An alarm keeps going off on the tower, like a siren
  • 51 Answers
Any more info
Posted on Jul 30, 2008
How to disconnect the alarm
Depending if it is a aftermarket or a factory alarm, they should all have fuses that can be removed. By removing the fuse, you may lose your keyless entry option. Most aftermarket alarms have a siren that is usually mounted under the hood in the engine compartment area. I've seen where people have cut the wire going to the siren to disable it but keep the power going to the alarm system to keep the keyless entry still functional if it came with the alarm system.
Factory alarms usually use the existing horn for the alarm. If that is the case, you might need someone who is experienced to disable the circuit so that the horn will not sound if alarm goes off but the horn will still be functional when needed. Hope this helps.
Dec 20, 2014 | Cars & Trucks
I need to switch off my car alarm
You car is now of an age where by the ni.cads in the alarm have failed an are causing a current drawn when the car is turned off..the alarm sees this current draw as a theft so the alarm sounds.
Either replace alarm siren assy (fitted with new ni.cads) or remove the siren (or just unplug it).
Jul 06, 2014 | 1998 Rover 600
Siren is going off and I don't know how to stop it. It was installed about 9 years ago and installer went out of business. I think it is wired separately from the security panel. We are clear across...
Time to install another alarm system.Go to the power source just disconnect the battery power source,if the control panel don't acept the codes or respone to the codes anymore.If the alarm keep going off the police come out more than one,they'll give a ticket every other times they have to show up to check around.
Jun 05, 2011 | Ademco 1 Wave 2 Alarm Indoor Siren Vista...
I have a Ge Simon Xt Alarm and i want to hook up a external siren(part 13-950)I received a 4.7 resister with the siren and 50 ft of wire.How do you attach the resister between the red and black wire?Do...
Wire nuts are ok if the siren is indoors. Gel filled connectors are better if you are mounting the siren outside because they keep the connection from corroding. The resistor needs to go between the two wires you are hooking up. The color of the wires you will are are generally red and black. If your siren has a yellow wire, you can use it instead of the red to get constant siren instead of the "whoop, whoop, whoop" sound that sirens usually make. Putting the resistor at the siren will make sure that it is supervised. That means that if someone cuts the wire going to the siren, it will alert you at the panel. If you put the resistor at the panel, nothing will happen if the wire is cut.
May 19, 2011 | GE Security Simon 3 Wireless Home Security...
Alarm seems to work; been checked at Toyota but they say siren is broken and say it's a common fault. But everything else seems to work - you can hear the relay clicking; lights flash.
What is actually the problem, "Actually seems to work", what doesn't work.
If Toyota are on about the 9volt battery back up siren then the main siren may be working fine, but that might not be. Most cars especially Vauxhalls have a 9volt battery back up siren, so if someone tries stealing you motor and they disconnect the battery the 9volt battery will keep the siren going off.
Feb 19, 2011 | 1998 Toyota Corolla
Just installed smart siren kit, worked ok for 1
Harley alarms, while a decent alarm system, are notoriously hard to set up. On a new installation I have sometimes had to run the set-up routine 4-5 times. I hope you have an owner's manual and/or good instructions. Keep trying to set the alarm up from the beginning. If you miss a key or time limit it's not unusual to have the set-up fail and you have to start all over. Disconnecting the battery will screw things up, so be careful.
Oct 02, 2009 | 2002 Harley Davidson FLHTCUI Electra Glide...
Alarm/siren sound
Check any alarms that may be set. Lok at the system clock, and any timing applications. Check your anitvirus for schedualed times for scaning.
Good luck
Jun 25, 2009 | IBM ThinkPad R51 1830 (1830AHU) PC...
Volvo s80 alarm
Have the codes read out for the vehicle. It is likely that the siren for the alarm is causing the false alarm. If the siren is bad, there will be a code set in the central electrical module. (CEM)
Jun 26, 2008 | 2003 Volvo S80
Wirng up a bw10000 car alarm to a dj systems siren
If you're connecting at the alarm module - you want the red wire from the siren to go to the brown wire on the alarm(the one that's in a plug with 12 or so other wires), not the red (red wire is the constant power input to the alarm).
Feb 24, 2008 | Car Audio & Video
Computers & Internet Logo
103 people viewed this question
David Payne
David Payne
