No picture at all just lots of bright colours cant even display menu
  • jayko01 Jul 30, 2008
    I HAVE AN LG FLATRON PLASMA TV WITH XD ENGINE. IT'S LATE 2002 MODEL. I CANT GET ANY PICTURE AT ALL. THE PICTURE JUST WENT SUDDENLY. THE SCREEN IS JUST FULL OF BRIGHT COLOURS I CANT EVEN GET THE MENU UP YOU CANT SEE ANYTHING BUT LOTS OF BRIGHT COLOURED DOTS IT DOESNT MATTER WHAT CHANNEL YOU GO TO THE ONLY DIFFERENCE IS A WIDE LINE OF COLOURS GOING FROM THE TOP OF THE SCREEN TO THE BOTTOM
    ITS AN LG PLASMA MODEL NO:RT-42PX10
    Genius:
  • 1,665 Answers
Write model no to search if any service manual is available.
Check for any loose connections, bad electrollytic capacitor, cold solders at main board etc.
If you are not familiar with electronics troublshooting and repairs better take it to an authorized service station to check what causes the problem and if is cost efective to repair.
Posted on Jul 31, 2008
  • 4,234 Answers
Your system has an issue with the digital processing of the signals. Since you can not see the menu, says that the problem is after the "tuner" and character generator circuits and in the display logic. This can be caused by something as simple as a bad cable connection or something more involved like a pwer supply problem. Lets start with the relatively simple things first. Open up the back and reseat all of the connectors and cables. Since the signal levels are so low, it doesn't take much to corrupt the signal. Reseating all of the above will eliminate a connection problem. If that fails to resolve the problem, please update this and we'll start looking at a possible power supply problem.
For the record, there is no "vertical deflection" circuit per se nor is there a trimmer to adjust the brightness as would exist in standard TVs.
Dan
Posted on Jul 30, 2008
  • 813 Answers
U have set a trimmer from the ckt bord if its Short then brightness is out of control u need to call a professional tb repairer
  • sandip panchal
    sandip panchal Jul 31, 2008
    or tay to change the capcitor might be short
  • 2,071 Answers
The problelm is a defective vertical deflection system. Could be the amplifier, vertical output driver or whole printed board that supports the vertical deflection activity. It is considered to be a serious failure.
That is my opinion. Even though you could fix it and get another few months or even a year of use, it will surely develop another problem.
hope this may help;
Regards,
VOTIT
  • LORETO LACARON
    LORETO LACARON Jul 30, 2008
    LG plasma service trouble repair tips;
    42px10-no pictures replaced all 3 boards Y-sus,X-sus,Logic
    42px10 - lines on screen - two side board faulty TOP and BOTTOM whitch go to the screen(on the left side)
    hope this may help;
    Regards,
    VOTIT
  • LORETO LACARON
    LORETO LACARON Aug 22, 2008
    latest updates of problem threads...
    Genius:
  • 1,011 Answers
Sir,
It may be the failure of the Convergence IC's. Try to replace the IC's it will be fix.
Thanks
Good luck
    Master:
  • 382 Answers
Try to hard reset the Tv.."Unplugg the Tv for 2 or 4 hrs then replugg it" ..But the actual problem could be a overflow of Power which could have caused this !!...thank you!!...
    Genius:
  • 1,226 Answers
did you reset your computer by unplugging and replugging from the wall outlet?
if yes then same result maybe you can self tech you TV, however at your own risk. (warning high voltage) you can open your TV Circuit and then try to resolder all the connection using the soldering iron becuase some connection is lessen.
may this can help.
tell me more if what ever.
mlenavz
  • Emelio Navaja
    Emelio Navaja Jul 30, 2008
    PS:sorry the TV i mean not the computer.
  • Emelio Navaja
    my analysis is there is no busted parts inside but it only loss connection toward the soldered parts of the circuit board. or maybe its just an only TV tuner got fault.
    melnavz
  • 10,594 Answers
Can you let me know model number and make of your tv?
  • Shahid Electronics
    Shahid Electronics Aug 03, 2008
    Hi again,
    Thanks for intimation of model number. I can send you LG Plasma service manaul for information and in my opinion, you need to contact LG service center because your TV requires spacial Jigs n Tools to sort out the problem in its circuits or firmware, what ever. Its not case of wrong command of remote or can not be rectify by simple Volt-Meter. Its suphysticated TV and should be handel at concerns service center. Its friendly advise.
  • 6,487 Answers
What's the model and brand of this unit?
  • Mark Gil
    Mark Gil Jul 30, 2008
    This is very common. it is the power supply going bad, it should run at
    130 volts dc, but it is now running much lower that this just enough
    for the tv to come on. but not enough to power all the circuits right.
    Hope that helps.......
    Genius:
  • 1,847 Answers
Wht is the make and model no#?
How do I alter the colour, brightness, and contrast?
Go to menu, go to screen settings or display settings. Should bring up the sharpness, contrast, color, brightness controls. Follow directions on screen to adjust. Hope this helps!
Jan 29, 2016 | Televison & Video
Theres no brightness setting in menu. it only has cc sleeptimer and exit. how do i change the brightness?
Hello
You can adjust the brightness control on your 19PR19 Philips Tv. For that you have to go to picture contol menu
Do it as follows
To adjust your TVs picture control, select a channel and follow these steps.
