Well I am having the same problem
My pc crashed so it was re built
installed windows 7 same problem
then went back to XP same problem
I reinstalled pinnacle 12 ultimate BUT can not down load the the patch via the net its not avaible now
We need to get this patch
Sunjith sewsunker
First make sure that your Camcorder is in the Disc Navigation mode to be able delete your required scene. When the camcorder is in the play back mode the delete scene won't appear.
The second situation is to check if your scene is not locked because if it is locked you are not able to delete it. Supposing that your scene is not locked then check what type of DVD disc you have. The discs labelled DVD Ram, DVD+RW, and the Card can be deleted. The DVD-RW can be deleted only when in VR mode and not the VF mode. Other types of discs like the DVD R can not be deleted.
Another way of deleting a scene after it has been recorded on a disc that's not deletable is to transfer the recorded scene to a computer disc and then edit it off.
Make sure the batteries in the remote are working (they go in the back of the remote at the bottom).
Turn on the DVD player with the power button on the DP300 itself (lower left). Open the dvd tray either with the remote (press open/close button, upper right) or with the button on the DP300. Put a DVD in the tray and close it with the remote or the button on the DP300. The DVD should load.
Use the arrow buttons in the centre of the remote to select choices from the onscreen menu of the DVD. Press Play (centre of the 4 arrow buttons) to activate the choice you want. For example, if you want to play a movie, use the arrow buttons to go up or down until "play movie" is selected, then hit PLAY, and movie will play. If you want to choose a scene/chapter of the movie, use arrow buttons to go up or down until Scene Selection or Chapter is selected (highlighted), and press PLAY. This should bring up a list of the scenes or chapters. Use the arrow buttons to select the one you want, then hit PLAY, and that scene should play.
If the DVD tray is taking less than 20 seconds to operate, there is likely no problem. If it is taking more, there may be. I think the mechanism that opens and closes the tray is often the first thing to stop working on DVD and CD players.
I had a similar issue a while back. It didn't do it every time, just on one DVD. When given the choice, go to "scene selection" instead of "play", and select scene 1. This bypasses the loop that the "play DVD" is on, and takes you straight to the movie. Hope this helps! --W/D--
What you are describing is 'Last Scene Memory' function which is a feature of most DVD players. The player will not memorise the last scene if you switch of the player before playing the disc. This should Fixya!
you have to finalize the video first and need to do it otherwise you cant because i have a sony and everytime i finalise it then i play the video finalizing option is in option menu
Got the same problem. The finalised disc plays correct on some dvd players, but not on my pc with Vista. Can't work with the recordings in pinnacle... Have not found a solution yet...
1.While the previews are playing, press the Menu Button on your DVD player remote to access the DVD's Main Menu. 2.Go to Scene Selection and press your Enter or Ok button on your DVD player remote. 3.Highlight Scene 2 and press the Enter or Ok button. This will start the DVD in Scene 2. 4.Use your rewind or reverse button on your DVD player remote to rewind back to the beginning of Scene 1.
Walt Disney Home Entertainment Technical Support 1-800-723-4763, Monday's 9:30-7:30 and Tuesday through Friday 9:30-6:30 CST
Over heating wont turn on http://forums.xbox-scene.com/index.php?showtopic=599216 http://forums.xbox-scene.com/index.php?showtopic=606431 http://copronymous.com/wp-content/uploads/2007/05/fix-for-the-3rlod.pdf
its a panasonic VDR-D160EB DVD Camcorder. Only shows 6 scenes of 72.
