Question about HP Office Equipment & Supplies
Cartrigde slides half way paper does not start.on light flash off and on
    Sergeant:
  • 390 Answers
You may have a paper jam, open unit and check inside near rollers and cartridge areas. cheers lilacgerry
Posted on Jul 31, 2008
When press print, the status light flashing orange. It print for a while then the paper light flash yellow, then it stop. The printer print up to half a page the it stop. Check printer and turn printer...
the flashing amber status light is normal indicating data going from computer to printer.the flashing paper light indicates a paper jam or out of paper. A sensor maybe not working properly or sticking. If your model number ends in a D check
Jul 16, 2014 | Brother HL 5140 Laser Printer
Error p1500
The printers first error code show all lights flashing:
Flashing Ready'Data
Flashing Toner Low
Flashing Load'Remove Paper
Flashing Paper Jam
Flashing Error
Flashing Press Continue
By pressing continue twice to get to second error codes the lights show:
Flashing Ready'Data
Off Toner Low
Flashing Paper Jam
Flashing Error
Pressing continue twice more shows:
Off Ready'Data
Flashing Toner Low
Off Load'Remove Paper
Off Paper Jam
Off Error
Off Press Continue
Pressing continue twice more brings back to all lights flashing
The computers ( I have tired more than one with diff USB and A parallel cables) do not see the printer as being attached. My toner is half full. I checked the internal power board in base of printer and the fuse is good. The error should not have anything to do with being connected to a computer or not because when it was working and not connect to a computer it would not blink all the indicator lights (If I remember correctly, just the Press Continue light would be lite).
Information I have found so far:
  1. http://support.dell.com/support/edocs/systems/p1500/en/index.htm#online_documentation
o Under PDF Documents Owner's Manual(English) (.pdf) (1.33 MB) shows very little about the indicator lights.
o Under HTML Documents User's Guide shows more information about the indicator lights but mentions nothing about the secondary error codes.
  1. The Lexmark E321/E323/E220 are very close cousins to the P1500 and on Lexmark's website the manuals have more info on secondary codes but nothing that matches my error.
Information I am guessing could be the problem:
  1. The fuser has gone out (need to know how to check) Why else would they sell the fuser if it didn't go out regularly Part Number: 56P1053
  2. Clutch Assembly I'm not sure of the accuracy of the info on this page.
Mar 12, 2014 | Canon Office Equipment & Supplies
We have Epson ink jet printer. It worked fine when we got it last month but now the pictures are really awful - the colors are blurring and running together and there are recurring horizontal streaks...
Maybe the ink cartrigde is running out. Get sure that the cartrigde has enough ink, if it has not then reload it. If it has enough ink, then review that the printhead be clean, (you could clean it by using Isopropyl alcohol), then you can use the tools included in printer software to align or maintain cartrigdes. If this does not fix the problem, then replace the cartrigde.
Apr 20, 2010 | Epson Office Equipment & Supplies
Printer Frozen with Resume Light On
The following steps to be done:
01. Please switch of the Printer and Desktop / Laptop.
02. Remove Both catridges 96 and 97 carefully.
03. Load 215.5x 279.4 mm (8.5 x 11.5 inch) paper in the Printer after switching on both printer and the machine.
04. Raise the Out Tray.
05. Slide the paper grade all the way to the left.
06. Place the paper in the tray, pushing the paper into the printer and check the Resume Light is flashing.
07 Place the paper in the In tray, pushing the paper into the printer until you get the flashing.
08. Slide the paper guide firmly against the edge of the paper stack.
09.Lower the Out tray.
Regards
Jul 26, 2009 | HP Deskjet 6940 InkJet Printer
Lights flashing, printer won't print as a result of a paper jam
Hi Girlemom. Just had the same problem here. Lift up the lid and slide the ink cartridges to the left. If they are stuck in the middle, this will prevent the printer from starting properly. Then, unplug it, plug back in, and turn on. It should restart normally.
May 08, 2009 | HP DeskJet 5550 InkJet Printer
HP Deskjet 1220c won't print
This is a problem with the carriage. Unplug the printer from the wall and the computer wait half an hour and then plug it back in and see if you have the same problem please post the results.
Mar 02, 2009 | HP DeskJet 1220c InkJet Printer
Not receiving faxes
Folio is not what you want. The usual is letter (LTR) or 8.5 x 11. You may have to check the settings to set the default paper size.
Jan 14, 2009 | Canon PC-1080F Plain Paper Laser Fax
Ink cartrigde
Did you remove the protective blue tape from the cartridge bottom, if please clean the cartridge Take a warm, damp paper towel or napkin and gently clean the bottom of the car where ink comes repeat the same process with dry paper towel and try to print , if you still have the problem you can contact lexmark and get the cart replaced with a new one as the cart comes with 6 months warranty.......
Jun 30, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Cannon copier pc940 paper jam
canon i960 -three flashing orange lights (paper jam error) but no paper is jammed. The print cartridge1.gif will not slide to center either-- I have tried to get the printer into service mode, but cannot get there because the orange lights never stop flashing.
Dec 06, 2007 | Cannon Canon i960 Photo Printer
Paper jams
It has nothing to do with cartrigdes. You have an undetected paper jam. You need a pair of tweezers and a torch and need to play lets find the nasty small hard to see bit of paper or ujo (unidentified jamming object) i had a piece of toddler toy cardboard so small once i had to remove it from my roller with a pair of tweezers so don't laugh at me!!! Good luck. Make sure you look everywhere, including inside unit, and down the back where paper goes too. Cheers.
Aug 30, 2007 | Lexmark PrinTrio X75 Printer
Ben Johnson
