Hard disk i have hard disk that is too old nd i want to recover my files.... i use USB to IDE cable to recover my files but my hard disk is not detected... i olridy try to change the jumper to slave,cable select,master, but no good... is der some1 can help me to recover my files in hard disk....even i try to boot up it in my desktop computer as slave nd cable select no good also...... tenkz in advance
  • thraser
    thraser Jul 30, 2008
    tenk but my hard disk canot be detected olridy....is der oder way to fix it???
    Problem Solver:
  • 7 Answers
First be sure the drive is a vaible drive.....meaning it should be in it;s originbal PC it came out of and able to boot up on the installed OS. If it can then you are in luck..... install the drive you want to copy to as a slave and use a program like DriveCopy or Norton Ghost to copy the entire drive.....or if you are just after select files, you can use the copy/paste method to the drive. By trying yo use the drive in a different PC it will not boot since it has the other PC's drivers on it =( If the drive will not detect in it's native machine then most likely the drive is lost (unless you pay to clean room recover the contents....spendy!) Let mem know if you need more help!
Jay
Posted on Jul 30, 2008
  • Jay Cain Jul 30, 2008
    Drive recovery is a last resort and very expensive. BUT, if the inof you seek is vital it is about the only option. Prices start at around $400 usd and go high.... well over $1200 usd. If this is an option you wish to consider I can send you names of good companmies that provide the service
Hitachi DK-238A-43 HD data recovery with a USB cable?
Get a USB box similar to the ACRYAN ACR-HD83060.
This box supports both 2.5" SATA and IDE hard disks
Jan 06, 2014 | Computers & Internet
My hardisk is unable to detect by the computers?? Please help!
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this program to recover your files.
http://www.asoftech.com/adr/
May 10, 2011 | Computers & Internet
Seagate external hard disk is not getting detected in windows 7 previously it was detecting. i tried to change usb cable, tried on different system but nothing worked. i want to take backup of data also....
This is my suggestion for you to possibly recover the back up file in your external hard disk.
Remove the enclosure cover of the external hard disk. Detach the hard disk from the ide connection.
Change the jumper setting of the hard disk to slave. See the sticker in the hard disk to see how to set up the jumper to slave. Connect the hard disk to the ide cable inside your pc. If your computer is equipped with sata cable, just find some ide cable and connect it the the ide slot in your motherboard.
Restart your system and you will find your hard disk as drive (d:) in your system. If this was successful then problem can be cause by loose terminal solder in the usb/ide connector of the enclosure, or possible voltage drop of the power supply of the enclosure. USB driver issue or problem with the usb slot in your computer can also cause this issue.
Jan 26, 2011 | Seagate FreeAgent Go 320 GB USB 20 Hard...
The hard drive is not being detected on our laptop it turns on and everything but its not being detected what is the problem its not even a year old yet.
Oct 09, 2009 | SimpleTech 1TB SimpleDrive USB 2.0/eSATA...
I want to read the files of my old Hard drive?
ok you have a pc. now, plug the IDE connector to your old hard disk and plug the power connector also. Now, you have 2 hard disks. Your old hard disk must be plugged into the secondary IDE slot. Dont touch anything with your original hard disk. Just add your old hard disk to your PC through the secondary IDE slot and using IDE cable. When your Windows OS opens, you will see a new Hard Drive when you open My Computer. It could be Drive E, F or G
Oct 09, 2009 | Maxtor Hard Drive
I think i have lost my recovery partition and i don't have haveany recovery cd so how can i recover my laptop and that partition is unllocated
HI......
PLEASE FOLLOW THE STEPS CAREFULLY
  1. Step 1 If you have deleted something by accident, you can try to recover that file from the recycle bin in Windows.
    If you have emptied the recycle bin, you may be thinking it is lost forever, but you can try to do data recovery using software that is free. Data recovery is not always going to work, if the hard drive has written over that sector with data from another program, it might be unattainable using home based software.
