Question about Toshiba MK8025GAS 80 GB Hard Drive
HDD NOT RESPONDING
Sir,
My 80gb HDD was working ok a month back when last used but today when tried to use,the power led is ok and the other led lights for a sec after some time, also my computer some times show sthe hdd detected but cannot access the hdd.Can u please tell me what should be the problem.
Thanks.
  • Anonymous Aug 26, 2008
    same
  • 94 Answers
Open the tower and try reseating the cables.... and remove any usb devices(pen drive or flash drive) and try booting the computer... if not we'll try with few other things...
Posted on Sep 11, 2008
Sir, Iam using the ZED-10FX Allen & Heath mixer. Iam not getting the 48V phanthom power and AUX out from the mixer both Green and RED LED on Phanthom power is not glowing. Iam getting the LED VU m
sOMEHOW YOU BLEW THE 48 v PHANTOM SUPPLY.
Open it up and check power board voltages.
Replace regulator circuit and check for shorts on your mic cables.
PEACE---
Feb 09, 2015 | Allen & Heath ZED-10FX Sound Mixer
No power
Check if the power supply u bought is working properly. I its working then check your systems motherboard, whether the led is blinking on board or not...
Dec 20, 2013 | eMachines W3118 AMD Sempron 3100+ 1.8GHz /...
AC power light blinks but not starts
The outside unit has a problem. Have it tested.
May 05, 2017 | Hitachi Heating & Cooling
I have a 250gb seagate sata but when i put my 80gb IDE hdd it only detects in booting and in bios but after that if i open my computer i cant see my 80gb IDE Hdd and even in device manager my hard disk was...
there was wrong in the set up of jumper in your 80gb hdd. Look closely to the 80gb harddrive, in between the ide cable terminal and the power supply connector you will see 8pin terminals paired together and a jumper use to short the paired terminals. It is most likely that the jumper was configure to detect your hdd as master. If the ide cable you use for the 80gb hdd was also use for the dvd/cdrom drive then it will conflict with it if both jumper setting was set to master. See the description of jumper settings in the sticker of the hdd. Position the jumper to slave.
Reboot your system again and see if the 80gb finally appear in your system. When system boot upon detection of hdd, the primary master should be 250gb while your primary/secondary slave will be read your 80gb hard disk.
Jan 24, 2011 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
Hdd power problem
Hi!
Check your HDD with HDD monitor utility to see if it's ok. You can try this one:
http://www.techsupportalert.com/best-free-disk-health-monitoring-utility.htm
If your HDD has bad SMART or power controller or smth like that - then you definitely need to replace HDD.
Also issue may be caused by your PC power supply or motherboard power controller. If HDD monitor shows that your hard drive is "alive", then try to "hang" your HDD to another power cord from your PC power supply and try to connect to other IDE/SATA port on your motherboard.
Also I'd suggest you to try your HDD on any other PC.
Jul 02, 2010 | Seagate (9W2892-337) 80 GB Hard Drive
Samsung 22inch lcd monitor goes blank after 1min idle system.
Hello sir, I have samsung 22in lcd monitor and nvidea fx5500 card. since last more than 6 months, my monitor goes blank If system remains idle (means I don't move mouse and don't touch keyboard) for 1 minute. After monitor goes blank I have to move mouse to brink it back to on. The power led keep on during this problem. I tried everything including power options in windows but could not fix it. Is it bios setting to be checked or could it be windows bug? Please help
Mar 23, 2010 | Acer X193W LCD Monitor
Frequent hard disk failure
check your hard disk cable first and replace it.if this isn' stopin your problem then make a new bios flash. may be ypur bios is reporting your hdd wrong so make a new one. if even after this you can not stoping your problem bay another mb.
Apr 05, 2009 | Intel D945GNT Motherboard
Computer shutsdown completely when i insert my 80gb seagate barracuda 7200 HDD
What operating system are you using some can only recognize up to 10GB
and is the 80GB fitted correctly
stripe on cable to No1 pin on M/board socket and toward the 4 pin power socket on hard drive
Oct 27, 2008 | AMD ASUS A7V8X-MX ALL IN ONE MOTHER BOARD...
HDD PROBLEM
Raj...
A few questions..
Is it external/internal drive
what kind of data connector does it have... USB, Wide ribbon cable or 6 pin sata
Has this drivbe got windows or linux on it, or is it just used for data.
Jul 30, 2008 | Toshiba MK8025GAS 80 GB Hard Drive
'Library Full' Error when transferring files to Zen.
the zen uses other areas for data storage and stuff.
best to reformat and not use so many folders.
Oct 21, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Toshiba MK8025GAS 80 GB Hard Drive Logo
368 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
