Question about Epson Stylus C46 InkJet Printer
I want to change ink cartridges but the cartridge holder will not go to the position
  • sreeradh p.r
    sreeradh p.r May 11, 2010
    hello friend
    which printer
    please provide correct model no
I want to chage my colour ink but the cartridge will not go into the center position hope you can help thanks a million
Posted on Nov 22, 2008
  • stewpot125 Nov 22, 2008
    sorry its a epson stylus c64
HOW TO CHANGE CATRIDGE
Purchase an ink cartridge made specifically for your printerTurn on your printer and raise the lid or press the cartridge changing button Wait for the cartridge carrier to slide out. Put your finger behind the ridge on the top front of the old cartridge and pull it toward you to remove. If you have an Epson printer, lift the cartridge holder lid, and the cartridge will pop up for removal. Carefully remove the tape from the ink opening on the bottom of new cartridge. Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been. Feel and hear the cartridge click into position. On some models, arrows will indicate the cartridge is correctly positioned. Close printer cover.If you have an Epson printer, close the cartridge holder lid and press the cleaning button to charge the cartridge.
Sep 06, 2011 | Computers & Internet
How to replace catridges for Epson Stylus Office T40W??
Good day. I hope this steps can help you in replacing your cartridges. This how i remember doing it. Just follow these steps.
>Make sure the power light is on, but not flashing.
>Open the printer cover and the output tray.
>Press the ink button. The ink cartridge holder moves to the ink cartridge check position and the
power light begins to flash.
>Press the ink button again. If more than one ink cartridge is expended or low, the ink cartridge holder moves to the mark.This
occurs each time you press the ink button until all expended or low ink cartridges have been
indicated. Once all of the expended or low ink cartridges have been indicated, the ink cartridge
holder
moves to the ink cartridge replacement position when you press the ink button. >Open the cartridge cover and place the ink cartridge into the cartridge holder with the bottom down.
Then push down the ink cartridge until it clicks into place. Then close the cartridge cover
>Press the ink button and then the printer moves the ink cartridge holder and begins charging the
ink delivery system
Hope this will help you a bit with your ink cartridge replacement problem. Have a great day.
May 22, 2011 | Epson Computers & Internet
Epson stylus sx200 refuses to acknowledge black ink bought direct from epson
I believe the DX series and the SX use the same system
# Determine which ink cartridges are not recognised.
# With the ink cartridge holder in the ink cartridge replacement position, lift up the ink cartridge holder lid and take the cartridge or cartridges out.
# Check that the cartridge is a genuine Epson ink cartridge - look for the EPSON branding and T0xxx codes on the cartridge labels.
# Check that the cartridges are correct for your Epson product.
# Wipe the green Intellidge Chip on the cartridge that is not recognised.
# Check the chip contacts within the ink cartridge holder for any debris or dried ink and wipe with a lint-free cloth if necessary.
# Check that the plastic at the bottom of the cartridge has been pierced.
# Check that the cartridges are in the correct slots.
# Reinstall the cartridges into the ink cartridge holder in the correct order.
# Push the ink cartridge down firmly. It should click into place.
# Repeat this for any ink cartridges that were removed.
# Push the ink cartridge holder lid down. It should clip into place and be secure.
# Press the Stop button, this will return the ink cartridge holder to the right hand side of the unit.
# If the error light flashes after the print head returns to the home position, the ink cartridge may not be installed properly.
# If the red light is no longer displayed, but Status Monitor still reports a Non-Genuine Ink warning.
# If the red light is still on the printer, and Status Monitor indicates that an ink cartridge is not recognised, follow the steps below.
# If the problem remains, there may be a fault with the ink cartridge.
Dec 30, 2010 | Epson Office Equipment & Supplies
How do I change the ink cartridges?
Step 1:Purchase an ink cartridge made specifically for your printer. Step 2:Turn on your printer and raise the lid or press the cartridge changing button. Step 3:Wait for the cartridge carrier to slide out. Step 4:Put your finger behind the ridge on the top front of the old cartridge and pull it toward you to remove. If you have an Epson printer, lift the cartridge holder lid, and the cartridge will pop up for removal. Step 5:Carefully remove the tape from the ink opening on the bottom of new cartridge. Step 6:Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been. Step 7:Feel and hear the cartridge click into position. On some models, arrows will indicate the cartridge is correctly positioned. Step 8:If you have an Epson printer, close the cartridge holder lid and press the cleaning button to charge the cartridge. Step 9:Close printer cover.