  2. Step 2 You can try however to do data recovery using this simple program "Undelete-All", I have posted it in resources.
  3. Step 3 If your hard drive crashed and the sectors were corrupted, again a professional hard drive recovery place would be the best, but if you don't have thousands to spend, you can try a few things that are free.
  4. Step 4 First you will want to restart and make sure the hard drive is being detected by BIOS, when it restarts press f2, or esc, or del to enter BIOS, every computer is different on how to get in, usually it will say at the bottom of the screen.
  5. Step 5 Once in BIOS you will see a summary screen, if your hard drive is detected, great! Proceed on to the next steps, if, however, your hard is not showing, I am afraid to say but more then likely it has died, and it would definitely take a professional place to recover, what they do is take the hard drive platter out, and mount it onto a professional machine to recover the data, again this can costs thousands (I've checked into it before).
    There could though be other reasons a hard drive is not showing, such as, loose cables, BIOS not updated, etc. But if it was working, and nothing has changed, and you haven't rattled the computer around like laptop computers, this you would want to check for loose wires, otherwise it is probably dead.
  6. Step 6 What you can do to try to get data recovery if it is still detected, and this works for desktop computers or laptop computers, would be to set up the old corrupted drive as a slave disk to the new disk.
  7. Step 7 What you would need to do is buy a new disk, install the new OS, be it Windows Vista, XP, etc, and then attach the old drive to the 2nd cable in the computer.
    There will be jumpers if your drives are IDE, every drive is different, and you will have to look that up, it might be on the drive itself. You will want the new drive as master, the old drive as slave.
    If your drives are SATA, no matter, it will do this automatically.
  8. Step 8 If you have a laptop computer, this will be a different procedure, you would need either an external enclosure for your old drive to attach it to your laptop via USB, or a desktop computer that you can hook it to.
  9. Step 9 Since laptop computers can have either IDE or SATA, this might pose a difficulty if your desktop only takes SATA and your laptop is IDE, you would need an enclosure for this to hook it up via USB. If your laptop computer is SATA, you can hook this up to any desktop that has SATA, same with IDE.
  10. Step 10 Once the drive is hooked up, and shows in Windows, you can begin the process of getting your files back. The main files on your desktop will be located in a USER file in Windows Vista c:\(user name)\desktop, in XP c:\documents and settings\(user)\desktop.
  11. Step 11 I hope this article sheds some light on data recovery, hard drive recovery, and deleted files in laptop computers, and desktop computers. I hope if this has happened to you, that you will be able to get your data back! I always, always suggest that you backup your data using an external hard drive connected via USB, better to be safe then sorry! :-)
PLEASE RATE ME..
THANK YOU
Sep 21, 2009 | Compaq Presario C700T Notebook
My computer worked properly. but at once my IDE devices started giving troubles. my 2 IDE devices are not detected at the start up.
The BIOS will have trouble detecting faulty IDE devices, eg the hard disk etc.
To check if the IDE devices are faulty, connect the hard disk to an USB hard disk adapter and plug it into a working computer's USB port, if the computer detects it as an external hard drive and you can open the folders and files then the hard drive is OK and the fault is the disk controller. If the hard disk is not detected then it is faulty and a new hard disk is needed, Windows installed on the new hard drive together with the device drivers and your programs to get an fully functioning computer again.
Sep 01, 2009 | Intel D865GBF Motherboard
Hitachi external hard drive recovery
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Aug 27, 2008 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
WD5000AAKS not recognized
take it apart and get a bridge cable called IDE to USB or ATA to USB.
Connect the cable to your PC and take out the files.
Jun 17, 2008 | Western Digital Caviar SE16 (WD5000AAKS)...
Linux OS
You don't have to get a $50 enclosure. They sell the cables with a IDE /SATA on one end, and a USB on the other for about $10 on ebay.
As far as recovering it..
Did you try the usual chkdsk /r, etc?
Jan 11, 2008 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
