Show me how to hook up speakers to the pc? please
HOOK UP 4000456 TO PC
Hello there.
From the little information on this item......
It seems it comes with an audio cable with 3.5mm Jack that plugs in to the headphone or output socket of your PC laptop etc.So that music from your device gets out to the speaker The cable also has a usb plug to plug in your PC to provide power to charge the battery.
If you want to download the guide showing the speaker / cable go here.
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/4000456_PM_EN.pdf
Sep 21, 2014 | Audio Players & Recorders
Tip
How to connect speakers to a Dell computer that has 7.1 intergated sound card....
This applies to: Dell Inspiron 530 and 531
Note if you are just connecting standard stereo speakers (2.0 or 2.1) you will just connect them to the green port. In adddtion if the speakers are 4.0 or 4.1 you would connect the rear speakers into the black port.
In regards to 5.1 speakers you would hook up the above listed connections and then connect the center and sub speakers to the orange port. The picture below shows the ring assignments for the center and sub-woofer connection if you are not using computer speakers.
For the 7.1 configuration you would hook up the above listed connection and then you would connect your side speakers to the white port. Note the side speakers are left/right speakers so the ring assignment is a standard setup with tip being left and the second ring being right.
on Aug 15, 2010 | Computers & Internet
My sterio won't make no sound at all and I don't know why. I have a sub slash speaker hooked up to it and another big speaker hooked up to it and it still won't play no sound at all
Is it possible that you blew out the speakers? Or that they are not connected properly? Showing the front of the Stereo is not at all helpful to understanding your issue. Please give a view of the back of the Stereo so we can determine whether it is improper wiring, blown speaker, or faulty components.
Dec 08, 2012 | Audio Players & Recorders
I have a Motorola DCP 501 Everything seems to work except the clip type speaker hook-ups no faults displayed
Hello
There are Center Speakers, Surround Speakers[L&R] and Front speakers[L&R]. Which amoung this show fault? Please clarify more about your Amps' problem.
Include the details of fault by FixYa comment box. OK.
Jul 10, 2011 | Motorola DCP-501 Receiver
I have dell speakers hooked up to my dell pc but NO sound.
  • Ensure the connection first if the connectors are hooked up to the correct port.
  • check if the speaker is receiving the power there should be an indicator lit up
  • If you have an integrated sound card make sure they are not disabled in BIOS.
  • Then check if the sound drivers are properly installed.
  • check the volume control to ensure if mute is checked(uncheck it) also ensure the volume level it needs to be set to a level so that it's audible to you.
  • Do check the speakers with another devioce to ensure the speakers are fine and working.
  • FOR MORE SPECIFIC INFO PLEASE PROVIDE THE MODEL AND BRAND DETAILS OF THE PC AND SPEAKER AND OS
Feb 21, 2009 | Dell Audio Players & Recorders
Moniter speaker
on my dell one male pin goes into the monitor and the other male pin goes intop the computer where the speakers normally hook up hope this helps ok please keep me posted on this ok best regards mike
Aug 24, 2008 | Dell C521 DimensionTM PC Desktop
How to hook up to computer
Hey Nerak, theres no better way then to show you, click here and the diagram will show you were to plug them in, good luck,
CoDoc
Dec 17, 2007 | Altec Lansing Multimedia Computer Speakers
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
