats reliable,and it actually does work,let me know, this thing also freezes on like the pause button was pressed, and then goes on playing,like its got a mind of own,and no tv signal,just another waste of hard earnt money gone.if yours under warranty take it back to the seller and let them deal with it,mine only worked three uses before it packed it in i want to get a new decent one,,,,,,,,,,,,any such thing available,,,, sorry i am not much help ,good luck,sounds like youll need it.. johnno.
Posted on Nov 15, 2008
Philips dvdr3460 - cannot open or close dvd reader tray.
The loader belt is either slipping or is broken. Sometimes you van find a rubber band from a newspaper will work as a quick fix.
Jul 28, 2017 | Televison & Video
Denon AVR 3806 Philips 42PFL3603D/F7 Compatibile
Make sure the control feature is disabled on both units so that they are not trying to send control signals to each other.
Secondly make sure your input is configured to hdmi for both audio and video within the receivers on screen menu The receiver usually auto senses the digital audio signal but doesn't automaticly know that it should use hdmi for video.
Dec 19, 2009 | Denon AVR-3806 Receiver
Philips 42PF9431d/37 behaving erratically
I would have the technician check out the key board assembly (button panel for lamen's terms). If not,then it could be a problem on the IR reciever board that is causing the small signal board to behave rather unusually. Tell him to check the ir board,there should be a surface mounted capacitor that will read shorted on a diode scale under the infra red diode. If that solves it,then it should cost you no more than 60$ reasonably. The logic board wouldn't have anything to do with the button changing.
I have also worked on a lot of this whole series of philips plasmas, and the control board is the least likely suspect from my experiences
Oct 16, 2009 | Philips 42PF9431D/37 TV
I can't turn off the SIM Lock
Hello, Please get the PUK code on your service provider,
Kind Regards, Jay
Oct 05, 2009 | Nokia 5310 Cellular Phone
Issues Displaying picture from HDMI upconversion
I've posted this other places. Hope it helps.
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
May 22, 2009 | Onkyo HT-S5100 Theater System
I have a DVDR3460 which needs to be zoned multi-region? how can I do this?
Access the menu of your DVD. It will give you the option to select the region.
Nov 09, 2008 | Philips Televison & Video
No Cable Picture
Call the cable co. If your getting the cable setup screen from the tv...Its getting that signal from the box...The tv is fine.
Sep 14, 2008 | Philips Magnavox 52MF437S/37 52 in. LCD TV
Cl034 magnavox remote versus samsung directv reciever
Go to http://www.urc.philips.com/. The Magnavox CL034 is under another name, US2-PM435, the Phillips version. Drop down menu to left of screen.Pick United States URC models. Then pick My remote is...US2-PM435. These codes really work and being the official samsung site they have many more than one recieves with the remote at time of purchase. Also note that the CL034 is the Magnavox remote (it does not have Phillips insignia)
Jul 25, 2008 | Philips Magnavox Learning Universal Remote
Recieving a fax
Try turning the ECM off. It belongs to the FAX SETUP menu and is explained in the user's manual.
Sep 04, 2007 | Samsung SCX-4216F All-In-One Laser Printer
Televison & Video Logo
90 people viewed this question
Top Televison & Video Experts
