My Vista 64 can't install Xerox PE 220
I can't install pe 220 in my vista 64 premium. cd driver from the package can't give me a driver for vista 64. i've download driver from xerox.com, but still can't find me a better soultion.
control centre program from the cd can't be installed... i don't know why....
and, i want to know, how to install the pe 220 firmware. can someone tell me how to do this?
Thanks in Advance
  • 7 more comments
  • Anonymous Sep 16, 2008
    same here
  • Anonymous Dec 06, 2008
    Same problem. PE220 cannot scan
  • Anonymous Dec 13, 2008
    same
  • Anonymous Dec 14, 2008
    oh no! and here i thought it was just me! has ANYONE actually solved this problem or should i try to return the printer while i hopefully still can...?
  • kitronit Dec 16, 2008
    I've got Vista Home Premium (32 bit) and I can't get the scanner to work either. The thing prints and copies but can't scan!
  • Anonymous Dec 25, 2008
    Hello everyone,
    I tried all ways to solve this scan problem. My OS is Vista 32 Home Premium.
    Let's turn XP back is better.
  • charlie810 Jan 03, 2009
    Hi all,
    I read your messate on fixya.com regarding the solution for the problem of installation of the scaner of the Xerox PE 220. I did as you recomended - means install it by Windows update - it takes long time and successfully installed but I can not use it in any software like Paper port, Corel....
    I faced exactly the same problem as kitronit described
    "When I intialize the PaperPort scanner software that came with the printer, I am required to set up and test the scanner using the ScanSoft Scanner Setup Wizard. The Wizard is able to see my scanner. When the Wizard tested my scanner, I got the following error: "The Wizard cannot find your scanner.". The same message provided several tips such as checking that the scanner is on and connected (I did - and besides, I am able to print to the same machine so there is obviously not a problem with the connection), restarting Windows (I did), and checking that the scanner works with another application.
    I then tried scanning a test document using Microsoft Office Document Scanning software, but I got the following error: "Unable to initialize scanner. Check scanner connection and scanner software." Of course, I know that the scanner connection is fine, since I have no problem printing to the same machine, so obviously that is not the problem..."
    It is interesting that I used this scaner normally before with the same OS (Windows Vista Home Basis 32 bit). Last week I decided to reinstall the whole laptop since it was heavy already and I could not reinstall the scaner this time - I don't know why ? Seems everything is the same - OS is the same, the driver for it for Windows Vista I downloaded and installed properly and the laptop sees it in all programs but any time I start scaning it can not be initialized (Some error in initializing the scaner !)
    Do you have any idea to help me - I tried many ways already.
    Thanks and best regards,
    Charlie
  • fenvun Feb 21, 2009
    I have the same problem and downloading the latest update from Window update did not fix the problem either. The printing works ok. but not the scanner or the fax.
  • kitronit May 11, 2010
    Tekin_S,
    Thanks for posting your solution. Are you able to scan with your printer or just print with it?
    I was able to install the necessary scanner drivers (or so says Windows Device Manager), but I have problems with the Control Centre and scanner software, and until this is resolved, I can't use the scanner/fax. Note - the printer works fine, just not the scanner/fax.
    Why does Xerox claim that you can use this scanner on a Vista OS if no one seems to be able to.
Pls visit to this web http://fujixeroxprinters.com.au//en/support/Downloads.aspx?product=5460.
Everything in there. Just download and install. Hassle free
Posted on Dec 03, 2009
Okay my friends,
This is Tekin from Turkey. I solved the problem.
However Xerox says "this product works on Vista", I discovered Vista Starter and Basic editions are not support this product. I tried on Vista Home Premium 32. PE220 original driver CD does not include right Vista drivers as I learn. So, you should need internet connection, this means PE220's right driver will be installed via Windows update.
I do that, and three right drivers of PE220 was installed to my OS. And now I can use my work center.
Fax, Scanner and Printer. There is no problem.
If you need for further help about this you can wrtie me an e-mail: tekin_s@yahoo.com
Regards
Posted on Dec 27, 2008
I need a driver of my printer XEROX WORK CENTRE PE 120i for Win7 32bits and 64 bits.
You can download the Xerox printer drivers from theirsupport WEB site. Please click on this link and
select your model printer todownload :- http://www.support.xerox.com/support/enus.html
Feb 21, 2011 | Xerox WorkCenter PE120i All-In-One Laser...
Nu mai am cd sa spart si nu se instaleza
Here is the driver from A4Tech website for your A4tech PK-635 web camera. Works with Win98, Windows 2000/XP/Vista/Win 7: http://www.a4tech.com/downloads.asp
Put in PK and 635 and then GO, then on the left side click Driver for PC to download the driver for it.
Mergi la linkul de mai sus, pui PK si 635 si apesi pe GO, pe urma dai click pe "Driver for PC" ca sa descarci driver-ul pentru acest webcam.
Feb 12, 2011 | A4tech PK-635 Webcam
Canon MP500 all in one printer is not compatible with Windows Vista. Is there a solution for this problem, or do I need to buy a different printer?
My Canon PIXMA MP500, purchased in mid-2006, came with the (then) ScanSoft OmniPage SE2 software on a CD. The PC had WinXP Installed. I had no use for the ScanSoft it so I made no effort to install it.
Fast Forward:
Two PC crashes later, July 2009. Using Win Vista Home Premium
LOST, important WinWord document file, only a hard copy available.
I tried to recover, scanning the "Xerox" copy. The SE Version of OmniPage was very complicated but I succeeded in producing a replacement *.doc file.
It appears that newer editions of WinVista contain the right printer drivers for this Canon Model.
Apr 26, 2009 | Canon Pixma MP500 All-In-One InkJet...
Gta san andreas
în conformitate cu ceea ce am căutat pe internet, GTA nu este compatiable cu Windows Vista. Ai nevoie de Windows 2000 sau XP pentru a instala acest joc.
Ne pare rău ArmyMason
Feb 24, 2009 | Microsoft Windows Vista Home Premium with...
I can not scan in xerox pe 220
I found the solution today. First you go to Autralia Fuji Xerox website at http://www.fujixeroxprinters.com.au then select Driver - Xerox WorkCentre PE220. Download the Control Centre and Scan to PC together with WHQL_PE220_2K_Vista_SCAN (scan Driver) and WHQL_PE220_2K_Vista_GDI.zip (GDI Driver). Setup files are in Control Centre and Scan to PC folder. The rest will pop up new hardware found and browse to two other files dor perfect driver.
Hope this help because it's help me today. Thanks to Miss Chin from Pineaple Computer Store One Utama Malaysia.
Nov 01, 2008 | Office Equipment & Supplies
Intel 845 GVSR drivers for windows vista
change to Windows XP,
windows vista will not support with *********** board
it will support more then 865 chipset
May 17, 2008 | Intel 845GE Motherboard
1,628 people viewed this question
jasbo
jasbo