[1] Press the Menu Button on the remote control to display onscreen menu.
[2] Press Cursor up or Cursor Down button until the word Brightness is hilighted. For each press of Cursor Up or Cursor Down button you can go through Colour, Picture, Sharpness, Tint, Colour temp etc, depending on the adjustment you want to make.
[3] Press Cursor right or Cursor Left buttons to increase or decrese the selected option. Ok.
Nov 17, 2010 | Philips 19PR19 19" TV
Some channels on my tv are dark and tinted orange, I used the menu button to display the menue and scrolled down to picture but I did not know how to select picture.
Hello
Adjust colour control to zero, and check for a pure black/white picture. Adjust contrast and brightness control to minimum and check whether the picture goes completly off or a slight picture prevails. If the picture goes out when you turn down brightness control to 1/3 position, that is about 20 points, your TVs screen voltage is very low, and it can be adjustable. If the picture does not go out and more brightness prevails, screen voltage is high. If the screen voltage is high, there will be some fine lines across the screen at about an inch apart; on the whole screen from top to bottom.
Screen voltage adjustment is critical for the clarity of the picture. If it is low, no proper colour will be dispayed. If it is high, it is harmful to both picture tube and your eyes.
Never try to adjust it without proper knowledge about it. The screen control can be located alongwith the LOT [Line Output Transformer], of your tv. There will have two adjustable controls there, one is for Focus, and the other is for Screen. Both are interactive, that is adjusting one will effect an other.
Oct 18, 2010 | Emerson TS2587D 25" TV
Adjust monitor
hi, most monitors have between 4 buttons or 8 to udjust picture. the 4 button MENU, PLUS, MINUS, OFF. when the menu button is pushed the screen will show a list of COLOUR, BRIGHTNESS, CONTRAST, etc,etc the plus is pressed to change the COLOUR, BRIGHTNESS, etc,etc. if you need to change the SCREEN setting BECAUSE THE ICONS ARE TOO BIG click on START go up list to CONTROL PANEL go to DISPLAY click on this and go to SETTINGS click on this and on the left. change to 1024 by 768 SCREEN SIZE (COLOUR 256). press APPLY wait press OK. gerry
Sep 10, 2010 | Envision EN 9110 19" Flat Panel LCD...
Acer model AT3201W no picture?? Sound is great, everything is connected tightly. Checked the manual ...no help..
There are several things that could be the problem, as usual. However I did manage to get a set working with the following characteristics:
- Set powered on ok and displayed the Acer logo fine.
- All of the inputs had very low brightness and poor colour.
- The backlight was working and appeared bright.
- The picture was barely usable with brightness/contrast set maximum.
I figured the issue here was a loss of the picture settings in the eeprom in the unit. So I set about to find how to get to the factory menu to set these things. This assumes you can get a menu to display on the set.
To enter factory mode on the remote control press menu/menu/234/menu. You will see the menu displayed with some info in the top bar that is normally not shown.
Then on the front of the TV press Volume- and Channel+ at the same time and hold until the factory menu appears.
You may see that the RGB gain and bias values are low or 0.
If that is the case set the colour temperature mode to Standard and then adjust the RGB gain and bias values to the following:
R gain: 434
G gain: 482
B gain: 484
R bias: 270
G bias: 270
B bias: 264
Then set the colour temperature to Cold and enter the following values:
R gain: 434
G gain: 482
B gain: 484
R bias: 270
G bias: 300
B bias: 310
Similarly, for Warm adjust the values to:
R gain: 434
G gain: 482
B gain: 484
R bias: 300
G bias: 280
B bias: 264
Then, if this was the problem, the picture should be fairly adequate.
Hope this works for you...
BTW I must give some credit here to another poster who provided a similar solution to a different problem here:
http://www.fixya.com/support/t154524-tv_losing_its_channel_memory
May 07, 2010 | Acer AL2671W 26 in. LCD Television
Samsung p1000 digital camera
Go into the menu and try to find an entry for "reset"...follow the on-screen instructions.
Feb 23, 2010 | Cameras
Cannot navigate Picture Mode (Colour) menu.
After some digging, I may have found something.
With no menus onscreen, press the menu button. Then press it again. According to a post I saw on another forum, that allowed the user to enter the tuning menus.
First press gets you "Overview" and the second opens the tuning menus.
Good luck, and repost the results.
Jan 09, 2010 | Televison & Video
I have an Acer 5534-1096, TOO BRIGHT
click on start
then control panel
then display icon
then select the settings tab and click advanced
then select the colour tab and you can adjust the settings in there
Dec 03, 2009 | Office Equipment & Supplies
Screen colour
You should be able to lower the brightness, using the slider below the resolution menu. For longer display and battery life, Apple recommends lowering the threshold. But, it should not be making the image distort or have any degradation to the image. If your machine is less than a year old ( and has no signs of user fault or P2P software ) you are eligible for complementary APPLECARE assistance. It makes no difference where you bought the computer. APPLE is international, and any APPLE STORE or 3rd PARTY APPLE AUTHORIZED REPAIR CENTER, should examine and troubleshoot this issue.
Keep me posted.
Dec 06, 2007 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Problem in lcd monitor
if its bright white colour without displayine even the menu then the problem lies with the lcd display.
Oct 26, 2006 | Sony Cyber-Shot DSC-S40 Digital Camera
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
