my camera an olympus stylus 700 all-weather 7.1 megapixel, isn't turning on. When the on button is pressed the zoom comes out/in/out making a grinding sound, the screen shows a none focused image until a bright blue screen is displayed with D: 5eO2
did you happen to drop it in sand or on a hard surface. by the description of the problem it shows that the movement of the lense assembly is not proper.i.e. it is having friction in the movement.Needs to get it repaired.
If the camera is still under warranty then return it. If it is out of warranty then replace it There is not a likely repair option Though Olympus Customer support may advise another remedy
I have a camara that has a problem.The problem is that when I take a picture (with the flash or...
(More)
I have a camara that has a problem.The problem is that when I take a picture (with the flash or not)the pictures appear with lines on the LCD view.This is the second camara with the EXACT SAME PROBLEM.I would like to know why this has been happening and what I can do to fix this camara.\r\nThank you very much.
getting lense error 306. lense tries to come out and then sticks causing the camera to shut down. If...
(More)
getting lense error 306. lense tries to come out and then sticks causing the camera to shut down. If I turn it off an on repeatedly, the lense comes out a little farther each time. Eventually, I can grap it an help it come out the rest of the way and the camera works fine. Solutions?
We have a Panasonic PV GS-300 video camera. The camera said we need to clean the heads and started...
(More)
We have a Panasonic PV GS-300 video camera. The camera said we need to clean the heads and started recording blue lines across the images we recorded. We cleaned the heads with a tape purchased at best buy, but the blue lines are still on the recordings. When we record new footage, the same blue lines are recorded over the footage. We have also hit the reset button. Can you help us please?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
