Kenmore Washing Machine Timer Out of Sync
Our Kenmore washer has had an intermittent problem with the timer dial stopping right before the rinse cycle. I would go to check the laundry and the tub would be full of water and it would essentially be "hung up" right before the drain and rinse. All I had to do to get it to move on was tap on the dial and it would start up again. I told my husband about this and he decided to take apart the timer assembly. Now, he can't seem to get it back together correctly. He thought he had it, but when he put it all back together and we went to run a test load, the washer would start filling, spinning or whatever, without even pulling out the timer knob. It was like the knob was already pulled out to start the load. When you pulled the knob out nothing different occurred. So, he took it apart a second time and now our washer is all CRAZY. Its apparent that the timer is not in sync any longer. The cycles aren't right, the speed (agitate/spin) is always Fast even when selected aas Slow and the temperature will only run Cold water no matter what selection is made. Now my washer is unusable. Also when you are running a cycle now, after a couple of minutes it gets to a point where the washer makes a thumping sound over and over (still agitating). When it made this sound, it made our laundry room lights go bright/dim bright/dim. I freaked out and stopped it. Is there any instruction or documentation you could provide to assist him? He's frustrated, I am frustrated and I need to do laundry... I am prepared to order a new timer assembly. Is there only one way to install the new timer, or will it be out of sync again?
Thanks!
Lora Bowen
  • 1 more comment
  • bowens1998 Jul 30, 2008
    The answer I received was not in the correct post.
    Is there only one way to install a new timer? Once it is installed will it be in sync with the dial?
  • bowens1998 Jul 31, 2008
    Well after a bit of searching, I found the timer! I wanted to find it somewhere locally, so it could be fixed today. Installed the new timer and voila... problem solved!
    Thanks so much...
    Top Expert:
  • Washing Mach... Master
  • 77,169 Answers
The timer is a electrical mechanical device, the problem you are having is what they do when they fail, replace the timer and all should be well, parts for washing machines are fairly cheap, go to a sears service center (not always at the main store) armed with the model number, it is on a sticker on the back of the washer. Make sure it is unplugged from wall before attempting any repairs.
Posted on Jul 30, 2008
    Sergeant:
  • 260 Answers
You definitely need to replace the timer assembly. It should fix your problem. I suspect the problems you have had are not your husbands fault, but rather trying to repair a bad timer. If you purchase the new timer, assembly should be pretty straightforward and I feel confident your husband can handle the job.
  • 1 more comment
  • Ken Jones
    Ken Jones Jul 30, 2008
    Yes, if you follow the directions that come with the timer.
  • Ken Jones
    But it is still possible to mess up the installation.
  • Ken Jones
    Ken Jones Jul 31, 2008
    Good to hear! Thanks for using our service.
    CH
  • 10,594 Answers
Here is an option, use "Hammer" and fix the rest of camera.
  • Shahid Electronics
    Shahid Electronics Jul 30, 2008
    Sorry, its correct message but in wrong post window...again sorry.
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Kenmore washer - water won't drain. It stops
    If the water drains between the wash and rinse cycles, your motor and pump are probably OK. If this is a machine with a dial, try a different cycle, like normal instead of heavy duty. If that works and the machine completes the entire cycle then the timer probably has a bad spot. You might try to find a replacement timer if that is the case although I didn't have any luck with my 10 year old washing machine. Best of luck
    Mar 20, 2010 | Washing Machines
    Kenmore 300 washing machine does not leave rinse cycle
    This sounds like a bad timer. If the machine is several years old, the timer could be in need of replacement.
    If you are handy, you can replace this device yourself and you should be able to obtain the part from any local Sears parts store or from the internet.
    If you are not familiar with this kind of work, it would be best to have a technician replace the timer.
    Jan 05, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
    Model 110 stops with water in machine. Move dial to rinsing cycle. Runs some then stops with water in machine.
    HI. The timer module will be the culprit here. The timer motor is malfunctioning. This motor is responsible for the forward motion of the timer dial. If it dose not function correctly, it will cause the issues that you are experiencing. kindly replace this damaged timer control device. Once replaced, the unit will operate properly.
    Nov 27, 2009 | Kenmore Washing Machines
    Kenmore washing machine will not drain
    Replace the timer.
    This is a neutral drain machine. If there is no natural pause in the timer at the end of the rinse cycle the timer is bad.
    Mar 13, 2009 | Kenmore Washing Machines
    Kenmore Elite Washer
    seems the timer knob is old and need of replacement normally happens due to age as the timer switches inside the timer knob become old and sticky mostly unable to move so the timer isnt able to do much of its job
    Apr 17, 2017 | Kenmore Washing Machines
    Kenmore Washer timer dial is not advancing
    ok " timer has a small stepper motor in it, and it can be replaced
    take stepper motor out .
    appliance parts store will have it
    or just replace timer
    take make and model number with you
    Jan 13, 2008 | Washing Machines
    Machine doesn't spin/rinse/drain
    not sure why, but the timer is lacking supply power during this event. look on back of timer for power connections to the motor. now monitor the 2 terminals for supply with a voltmeter to be sure. usually a schematic is taped to inside of machine so you can trace where that supply is on it.
    Nov 20, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
    Asko w6221 front load washer stops after wash cycle
    Do all of your cycles work when you turn them manually? If one cycle does not work when you turn the dial on it then it will be your timer (The dial assembly $100-up) If all your cycles work manually, then it could be your timer motor which is attached to your timer assembly. If you turn the dial pass the wash, on to the rinse, does the dial automaticly move (when finishng the rinse cycle)to the spin cycle? If so then your timer motor is ok. The only wires close to the bottom are the motor, but these should be high enough out of the way.
    Apr 01, 2007 | Asko W6221 Front Load Washer
    Washing Machines Logo
    659 people viewed this question
    Top Washing Machines Experts
