Question about Lexmark Office Equipment & Supplies
Our printer didnt communicate to our computer.i install everything i follow all the cd instruction but still didnt work still not communicate the computer to the printer.or the printer to the computer.
    Sergeant:
    Champion:
  • 214 Answers
Check your printer cables or if required replace them
Posted on Jul 30, 2008
My lemark x3650 will not pick up on my computer
If this is your first time using your printer in your computer, then, you need to install the driver enable for it to communicate with your computer. Look for the dvd that came with your printer when it was delivered to you. Insert the disc and let it run. Follow the on-screen instructions.
If you already installed that printer before in that computer but just stopped working, then, you probably have some problems with its communication. The communication between the printer and the computer has been interrupted. I can't tell what made stop working but I can tell you how to make it work fine again.
Here's what you need to do:
Un-install the printer's driver by going to the Control Panel/Remove or Uinstall Programs/Lexmark.... After you uninstall the printer's driver, insert the dvd (printer's driver) in the tray. Let it run. Follow the on-screen instructions.
var geo_Partner = '82910b1e-9b92-42fd-b83f-fa09a0787ae7'; var geo_isCG = true;
Mar 04, 2011 | Lexmark X3650 Printer
I just bought A Kodak esp 3250 series AIO printer. I can print from computer, copy and all that but whenever I try to scan to computer or even preview scan I get a error saying :An error occurred while...
Try a new USB cable. Scanners require bidirectional communication with the computer and thus can fail when printer itself works. (If you use a print server or USB hub, try a direct connection.) Also try changing USB ports.
Another thing to try is to remove the TWAIN driver and reinstall it. This requires the original software CD from Kodak.
1. From your computer desktop, click Start > Run. (In Windows 7, type run in the search box then click on Run.)
2. Type %windir%, then click OK.
3. Double-click twain_32.
4. Right-click Kodak, then select Delete.
5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
6. Double-click aioscannr.msi, then follow the instructions to remove it.
7. Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
8. Open Home Center Software:
a. Select Scan Documents and Pictures.
b. Scan a document.
Unfortunately, if the error persists, the scanner may need service. Contact Kodak: http://www.kodak.com/go/contact .
I hope this helps.
Jan 06, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
When I try to scan or print a message comes up telling me to ck power and usb connections. I have unplugged and restarted computer 4 times and still have problem
It could be a communications error message, the printer is not communicating with the computer.
  • Disconnect and then reconnect the USB cable.
  • Disconnect and then reconnect the printer power cable.
  • Restart the computer.
  • Remove and reinstall the printer software
  • If your printer does not function properly or communication error messages appear when using your printer, you can remove and reinstall the printer software.
    1. Click Start®Programs or All Programs®Dell Printers®Dell Photo AIO Printer 962®Uninstall Dell Photo AIO Printer 962.
    2. Follow the instructions on the computer screen to remove the printer software.
    3. Restart your computer before installing the software again.
    4. Insert the Drivers and Utilities CD, and then follow the instructions on the computer screen to install the software.
    If the installation screen does not appear:
      1. In Windows XP, click Start®My Computer.
    In Windows 2000, double-click My Computer from your desktop.
      1. Double-click the CD-ROM drive icon. If necessary, double-click setup.exe.
      2. When the printer software installation screen appears, click Install or Install Now.
      3. Follow the instructions on your screen to complete the installation.
    Communications error message
    The printer is not communicating with the computer.
    Dec 06, 2010 | Dell 962 Photo All-In-One InkJet Printer
    Lexmak x1240 all in one will not communicate with computer
    Hi, I am writing you regarding your problem with the printer.
    If the printer is still not printing, try first replacing the usb cable, and try a different USB port.
    If still no luck , then you will probably need to reinstall the driver software, either from CD , or downloading the file from Lexmark website.
    If you do not have the disk you must download the software from Internet, follow instructions below,
    Click here:Official Lexmark Drivers and Software
    A web page will open, follow instructions, select model, select operative system etc., and click on download .
    Chose to download the file in my documents when asked.
    After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
    • Unplug printer USB.
    • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
    • Download driver from website, or use the disk and run the install file.
    • Follow driver installation wizard.
    • Plug back printer when prompted from installation wizard.
    Always start printer setup with printer unplugged, and chose printer as default during install.
    Mar 14, 2009 | Lexmark X1240 All-In-One InkJet Printer
    Documents not printing
    follow this steps 1)right click the my computer icon
    2)click properties and then click hardware n go to device manager.
    3)uninstall all usb ports and then scan for hardware changes
    4)ur pc will detect your printer and ask for printer drivers
    5)re load drivers and your pc will communicate with your printer
    6)for reloding install the cd follow the instructions on the screen and click next
    7)restart when the printer is loded.connect the wires and cords properly
    Nov 17, 2008 | Office Equipment & Supplies
    New printer-hp deskjet f4235 all in one -will not work. I have done everything EXACTLY like the instructions but still will not print.
    7)restart when the printer is loded.connect the wires and cords properly.
    Nov 15, 2008 | HP Office Equipment & Supplies
    Windows 98 PC won't recognize Lexmark 75 printer
    Oct 05, 2008 | Lexmark X75 All-In-One InkJet Printer
    Printiner not communicating
    Drivers, Software, lost C.D....come this way!
    If you have lost you cd or don't know how to install your printer then all you need to do is download the drivers and software from the manufactures website that suits your operating system and printer.
    Sep 16, 2008 | Lexmark Color JetPrinter Z23 InkJet
    Black lines in display and printer will not turn off with on/off button
    If your printer does not function properly, or communication error messages appear when using your printer, you can remove and reinstall the printer software.
    1. Click Start®Programs or All Programs®Dell Printers®Dell AIO Printer 946.
    2. Select Uninstall Dell AIO Printer 946.
    3. Follow the instructions on the computer screen.
    4. Restart your computer.
    5. Insert the Drivers and Utilities CD, and then follow the instructions on the screen.
      1. Double-click the CD-ROM drive icon, and then double-click setup.exe.
      2. When the printer software installation screen appears, click Personal Installation or Network Installation.
        If the problem continues, the printer needs to be serviced.
    Aug 09, 2008 | Dell 946 All-In-One InkJet Printer
    How to install my lexmarkx2470 to my computer
    when running the cd that came with the printer (if you have that)
    follow the instructions dont connect the printer/cables untill it tells you to do so then it should install .
    riz.
    Apr 02, 2008 | Lexmark X2470 All-In-One InkJet Printer
    22 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
