When I plug in my Zen Micro to the PC to chage all i get is the flashing charge signal but the devices does not recgharge. This is the same USB that i have used successfully on another PC. it also wont register on my pc when i plug it in so am unable to orgainze my Zen.
  • Billie13 Aug 03, 2008
    still dint work but thanks.. might be that i didnt insatll the drivers correctly.
    Novelist:
  • 167 Answers
I use to have that little player and i remember how it could be tricky on different computers.
from http://www.anythingbutipod.com/forum/showthread.php?t=27711
If these don't work please report back:
4. If the Zen is not detected by or charging from the computer when connected, make sure you are using a USB port on the back of the computer (built into the motherboard) instead of one wired to the case (front or side). That way you are using a USB port with the proper power output.
5. If the Zen is not detected by or charging from the computer when connected, make sure the USB port you are using are USB 2.0 and not v1.1. If you computer is a newer computer, this shouldn't be a problem, but if it is an older computer, it may only have USB 1.1 ports which doesn't output enough power as USB 2.0 ports.
6. If the Zen is not detected by or charging from the computer when connected, make sure you have no other USB devices plugged into the computer (front and back ports), but the Zen. That may be worth a try to see if you can get enough current from the USB ports to begin charging it again. Usually the more devices you have plugged into the USB ports, the less current that will be available for charging due to the power being shared with all other devices plugged in.
7. If the Zen is not detected by or charging from the computer when connected, make sure that the drivers are loading for it properly under Device Manager (no conflicts showing). I believe the Zen will not be detected or begin charging unless its drivers are loaded and working properly.
Posted on Jul 30, 2008
I think my zen has a viruses and it won't turn on
charge the zen via usb data cable by connecting it to the computer dont charge through plug switch
Feb 06, 2010 | Creative Labs Zen Micro MP3 Player
I have a Zen Vision M 30G when i plug it in i get a malfunction error and the USB does not recognize it, It does however charge and everything works properly on the Zen
was their any software that came with the device to download. If you have it plugged in to a receivers usb port, check with the receivers ability to read the device, some only handle up to 2Gs. If plugged into usb on computer your device should aquire software to make it recognizable.
Nov 07, 2009 | Creative Labs Zen Micro MP3 Player
CREATIVE ZEN - NOT CHARGING
Go into your lab top and click on remove hardware safety.Find your zen the click remove..Next do not unplug it,shut off your zen then you should see instantly on the zen its charging...
Mar 31, 2009 | Creative Labs Zen V MP3 Player
My battery takes ages to charge threw usb
wal-mart sells a usb charger for under 20.00 us dollars. you plug it into outlet, then connect a usb cable to it and finally your player to the plug. hope this helps.
Dec 27, 2008 | Creative Labs Zen Micro MP3 Player
My zen doesnt want to connect
I think I found my answer. With my player connected I went to Control Panel- System- Hardware- Device Manager and under Portable Devices removed my Zen Player. I then went back to Control Panel- Add Hardware- and let the Add Hardware Wizard add my player back.
My Zen Micro Photo now connects to computer and I can charge the battery with no problem.
Nov 04, 2008 | Creative Labs Zen MicroPhoto MP3 Player
Zen V Plus not charging and not recognized by windows
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Also make sure if your device requires "DRIVERS" or if you have a CD download and install that before anything.
Aug 18, 2008 | Creative Labs Zen Micro MP3 Player
Vision M not recognized
I'm having the exact same problem. My zen is 'charging' but isn't detected anywhere on my pc and I'd leave it charging for days but nothing happens. I've tried different usb ports, reinstalling the software several times but nothing. I recently reinstalled Windows and with my new pc my Zen cannot work on it for some reason?! I put previous files from my old pc onto my Zen hoping that I could transfer them onto my new Windows pc but I fear I've lost the data on my Zen completely. Arggh, any suggestions guys? Please..x
Feb 29, 2008 | Creative Labs Zen Touch MP3 Player
Creative Zen M won't turn back on
There is a major bug in Firmware version 1.40.xx related to battery charging, and it will exhibit this behavior if there is not enough battery power available for your device to power up. You will need to upgrade your firmware to fix this.
There is a catch, however - your player will not power up on USB power alone, which poses a problem for firmware updating. You must obtain a DC wall charger, plug it into the player via the dongle. This will allow the device to turn on. Then you must plug into your computer's USB port. Do not worry - having both a wall charger and USB cable plugged in at the same time will not harm your player or your computer. This will allow your ZVM to remain powered up so you can update the firmwar
Nov 15, 2007 | Creative Labs ZEN Vision:M Digital Media...
Charging
The apple usb power adapter only works on apple products.
Feb 09, 2007 | Creative Labs Zen Micro MP3 Player
Creative Labs Zen MicroPhoto (8GB) possible faulty USB Cable ????
When I had that problem on my Zen I un-installed all the software and rebooted my system and reloaded the software. Not sure why it worked but it did.
Nov 13, 2006 | Creative Labs Zen MicroPhoto MP3 Player
178 people viewed this question
 Grubhead
Grubhead
