Question about Xerox Office Equipment & Supplies
I have an old XErox DC4 LP printer Error code: Service call J5 Then it says cycle power U6-4 How do I resolve these issues Thanks Patrick copymasters114@hotmail.com
    New Friend:
I have riso ks 800 showing error code j5
Posted on Dec 21, 2013
  • 57 Answers
Check your paper tray you may be low on paper or check on your pick-up roller. It could be that this roller is not picking up the paper on time. It may be skipping the paper.
2) check your toner lever.
You have a very old model. This error j5 could means different thing in different model. Let me direct you to this website it might help.
Thanks
Good luck
http://www.office.xerox.com/support/dctips/dc05cc0358.pdf
Posted on Aug 03, 2008
Xerox Phaser 8860 error 09,005.40:71198
Want to resolve your printer issues online then, dial Xerox Printer Support Phone Number1877-778-8@9@6@9 anytime as you like. For further Info Click:https://goo.gl/Co2Bom
Oct 30, 2014 | Xerox Phaser® 8860/8860MFP Extended...
Xerox Phaser 7760 shows the error 004-350, what can I do?
You can find answers to your Xerox questions at www.xerox.com/support .
Solution : Power Off the Printer, Wait 45 Seconds, Then Power On the Printer Some problems can be resolved by powering the printer OFF and ON.
WARNING: Only use the power switch on the printer to power the printer OFF and ON. Damage may occur to the printer if power is interrupted by other means.
CAUTION: When cycling power on the printer, any incomplete jobs in the queue will be lost and will have to be resent.
  1. Power OFF the printer using the power switch located on the top, right side of the Control Panel.
  2. Wait approximately 45 seconds, then power ON the printer.
Oct 23, 2013 | Xerox Phaser Office Equipment & Supplies
What is the Xerox Phaser 8400 printer error code 07.010.43:43923? Much appreciated. Thank you.
Try this:
The printer has encountered an error state without the benefit of a code. Turn the printer off for 30 seconds, then power back on.
If the Printer Error message returns, press the i button on the printer's front panel. The actual error or fault number should be displayed. Note the error or message and search the knowledge base for the error.
Also:
Based on the problem description provided, we have determined that your printer needs service.
Please turn your printer off and use one of the methods below to make arrangements for service:
If using the local service provider website, please perform the following steps:
  1. Enter your zip code in the space provided.
  2. Choose a mileage distance. The search will locate a Service Provider within the specified range if available.
  3. Click Go. The web site will return a list of Authorized Service Providers (ASP) with their company name, address, phone number, and fax number.
Feb 12, 2011 | Xerox Phaser 8400 Laser Printer
Xerox WorkCentre C2424: turned on, runs thru tests, initializing and then shuts off and starts the cycle again. The cycle continues but never resolves.
1. Power machine off and wait until completely off. 2. unplug power cord from wall. 3. with power cord STILL DISCONNECTED turn machine on and off again. 4. WAIT 60 SECONDS 5. plug power cord back in and turn back on
If this does not resolve the issue call for service.
Hope it helps!
Feb 09, 2011 | Xerox C2424 Copier
Error code 117-363 printer starts machine is awake
only see error code 117-363 and not permited other option
Nov 26, 2009 | Xerox 6180MFP/N Printer
Xerox phaser 6265 displays engine service 8300
From the service manual:
Code 83: Engine NVRAM is corrupted or receiving wrong data from a CRUM.
1 Cycle power to the printer. Does the error still appear? If so, go to step 2.
2 Remove and reinstall the Imaging Unit and Fuser Assembly. Does the error recur
after the power has been turned off and then on? If so, go to step 3.
3 Replace the imaging unit. Does the error still occur? If so, go to step 4.
4 Replace the fuser assembly. Does the error still occur? If so, to to step 5
5 Replace the EEPROM board. Does the error still occur? If so, replace the Engine Control Board.
Jun 23, 2009 | Xerox Phaser 6250 Laser Printer
Docucolor 252 fault code 047-310 How do you fix this?
This error code indicates that the Xerox is not communicating with the finisher. The recommended method to resolve this is to power off the Xerox, wait 3 minutes after power is off, unplug the machine from the wall, wait 1 more minute and plug in and restart. If that does not help, it will require a call to the service number: 800-821-2797
Jun 08, 2009 | Xerox DocuColor 12 Color Copier
Xerox 8400 error code 37,063.45
Vpp measurement too low.
The printhead power cable may be disconnected.
Xerox All error booklet download LINK
Please rate as Thankyou
Dec 26, 2007 | Xerox Phaser 8400DP Thermal Printer
Xerox phaser 6250 NVRAM Failure
Cycle power, try cleaning the CTD (ADC) sensor and toner full sensor. This is what Xerox has to say about the NVRAM failure: On the front panel, press the key labeled i to view information about the error. Record the error code number. Turn off the printer. Reseat the fuser. Reseat the imaging unit. Reseat the toner cartridges. Turn on the printer. If the error continues to be displayed contact service. To be on the safe side you can follow the instructions here on the procedure to replace the transfer roler: http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi Good luck
Mar 25, 2006 | Xerox Phaser 6250DP Laser Printer
206 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
