Question about HP PSC 2110 Color Printer
Can't print power is on but all functions just seem not working at all
  • 4 Answers
Plz replace the logic board & check the printer.
Posted on Sep 04, 2008
Theck the printer status at the control panel. Confirm if the drivers really exist by checking its properties.. uninstall the printerb drivers and reistall again from scratch. Check for Diagonstic toools from hp.com
Posted on Aug 02, 2008
  • 87 Answers
Hello, friend
please remove all printer drivers in control panel
and reconnect printer cable
system will detect new hardware , install printer driver
systen not detect any hardware device please check printer cable
Posted on Aug 01, 2008
    Sergeant:
    Champion:
  • 246 Answers
Check the printer status under control panel
IF it is ok try to reinstall the printer driver
  • 28 Answers
Is this connected with a usb cable? did you try checking the printer status under control panel? try to download a HP Printing Diagnostic utility from hp.com.
Posted on Jul 31, 2008
My printer, HP 8500, has been trying to delete a document for hours with no apparent results. I am unable to print anything else although it does put a new document in queue. I do not get any error...
There are 2 simple methods to resolve any print job stuck in queue issue. However, both the methods will not fix printing issue if the HP Printer is in Error mode. Make sure your printer is able to print self test page to prove its functionality,
First method.
This Utility program resolve all the printing issue for HP Printers Only ( Network and USB connection )
This Utility will Resolve :
1. Check Connectivity between the Pc/laptop and HP Printer
2. Check if there any Documents stuck in Queue
3. Check if all the software/Drivers are correctly Installed
4. Check if the HP Printer icon is the default icon to print
5. Will Resolve Printer Spooler Issue and few more issue
Download the file on Desktop and Run the program ( Ex. File name = HPPDU.EXE )
Click Here to download the Utility and save on Desktop location
Run the HPPDU file and follow the instruction on screen to fix.
If this does not fix, try the 2nd Method given below ( this is manual process to clear the print job stuck in queue )
This works for all brands of printers ( HP, Canon, Epson, Brother etc )
Click Start > Programs > Accessories > then select Command prompt, then the black window will open and there type NET STOP SPOOLER and hit enter that will confirm service is stopped , after that on the black window type NET START SPOOLER and hit enter. Repeat this step 3-4 times and end the command with NET START SPOOLER and hit enter. Open the Printers folder and Refresh the Window ( Press F5 on the keyboard )
The service will be started and all print queue should already be remove.
// Above given solutions help in resolving print queue issue, however check the printer functionality if it is working fine ( the printer should be in working condition and should be able to print self test page, this utility cannot fix printer hardware issue //
Regards,
Ron
* Please rate this solution with Thumbs up and comment to help us improve providing support
Jul 02, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
On my Canon i950, when the printer starts to print the paper is sucked in by a rotating motor, but it seems like that motor is spinning too fast that it causes the paper to go sideways, crinkle, and jam....
Ok you can only try it could work
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i950)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 03, 2010 | Canon i950 InkJet Photo Printer
HP 7410 has power, screen is lit, but power button is not. None of the functions (print, copy, scan, etc. will work. Any ideas?
Seems like something a lot of us are experiencing. I have the exact same problem. Has anyone found a solution?
Dec 07, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Ink absorber is full and need to reset
found this at fixyourownprinter.com. Seems it works on most canon models and may work on your ip1800.
1) With the printer2_bing.gif power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s) according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.) [hth: I believe the power button has to be pressed once more after cycling the alarm button to complete the action. The power/resume-cancel button LEDs toggle to help you count.]
Time(s) LED indication Function Remarks
0 times Green (Power) Power off When the print head is not installed, the
carriage returns and locks in the home position capped.
1 time Orange (Alarm) Service test print See 3-4. Verification Items, (1) Service test print.
2 times Green (Power) EEPROM information print
See 3-4. Verification Items, (2) EEPROM information print.
3 times Orange (Alarm) EEPROM initialization [hth: does not re-initialize Waste ink counter]
>>>> 4 times Green (Power) Waste ink counter resetting
5 times Orange (Alarm) Destination settings [hth: not applicable]
6 times Green (Power) Print head deep cleaning (Cleaning of both black and color)
[hth: 7-10 not applicable]
11 to 13 times Orange, Green, Orange (Alarm, Power, Alarm) Return to the menu selection
14 not used in servicing
15 Orange (alarm) return to the menu selection,.
Note: If the Resume/Cancel button is pressed 16 or more times, the Alarm or Power LED lights steadily without
any changes.
Nov 27, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
How di I reset the ink counter on a canon mp620?
I found this at fixyourownprinter.com. Seems it works on most mp models and may work on your 620.
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
any changes.
Nov 08, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Date and time in prints
This function only works in "postcard" resolution. Press function button, and select postcard (1600 pixel width) resolution.
Jun 14, 2009 | Canon Cameras
My canon i950 waste ink absorber is almost full
1. Start with the printer OFF
2. Hold down RESUME and then hold down POWER
3. release RESUME
4. press RESUME twice, then release POWER
5. Let green light blink until printer is done moving print head.
6. Select functions below with RESUME press POWER to execute:
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
Mar 17, 2009 | Canon i950 InkJet Photo Printer
Print Screen Button not working
Yes, there is a button, up by the function buttons, that says "print screen". I've tried pressing just that button; pressing that button and the alt button together; and pressing the "Mode F" button and the print screen button together, but nothing seems to work
Jul 23, 2008 | Logitech LX 300 Keyboard/Mouse
My printer hp photosmart c4180 all in one doesnt print properly, every time i swich it on it says the cable printer connected to this computer has malfunction than when i change the cable to another usb...
my printer hp psc 2355 all in one doesnt function at all even it is plugged. i checked the plug it has power saw light but when i put the power on for the printer to start its not working what seems to be the problem. been using this for 4 years never had problem with it just it snot having its own power even if **** plugged properly.
Jul 12, 2008 | HP PSC Photosmart 2355 All-in-One Printer
Printer won't print
If the ink is too low the head cleaning won't work. Also, I have had to do the cleaning functions several times for it to work. Will it print a test page? Look in to reinstalling a print driver.
Oct 29, 2006 | Epson Stylus CX6400 All-In-One InkJet...
HP PSC 2110 Color Printer Logo
65 people viewed this question
Ben Johnson
