Question about Pinnacle Studio Ultimate Version 11
Capture from dvd disc
I cannot make devided scene from the file
    Champion:
  • 258 Answers
I need more info to answer this one. I use PINNACLE TOO
Posted on Jul 30, 2008
Samsung ht-tx500 keeps saying no disc what could the problem be?
  • There may be DVD region limitations on your device, and you use a DVD disc that is not listed in your device.
  • It may also be the vendor of your brand DVD disc, including those that are not recommended.
  • The format of the files on your DVD disc, does not support.
  • Disc Optic is dirty / dusty. Clean it.
  • Disc is scratched.
  • Damage to the disc player.
This picture is captured fromf the User Manual, page 6.25840297-l1qpqmriditabltrjczr2eku-4-0.jpg
Aug 28, 2015 | Samsung Audio Players & Recorders
How do I find the delete option on my hitachi camcorder?
Hi! The solution to your problem is Three fold.
First make sure that your Camcorder is in the Disc Navigation mode to be able delete your required scene. When the camcorder is in the play back mode the delete scene won't appear.
The second situation is to check if your scene is not locked because if it is locked you are not able to delete it.
Supposing that your scene is not locked then check what type of DVD disc you have. The discs labelled DVD Ram, DVD+RW, and the Card can be deleted. The DVD-RW can be deleted only when in VR mode and not the VF mode. Other types of discs like the DVD R can not be deleted.
Another way of deleting a scene after it has been recorded on a disc that's not deletable is to transfer the recorded scene to a computer disc and then edit it off.
Oct 08, 2011 | Hitachi DZBX35A DVD Camcorder
Is there a way to hook up a usb cable to a Sony Handycam DVD205?
unfortunately,no. the dvd camcorder was designed for easy dvd disc recording w/o usb or computer connectivity (it doesn't have usb port for connection). comparable models that has the usb jack are dcrdvd305 aqnd dcrdvd755 (which cost more). but don't loose hope.other options to transfer videos from cam to pc is by using the dvd disc (make sure you finalize it) and your computer's dvd drive (make sure it has supports 8cm disc and the disc tray in the right orientation to take the disc so it won't fall out). once inside the drive.open or explore the disc and copy and paste video files saved on the usual video_ts folder or the .vob files. if you need to playback the copied files you can simply change the file name to .mpg or use a file conversion software (which you can easily download for free online, use free file conversion as your search phrase) to convert files to a file format you need for editing purposes. another way to go is to use the supplied a/v cable. this type of connection would need a supporting software and hardware installed in your computer. an a/v capture card should be installed and a compatible video capturing application would be needed. hope this helps.thanks:)
Jun 01, 2010 | Sony Handycam DCR-DVD205 DVD Camcorder
Vob ifo bup files to burn as dvd trouble
Try this:
Get the Nero 9 application
Install it on your computer
Create a Video Disk
And browse the folder of the VOB files Add it to burn the disk
Select Burn to burn the DVD ....
You may also try to put in a blank dvd and copy all the files on the DVD drive
Select burn these files on the disk
This should work
Regards Soumajit
Mar 12, 2010 | Computers & Internet
How do I transfer the mini DVD to Movie Maker
With your Recorded DVD-R Disc "Finalized", and in the DVD player on your computer, you should be able to browse to your videos with Movie Maker.
In MovieMaker, on the left side where it lists:
Movie Tasks
1. Capture Video
Capture from Video device
Import video . . .
You want to "Import Video", by clicking that and browsing to the DVD-R to find what could be MPG files, or VOB files. They're both MP2 DVD format video and audio files.
Tip: Right Clicking in the Import Video Dialogue Box where the files are listed and selecting View / Thumbnails, will present a view of the scenes in each video.
Jun 11, 2009 | Canon DC100 DVD Camcorder
I want to make dvd that is compatable with dvd player.
The files on your camcorder should be mpeg files, unless you finalized the disc. A finalized disc should play on any dvd player. DVD-R disc work with all DVD players, DVD+R disc only work with some DVD players.
Feb 12, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Recording locks up on "Generating disc menu"
I too suspect it is related to windows updates which seem to take up a lot of memory. The only solution to Pinnacle hangups is to make sure you have a computer that accepts 4 MB and upgrade to Windows Vista.
Short of that, the solution is to break your videos into tiny scenes containing 30 pictures or less if you are using AVI, and then save your files NOT to DVD, but onto your hard drive as image files. Make sure you rename each section image file after you save it, or each section will write over the previous one.
Finally, using a program like Nero (the Express part), join them all together on one DVD and allow Nero itself to create your menus. Nero does a fantastic job of that and makes menu creation very simple.
Jan 25, 2009 | Pinnacle Dazzle DVD Recorder
Importing Videos to Microsoft Movie Maker
Hi, i have a perfect solution but it costs around £30. Buy Ulead VideoStudio 11 plus. Its excellent, for one thing, it picks up your disk when you put it in and also you can edit it. I had the same problem but since i got this is was fixed!
May 02, 2008 | Panasonic VDR-D100 DVD Camcorder
Help - Capturing Video from a DVD-R Disc
I took the plunge based on manufacturers marketing claims and sales level tech support - Mistake! Panasonic VDR M50. The DVD-R disks are fairly straightforward. They can be played in my DVD video player and my PC, and I can use Fleximage DVD-to-AVI for conversion to a file format I can use for editing. The camera creates sequencial files for some reason and this software will only convert the first file. Very frustrating! I ended up playing the DVD-R on my DVD video player and using the video cable, transferred the video back to a DVD RAM disk on the camera. See DVD RAM problems below. The software that came with the camera has so far proven worthless. I have struggled with the DVD RAM disks. They are fabulous to use in shooting and editing on the camera but I cannot for the life of me get the DVD format converted off the DVD RAM. They cannot be read by my DVD video player or my DVD drive on my PC. I can see and even transfer the files to the PC through USB but for some reason, the DVD-to-AVI software will not recognize the files that were recorded and I cannot use the file format from the DVD ROM for anything other than viewing the video. Again, the software that came with the camera has so far proven worthless.
Sep 06, 2005 | Panasonic AG-185 Camcorder
Pinnacle Studio Ultimate Version 11 Logo
60 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
Alun Cox
 Ian Kayhan
Ian Kayhan
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
