DVD Recorder Samsung
I have used a laser cleaner lots of times. I have the right type of disc (dvd-r) - does the speed at which it writes make any difference? Some are labelled 1-4x; some are 1-16x?
    Habit-Forming:
  • 35 Answers
1-16 just allows it to record faster a better quality disk. It is possable that some cheaper disks may not work as unit gets older and laser gets weak. May need laser manualy cleaned.
this can be done with isopal alchol and a Q-tip if you can get to it. It depends on if you want to start disasembling yourself or take it to someone that can. local electronics handy man. or repair shop.
Posted on Jul 30, 2008
I have a phillips magnavox vcr dvd recorder combo model number mwr20v6 that i have had fo about 2 years and here lately every time i try to record on to a dvd it pops up with error code e454037380.i have...
I have a phillips magnavox Problem with the Philips Magnavox MWR20V6 DVD Recorder / VCR Combo I have a phillips magnavox vcr dvd recorder combo model number mwr20v6 that i have had fo about 2 years and here lately every time i try to record on to a dvd it pops up with error code e454037380.i have cleaned the lens with a disc cleaner and still didnt help,same thing is happening. i am also using the same type of disc that I have been since day 1. Can you help??
Mar 09, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have a Panasonic DMR-ES35V DVD Recorder. The manual recommends their lens cleaner RP-CL720PP which is discontinued. Is it safe to use a generic CD/DVD lens cleaner for players? Or do I need one...
You should use a specific DVD lens cleaner for your recorder, there are generic ones available I am sure. I do not recommend CD/DVD lens cleaners - far too abrasive, and there is a risk of damage to your unit if you use this type.
A generic DVD lens cleaner should do no harm and does not cost a lot. The type of cleaner I have used in the past is exactly like a DVD disc, with fine bristles, is a dry type, and it gently removes the grime and dirt film from the lens eye (you can probably obtain a wet and dry type that comes with a small bottle of fluid). These are the most reliable, and, unlike original CD lens cleaners, are far less abrasive. These lens cleaners usually work in DVD players and recorders, I've never had any issue after using this type.
Give that a try, see how you go.
Feb 02, 2011 | Panasonic Televison & Video
Hi, I have a Samsung DVD-VR300E dvd/vcr combo. The DVD player won't read any DVDs anymore, whether bought or recorded. What I don't understand is that it does still read the DVD cleaner disk! It won't read...
The laser in the DVD drive may be shot (?), even though it seems to read the DVD cleaner disc. I attended a maintenance class on cleaning CD and DVD writer drives for PCs and was told not to use the disc cleaners with brushes as they can knock the laser out of alignment. It's best to use a can of pressurized air to clean a drive when it's open. Just make sure not to allow any of the propellant to get inside!
Aug 03, 2010 | Samsung DVD-VR300 DVD Recorder/VCR
How to record from tv . what sort of disc is used
if you unit is capable of recording from TV you use a R-W DVD Disk (Read write) The disk should be capable of writing many times. So can your unit erase as well as write?
Please rate my help++++Thanks for using FIXYA
Mar 21, 2010 | Televison & Video
When I put a DVD-R into the DVD-R 155 recorder to copy a TV program after a few minutes of the blue disc at spinning at the top right of my TV screen the disc is ejected with the message 'disc cannot be...
This is a Samsung DVD recorder - I've had the exact same problem - By the way, don't you mean "this disc cannot be recorded" ? These DVD recorders are known to reject certain type of discs.
* Have you updated your Samsung with the latest firmware ?
http://www.samsung.com/ca/support/download/supportDown.do?group=&type=dvdplayers&subtype=recordable&model_nm=DVD-R155&disp_nm=DVD-R155&language=&cate_type=all&dType=D&mType=FM&vType=&prd_ia_cd=03010300&model_cd=&menu=download
Follow the instructions carefuly and please understand the risks involved in flashing your drive - Do not interrupt the process, it can take long.
* here are the brands of DVD-R I have used successfuly with this recorder int he past:
Taiyo Yuiden DVD-R 4x / 8x (the optical drives used in those recorders are outdated, their writing strategies are never up to date and may not recognize some type of discs)
Maxell DVD-R 4x / 8x
Verbatim DVD-R 4x / 8x
Try another blank disc - maybe it will accept it - if it keeps rejecting all your blank DVD-R no matter what brand, you have a bad drive inside your recorder - the samsung recorders are **** - I have ever since gotten rid of that piece of **** and now use a Sony HDR-780 HDD/DVD recorder, uses pioneer components and is great !
Avoid those lens cleaners - they can do more harm than good!
I hope this helps.
Try different brands of DVD-R, avoid the cheap generic **** - drives like best Taiyo Yuden & Verbatim media id codes - they should recognize Maxells, verbatims, sony, taiyo yuden, ritek. if it keeps spitting out all discs you use, you have a defective unit. The latest firmware on that drive should also help !
Good luck :)
Aug 22, 2009 | Samsung DVD-R155
Has really slowed down dubbing - and disc is heated when removed, after only one dubbing and finalizing.
The speed of dubbing depends on the max writing speed of the disc used.
A disc always gets warm after using,the laser gets verry hot.
Jul 31, 2009 | Panasonic DMR-EH50 DVD Recorder
Won't accept any dvd disc
It sounds like the Laser went out. Buy a new dvd player
Jan 13, 2009 | Samsung DVD-VR330 VCR and DVD Recorder
Dvd recorder funai
I have fixed mine with the same problem , all it needed was the lens cleaned , i used a laser lens cleaning disc from maplin for 6.99 and voila good as new.
May 09, 2008 | Funai PY90DG DVD Recorder
RCA DRC8295 DVD Recorder
I also was having same issue's with blank DVD's with 16x or higher ratings. I remembered that when I first used the recorder their was only 1-4x write speeds available so I started to look for these specific dvd's. It took me a while but I did find some and ordered a set of 25 five to try and the recorder worked.
So the issue is that the recorder will not read any dvd rated more than 4x, and the under side of the dvd's rated 8x and faster are a different color that the laser is not able to read. The dvd's are made by Philips brand rated at 1x-4x and are DVD+RW, I haven't found the DVD+R' yet but am still looking.
I found these DVD's at www.tigerdirect.com and the minimum amount was a 25 disc spindle but I think you could get 50 or 100 but am not sure so look around a bit but these will work. I put one in my DVD recorder and was formatted within a minute and was asked if I wanted to name the disc which I had not seen in a while.
Anyway you all can use your recorders again and my dad will get to use hid for the first time as he has had this problem right out of the box!!! I think the owners manuel specify's you to use 1x-4x but am not positive.
Oct 17, 2007 | RCA DRC8295 DVD Recorder/VCR Combo
Dvd recording
have you close the disc
Jul 26, 2007 | iLO DVD Recorder DVDR05
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
