Question about Motorola Mobility RAZR V3
Unable to charge
My phone was charging just fine ealier and now it doesnt at all. i've tryed a lot of stuff. please help me fix it.
I had the same problem. The wire on my charger had a kink in it. A new charger fixed the problem.
Posted on Jul 30, 2008
Recently my samsung galaxy s2 fell on the ground and shattered the screen! A day later the phone just died! I've bought and fitted new screen and housing but the the phone still won't charge or...
you need a new phone i think you broke the motherboard in the phone i did this as well and tried to fix it myself when i took it in to get fixed they said that the motherboard was broken and that i just needed a new phone... good luck look at it and make sure nothing else had been disconnected also look at the charge points and make sure nothing broke off and got stuck in there i know simple stuff... but sometimes thats the problem...
Jan 10, 2013 | Cell Phones
My phone won't charge and is about to die. When I put it on the charge is says "Unable to charge. Non supported battery." I've tried using the air in a can stuff on the ports but that...
You may have a hardware problem. It's very common for the charging port in a cell phone to become damaged somehow, which can cause this error. Other possibilities is a damaged battery or damaged power cord. Your best bet is to bring the phone to your carrier's nearest store and have them check it out for you. If it's the battery or the cord, a simple replacement is cheap and quick, but if there's a problem with the phone itself, you'll need to get a new one.
Jun 10, 2011 | Samsung Glyde SCH-u940 Cellular Phone
I have a sony cibershot camera for over a year now, it has always worked nicely, up until a month ago, it suddenly wont turn on anymore. I,ve already charged and re-charged the battery but nothing...
make sure the batt is charging and working fine.check also the batt contacts.make sure its clean.insert batt to your camera.instead of pressing the power button, press the play button instead to power camera on. if unit turns on,might actually be an issue w/the camera unable to power on in camera mode.if it turns on initialize cam (p.75 of the manual).see if it works.if still wont turn on try using a diff batt (or if you have an optional ac adapter model#acls5k use it, attempt to power on cam to isolate issue w/power source).if batt or ac adaptor not available try to check batt with another cam if possible to test batt. if still unit doesnt turn on using a fully charged, diff batt, or using an ac adaptor,unit would reuire service. hope this info helps.thanks:)
Apr 06, 2010 | Sony Cyber-shot DSC-H9 Digital Camera
Razr will not charge with wall charger
Your charger is faulty. If your phone is able to charge off of other sources (computer, car charger, another wall charger) Then, the charger needs to be replaced. Some mobile companies have a 90 warranty on accessories like the charger and battery. Then the mobile manufacture (Motorola) has a 1 year warranty on the charge and battery. I would check on that, and get those replaced.
Feb 04, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Won't Charge or Turn on
First try drying out your phone for a day or two with lots of dry moving air gently blowing past and around it, the phone must be unplugged and battery removed during this process, then once everything has been dried try charging the battery in another phone just like it, if it charges and see it it will power the phone, if the battery works put t back into your phone and try to turn it on. If it doesn't work in your phone but it does in another then its the phone, if the phone works with another battery its the battery but dry them both totally first, even a few tiny specs of moisture can screw up your phone when power is running through it, so be careful. Cheers!
Mar 02, 2008 | Motorola Mobility RAZR V3
V3 unable to charge
reflash the firmware this will correct the charging issues and if that does not fix it then have the mainboard replaced.
Feb 17, 2008 | Cell Phones
*Unable to charge
Try a different battery in it when you are trying to charge if it works your fixed if not it may be as you suspect.
The other way is to try a different chargers well if the prob is still there then it is in the phone and needs a tech to look at it
Nov 03, 2007 | Motorola Mobility RAZR V3
Unable to charge
My wife spilled some water on her Pebl and she shut it off for the night. She dried it pretty good but it had a protective case over it and she thought that it didnt get water into the inside of the phone but it did. The next morning the phone wouldnt work. We left the battery out all day and yes, the "wet" dot had turned red. We thought all was lost, but that evening after it had dried we replaced the sim card and battery and turned it on and it worked fine....except it needed to be charged and when she went to plug it in we got the "unable to charge" msg and the phone shut off. Well, since I had bought the phone second off of Ebay I knew there was nothing that Cingular would do, I took the screws out of the back and took the phone apart. There is another one of those dots back there as well....and it wasnt tripped. I did notice a little bit of white stuff around were the battery prongs touch the main circuit board, I gently used the small screw driver I used to take out the screws and cleaned that stuff off. I also gently scraped those prongs and the metal they touch on the circuit board. Thought it was a long shot but I put the phone back together and plugged it in and bygod, its charging. Guess we will see how long this fixes the problem. Hope this helps you out some.
Jun 05, 2007 | Motorola Mobility Earwrap Handsfree For...
Motorola Mobility RAZR V3 Logo
19 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