Jun 13, 2010 | Epson Stylus C86 InkJet Printer
HOW DO I CHANGE MY INK CARTRIDGE?
  1. Step 1 Purchase an ink cartridge made specifically for your printer.
  2. Step 2 Turn on your printer and raise the lid or press the cartridge changing button.
  3. Step 3 Wait for the cartridge carrier to slide out.
  4. Step 4 Put your finger behind the ridge on the top front of the old cartridge and pull it toward you to remove. If you have an Epsonmag-glass_10x10.gif printer, lift the cartridge holder lid, and the cartridge will pop up for removal.
  5. Step 5 Carefully remove the tape from the ink opening on the bottom of new cartridge.
  6. Step 6 Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been.
  7. Step 7 Feel and hear the cartridge click into position. On some models, arrows will indicate the cartridge is correctly positioned.
  8. Step 8 If you have an Epson printermag-glass_10x10.gif, close the cartridge holder lid and press the cleaning button to charge the cartridge.
  9. Step 9 Close printer cover.
Thanks
Apr 24, 2010 | Epson RX620 All-In-One InkJet Photo...
How do i change ink cartridge
While cartridge installation varies somewhat between brands and models, these general instructions apply to most major brands:
  • Step 2 Turn on your printer and raise the lid or press the cartridge changing button.
  • Step 3 Wait for the cartridge carrier to slide out.
  • Step 4 Put your finger behind the ridge on the top front of the old cartridge and pull it toward you to remove. If you have an Epson printer, lift the cartridge holder lid, and the cartridge will pop up for removal.
  • Step 5 Carefully remove the tape from the ink opening on the bottom of new cartridge.
  • Step 6 Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been.
  • Step 7 Feel and hear the cartridge click into position. On some models, arrows will indicate the cartridge is correctly positioned.
  • Step 8 If you have an Epson printer, close the cartridge holder lid and press the cleaning button to charge the cartridge.
  • Step 9 Close printer cover.
  • Apr 21, 2010 | Epson Stylus CX6000 All-In-One InkJet...
    How do u change the ink in the epson 6000?
    Things You'll Need:
    • Replacement cartridge (black, cyan, magenta, or yellow)
    1. Step 1 Turn on the printer and press the Color button.
    2. Step 2 Lift up the scanner and wait for the ink cartridge holder to move into position. Remove the ink cartridge holder's cover.
    3. Step 3 Push the tab at the back of the empty ink cartridge to free it from the cartridge holder. Lift the empty cartridge out and dispose of it.
    4. Step 4 Prepare the replacement cartridge by shaking it gently while still in its packaging. Remove the cartridge from its wrapper, taking care to hold it by the sides.
    5. Step 5 Insert the replacement cartridge into the appropriate slot of the ink cartridge holder. Push down on the replacement cartridge until it clicks into place.
    6. Step 6 Close the cartridge cover and lower the scanner until it clicks into place. The printer is now ready for operation
    Nov 15, 2009 | Epson Stylus CX6600 All-In-One InkJet...
    Change ink cartridge on epson stylus SX200 -printing head moves from side to side but then parks to the R and I cannot get access to change the cartridges.........
    The ink cartridges are all separate so you press the cancel button (with no jobs pending) to bring the cartridge holder in to the right place open the holder remove the cartridge and then replace it, let the printer purge the cartridge then your good to go
    Mar 24, 2009 | Epson Stylus Photo R320 InkJet Printer
    I need to change the ink cartridges on epson stylus sx200 but i need help as instruction book doesntreally tellyou how-thanks
    buy an ink cartridge made specifically for your printer. Turn on your printer and raise the lid or press the cartridge changing button. 3 Wait for the cartridge carrier to slide out. with an Epson printer, lift the cartridge holder lid, and the cartridge will pop up for removal. Carefully remove the tape from the ink opening on the bottom of new cartridge. Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been. 7 Feel and hear the cartridge click into position. On some models, arrows will indicate the cartridge is correctly positioned. with an Epson printer close the cartridge holder lid and press the cleaning button to charge the cartridge. Close printer cover.
    Dec 09, 2008 | Epson Stylus Multifunction Inkjet Printer/...
    Epson Stylus C46 InkJet Printer Logo
    224 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
