Question about HP Office Equipment & Supplies
I have an Hp C4200 all in one printer, I am printing successfully from my computer but when I try to photocopy the paper is coming out completely black. I went on to HP support which said it was due to the paper not being placed correctly in the machine, but I have checked this several times & also got my daughter to check it out, she says I am doing everything correctly. Can you help me ?. Thank you, Sylvia Watt.
I have the same problem, the photocopy part does not scan, only print. I can perfectly scan amd print trough Windows. just the Copy button does not work correctly. It does not matter if its plugged into the PC or not, it does not copy. any help???
Posted on Nov 15, 2009
  • 35 Answers
I need to know....
Are you copying from the adf(automatic document feeder) or the flat bed?
Is this a new problem?
Posted on Jul 31, 2008
  • charles gallagher Jul 31, 2008
    I need to know....
When I want to print something, if I go to file then print, it says offline, bot when I click on the C4200 series( copy 1) it will print BUT brints VERY small. Am I supposed to doing something...
  1. Click start --> Control panel --> Printer and faxes
  2. Right click on printer 'C4200 series' and select 'Set as default printer'.
  3. Right click again on the same printer icon and select 'Use printer Online'.
  4. Try Printing.
  5. You can delete the icon that says 'C4200 series(copy1)' if you are not using it.
Regards
Riztech
Oct 24, 2010 | HP Photosmart C4280 All-in-One InkJet...
Message shows "Paper jam" but there is no paper jam
try turning off the printer for about 10 sec. to clear its memory and turn it back on.. then print again
Oct 19, 2009 | HP Photosmart C4250 Multifunction Photo...
I can no longer print from my Mac to my HP Photosmart C4280. This happened after changing the ink. The following occurred when I tried to troubleshoot: Network Diagnostics was able to connect to the...
I can no longer print from my Mac to my HP Photosmart C4280. This happened after changing the ink. My HP icons are no longer in menu bar either. When I try to print the HP makes a loud noise and shoots the paper through at rocket speed with terrible print quatlity.
Aug 30, 2009 | HP Photosmart C4280 Aio Printer
Can not print and photocopy on panasonic dp-2330
Hello sir; Check the paper path where the paper stuck,there have a senser , may be come off or out of track, just put it back to right place.
May 15, 2009 | Panasonic WORKiO DP-2330 Copier
Lines rule across my print out paper at photocopying mode
Make sure you don't have a scratch on the glass of the scanner. If you have a mark, or scratch that matches the line ruled on your print, then there is your problem.
It;s also possible the scanner is jerking as it goes across the bed, which is causing the line. Is the line solid, dashed, bold, thin or just kinda there?
Mar 14, 2009 | HP DeskJet F380 All-In-One Printer
HPF300 will not copy paper comes out blank when printing from computer and also blank when photocopying
My printer shows is out pf paper and is not.. did everything I could do and even though the paper is still there the printer doesn't print and keeps showing its status as is out of paper.
Could you help, please.
Best wishes
Oivia
Dec 01, 2008 | HP Office Equipment & Supplies
I am trying to load my HP Photosmart C4200 printer/scanner and it does not come up as an option. What do I do? Karen
  1. FIRST TRY TO CANCEL ALL THE PENDING DOCUMENTS WHICH YOU HAVE GIVEN BEFORE THEN TRY TO PRINT IF THIS DOES NOT WORK THEN TRY OTHER OPTION GIVEN BELOW.
  2. CHANGE THE USB WIRE (THE CONNECTION BETWEEN PRINTER AND YOUR PC )IF IT IS TOO OLD.
  3. THERE MAY BE THE PROBLEM WITH USB DRIVERS IN UR PC .
  4. TO RECTIFY --- RIGHT CLICK THE MY COMPUTER ICON
  5. CLICK PROPERTIES AND THEN CLICK HARDWARE N GO TO DEVICE MANAGER
  6. UNINSTALL ALL USB PORTS AND THEN SCAN FOR HARD WARE CHANGES
  7. UR PC WILL DETECT UR PRINTER N ASK FOR PRINTER DRIVERS
  8. RELOAD DRIVERS N UR PC WILL COMMNICATE WITH UR PRINTER.
  9. FOR FURTHER ASSISTANCE FEEL FREE TO ASK AND WISH U SUCCESS -BYE
Jun 07, 2008 | HP Office Equipment & Supplies
HP photosmart C4200 successfully installed and prints only on white paper. Unable to print on conqurer paper.
What is the problem - does it feed the paper or just nothing comes out when the paper is fed through to print
May 08, 2008 | Office Equipment & Supplies
158 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
