Question about Bosch Washing Machines
Machine is filling up but will not start washing cycle just makes a noise as if it is trying to start
  • allison1 Aug 04, 2008
    Thanx for all suggestions however FYI the brushes were needing replaced
  • 38 Answers
Give the agitator a twist with your hand and see if it starts to wash. If not, it could be a worn belt, broken couplin, stuck motor, or other mechanical problem.
Posted on Aug 01, 2008
    Scholar:
  • 165 Answers
What you are describing is the sound of the motor trying to turn. this is hardly a reason to replace a washer, especially is it is a newer model. i suggest you calla tech and have the washer tested.
Posted on Jul 31, 2008
    Scholar:
  • 111 Answers
My guess is the drive belt is off. Only a guess. Or, probably more likely, the clutch is shot. Clutch repair is expensive. Better just buy a new washer.
Washing machine won't wash when on large cycle
without stating the make and model it makes it harder for us to help you figure them out .front loaders are more prone to this type problem than top loaders .could be the gear box is going bad or a belt getting stretched
Oct 06, 2015 | Washing Machines
Machine filled with water. .but doesn't start to wash. .makes humming noise
Either the motor is bad or the fill sensor is bad? Try switching it to the spin cycle if it doesn't spin more and likely the motor is bad ?
Feb 21, 2015 | Washing Machines
Wash machine fills up starts cycle then stops it dont go to rinse then will start making a humming noise
it has bad cycle timemer switch in it replce with new one about 80.00 dollars
Dec 24, 2014 | Washing Machines
Smart drive 085
the buzzing noise is the pump trying to work, but it cannot due to a blockage. unplug the washer and you can lean the washer backwards and remove the pump to unblock. the fill error is probably unrelated, and is an inlet valve issue.
Sep 25, 2013 | Fisher and Paykel (IWL12)
My washer makes alound grindin noise wen trying to empty
1) most Noises coming from washing machines coming during the cycles of SPIN .Clothes load can be un-balance. Stop the machine and balance the clothes.Start again, and repeat the step if necessary.
God bless you
Jun 28, 2012 | Washing Machines
Howling noise on start-up
Hi just read your posting.Does the machine make the noise when it is filling?If so then try a cold fill and see if the noise happens and if there is no noise then try a hot fill to see if there is a noise.Please reply with additional information on whether the noise happens on the filling cycle or at another part of the cycle.
Jul 10, 2010 | Fisher and Paykel GWL11 Top Load Washer
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
GE washing machine does not run, gives humming noise
A washing machine is a simple product.
When trouble shooting anything you have to know what is supposed to do and what is it not doing.
At the begining of a washing machine cycle the machine fills with water until a switch is made telling the machine it is full and ready to agitate. Since it never fills it will stick in that part of the cycle.
When you start a cycle and no water enters the drum you have one of three problems:
1. The water supply is shut off.
2. The solenoid valve that supplies the water is not opening.
3. No power to the washing machine.
Since you are hearing a hum, the machine seems to be trying to activate that valve,
The humming noise comes from the electromagnetic field that activates the valve,
Dec 04, 2008 | Washing Machines
Washing machine makes buzzing noise
Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
Nov 06, 2008 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
