Hi ,, toner life end error on a brother copier dcp 7020
Hi , i have 3 copiers brother dcp 70 20 and all the 3 have the same problem , in one of them i repalce the circuit board in wich is located the paralel port and usb port and is working , but i nee to fix the other two , i need to know where can i buy this circuit board , can any one help me _
    New Friend:
  • 159 Answers
Any brother partner in your area
Posted on Jul 30, 2008
Brother DCP-9020CDW - How can I reset the toner life?
Hi there
You can reset the brother dcp 9020cdw toner cartridges using the printer menu. Its simple. see video on the link
http://www.zinetic.co.uk/Blog/resetting_the_brother_dcp_9020_cdw_toner_cartridges-blog.aspx
Nov 18, 2013 | Brother DCP-7020 All-In-One Laser Printer
Toner Life End message on DCP-7040
If your cartridge has a lever on the left side near the rear, it needs to be reset, and there's a lever inside on the left that can stick and cause that error. You need to wiggle and pull that lever until it moves freely again.
Jan 04, 2010 | Brother DCP-7040 Laser Printer
Brother DCP 7020 Keeps giving me the "Drum Error" Message
Dear sir you see properly drum unite has a drum image sensor its demage so you change your copier drum unite, thanks.
Nov 17, 2009 | Brother DCP-7020 All-In-One Laser Printer
The Brother DCP 7020 printer displays error
back cover door switch is displace so it called back cover open.
Oct 12, 2009 | Brother DCP-7020 All-In-One Laser Printer
Toner life end warning light. replaced with new toner/drum still error
To reset the sensor after installing a new toner cartridge follow these steps.
1. With unit powered on open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press "+" key 10 times until the display reads 10.
5. Press "SET" key.
6. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
7. Close cover and see if Toner Life End error message has gone.
Jul 28, 2009 | Brother DCP-7020 Black and White Copier
BROTHER MFC 7820N MACHINE PUT IN NEW DRUM, CHANGE DRUM MESSAGE COMES ON. PUT IN NEW TONER, TONER END OF LIFE MESSAGE COMES ON.
To manually reset the counters, do the following:
  • Open front cover, press "option".
  • Answer Yes (by pressing 1) to the question in the display.
  • Your drum counter is now reseted. Press "option" again.
  • This time, press *, 0, 0.
  • Your toner counter is now reseted too.
(If nothing happens when pressing option, try using the back/clear button instead.)
Jun 15, 2009 | Brother DCP-7020 All-In-One Laser Printer
Dcp 7020 and 7040 toner life end message premature, need override
When the Toner Life End LED flips on, requires you to replace the cartridge, even when there's still toner left in the cartridge. The machine detects end of life by shining a light through from one side to the other.
To circumvent the detection mechanism, remove the cartridge and put a piece of masking tape over or jam a little bit of paper into the clear opening/circle on the right side of the toner cartridge, and then pop the cartridge back in. Eventually, you'll start seeing streaks, and then you'll know that the cartridge is truly empty.
Jan 17, 2009 | Brother DCP-7020 All-In-One Laser Printer
Brother dcp 7020 says toner end life
unplug plug it back in, did you remove the protective cover and clean coria wire?
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000065/faq000065_018.html?reg=us&c=us&lang=en&prod=dcp7020_us
Dec 20, 2007 | Brother DCP-7020 All-In-One Laser Printer
DCP 7020
If you are using non brother toner then that's the problem, if not it is the drum unit.
Dec 19, 2007 | Brother DCP-7020 All-In-One Laser Printer
293 people viewed this question
jasbo
jasbo
