All the different lights you get on the dash of any vehicle, have
been there since 1980. That is 31 years. Nothing has changed
since then ,unless you were on another planet
Check for Codes
Diagnose System with OBD Malfunction
Repair system as necessary
It is pretty common for the pad on the solenoid to strike the keys wears out, and for the batteries to be dead for the memory. Your machine probably needs a good cleaning, oiling, and a new pad for the striker. about $100.00 in the shop.
1. Turn the ignition from OFF to RUN 4 times within 6 seconds. 2. Turn the ignition OFF. The system will chime to confirm programming mode. 3. Within 20 seconds, press any button on first keyless remote. The system will chime once to confirm programming. 4. Within 20 seconds, press any button on second keyless remote. System will chime once to confirm programming. 5. Turn ignition to RUN to exit programming mode.
To get the code in: 1. Turn the stereo off.
2. Turn off the ignition
3. Turn the ignition back on (dash warning lights on)
4. Hold and keep down the AS button on the stereo.
5. Turn the stereo on.
6. Release the AS button after 4 dashes appear on the display
7. Now enter code (if code = 7009. Press preset button 1 seven times, button
2 once
3 once
4 nine times
If you go past you can go round again by pressing the
preset button repeatedly
8. Once all 4 numbers are correct hold down AS again until you hear a beep (2 - 5 seconds)
9. The stereo after beeping will scan to program channels You have 10 attempts to get the code in. However some models will not give you the number of attempts remaining!
