Instruction disc is not working - Computers & Internet
  • sharfique k. May 11, 2010
    pliz provide more details.
  • Coss May 11, 2010
    Please provide some product information about what you are installing on what.
    and include any error messages that pop up.
    Problem Solver:
  • 17 Answers
Your media device lance is dirty or lance is damage. u change ur media device and enjoy
Posted on Jul 30, 2008
My centrios edw8020 dvr records o.k. but won't play dvd on any other dvd systems
If the disc is not "finalized" it will not play on other DVD players. The steps to finalize the disc are part of the DISC Utilities Menu. under "DISC OPERATIONS". Choose "FInalize DISC". Instructions refer to finalizing DVD=R disc, so you may want to try this type of disc first and see if it works. Says It can be used as DVD-Video disc but results are not guaranteed. You can not edit disc after finalizing, only playback.
Jan 28, 2014 | Centrios EDW8020 DVD Recorder
The dvd payer is not working.
see this instruction and follow for fix it. God bless you
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Jul 17, 2013 | Televison & Video
When i turn on my gamecube it says an error has occurred and to shut it off and check the instruction booklet for further instructions
  • An Error has occurred:
    If you are getting the specific message, "An error has occurred. Turn the Power Off and check the Nintendo GameCube Instruction Booklet for further instructions." This means there may be an internal problem with the system.
    1. Check Individual Game Disc problems or Multiple Game Disc problems (depending upon how many games exhibit the problem) to see if the cause of the message is a dirty or damaged disc.
    2. If the disc appears fine or works properly in another system, this means there is an internal problem with the system. A repair will need to be set up. Please use our convenient repair options.
  • Nov 01, 2010 | Nintendo GameCube Console
    How do I get an update disc for my Olevia BDP-110 Blu-Ray Disc Player?
    You can download the ISO from this page. Instructions are also available; follow them carefully.
    ISO is a disk image and must be burned my mounting otherwise update will not work. You can get instructions here about burning an ISO.
    Dec 24, 2009 | Televison & Video
    Blueray disc update needed
    When I tried to play a Blu-Ray Wall-E disc on my Sony DBP-S50, I got a message that I needed to update the java inside the player before it would play the menus and the movie. I think there might have been a website suggested on the screen before the disc stopped working, or it may have been on or in the dvd's box.
    You will need to find the firmware upgrade online, follow its instructions to burn it onto a disc, and then run that disc in your bluray player to fix your problem.
    I cannot tell you where to get the disc to upgrade your player, because you have not mentioned the brand and model of player you have, and this message is posted in the PlayStationPortable section of this website.
    Hope that helps.
    Oct 03, 2009 | Sony PlayStation Portable (PSP) Console
    Emerson EWR 20V5
    Jan 17, 2009
    I posted this Jan 3, 2009 and seem to have a solution.
    Similar problem. E4 54037380 Can not record on this disc. Even though it is from the same package of DVD-Rs that I have successfully recorded to previously. Contacted them about 9 months ago without a successful resolution so I am trying again. Unit will play any DVDs, will record and play back DVD-RWs but will not record on my imation DVD-Rs 8X discs that worked fine in the past. Starts to record for a few seconds and then the error message appears (sometimes with slightly different final 4 digits of error number). Other postings have suggested: maybe a firmware update is available (I requested and we will see Emerson's response), trying slower speed discs (I am skeptical since these 8x imation discs in this same package previously worked, and the instructions say 1-16x for DVD-Rs), unplugging the unit for 1/2 hour to reset the unit (did not work), playing the last disc recorded to the end and then trying a new disc (now it recorded for about 30 seconds rather than 10 seconds but then got E4 54043E02 error message, different but still did not work). So I am hoping for something more productive out of Emerson this time.
    Update Jan 17,2009. Bought a CD and DVD cleaner disc with the little brushes on it. Cleaned the EWR20V5 per the cleaner instructions and tried to recod on the imation DVD-R 8X that I had used successfully in the past, no luck, same error message. So I bought another brand, maxell DVD-R 4.7GB up to 16X and IT WORKED. The instructions on pg 25 say for DVD-R "up to 16X" may be used but "4X-8X disc is recommended". Go figure, no idea why the 16X worked but they did in this case. So just a suggestion to try other brands. Someone else had suggested that also so I gave it a shot. $8 of new discs and $13 for the cleaner and I've back in business.
    Jan 16, 2009 | Emerson EWR20V4 DVD Recorder/VCR
    Disc drive ejects blank discs...plays dvds
    Hi Again,
    Sorry I didn't get back to you sooner. Work!
    You need to let me know what type of PowerBook G4 it is as the instructions for each are different. However, what I will do is give you the links to the appropriate sites and some instructions for them:
    1. First you need to reset the Power Management Unit (PMU). To do this refer to THIS page. A little way down is a heading 'PowerBook and iBook models covered in this document'. Select the model listed in blue below this which will take you lower down the page to the instructions for your model.
    2. After restarting try your drive again. If it doesn't work, try a dvd drive cleaning disc.
    3. If it still doesn't work your drive is Kaput! If you're near Kent in the UK then I can help you out. If not find a local Apple Specialist who can replace the drive for you.
    All the best
    Sean
    Dec 22, 2008 | Apple PowerBook G4 Mac Notebook
    Braun Tassimo 3107 or 3701
    Yessir, you need a t-disc to use it, because the machine reads the bar code that is imprinted on the aluminum lid of the t-disc to get instructions of how hot the water should be, and how much water should be used for the beverage you're qnting to prepare. no t-disc, no drink, no working machine. it's that simple.
    Oct 23, 2008 | Braun Tassimo Espresso Machine/Coffee...
    The spin motor doesn't turn spin the disc
    yes you can replace your lens also your lens is not working so you have to change
    May 18, 2017 | Philips DVP5960/37
    Lost instructions for Presto Powerpop
    Fom what I saw online,you need a disc that you can buy seperate-online from wallmart--presto replacement powercup concentrator # 09964. Put the cardboard disc on bottom.either with a little oil or not, add !/3 cup popcorn and put top on. Microwave for 2-21/2inutes. You can reuse the disc a few times till it turns brown. I got on of these poppers at a yard sale. Its missing the bottom, but works o.k. Enjoy
    Aug 03, 2008 | Presto Kitchen Appliances - Others
    Computers & Internet Logo
    20 people viewed this question
    David Payne
    David Payne
