Question about D-Link DES-1024D Express EtherNetwork 24-Port 10/100 Switch (S2299467)
PROBLEM WITH MY HUB DES-10160(D-LINK)
THE HUB GOES ON AND OFF SUCH THAT i GET A MESSAGE THAT LOCAL AREA CONNECTION IS UNPLUGGED OR PLUGGED
  • 2 more comments
  • angelpaul Jul 31, 2008
    the network hub is 1 year old, it is connected directly to the mains. Yes there could be possiblilty either of being plugged into a bad power source as there was a sign of flutuation that day or a power surge
  • nuniksais Oct 13, 2008
    The hub disconnects but the power is still on. It's just the network that gets disconnected. I dont know if the hub is broken or anything.
  • Anonymous Nov 02, 2008
    HELLO
    WHEN I CONNECT D-LINK DES-1016D, ITS VERY SLOW SOME TIMES IN HANG. I AM USING THIS SWITCH FOR LAST 3 YEARS. NOW ONLY STARTED GIVING THIS PROBLEM. PLEASE LET ME KNOW WHAT WILL BE THE REASON. THANKS
    AZGIN
  • nuniksais May 11, 2010
    My hub is just 1mth and a few days old.
    Actually i have 2 hubs of the same model, though the one that turns off is the uplinked hub. Are there any issues about uplinks? What kind of cables do i need in order for it to work properly?
    By the way, the 2 hubs are plugged in adjacent outlets.
How much does D-Link DES - 10160 - 16 Pts cost in Qatar Riyads
Posted on Dec 23, 2009
    Genius:
  • 1,056 Answers
Yes the LAN will report plugged and unplugged when the hub goes on and off.
Is this a new or used hub?
If it is used, how old is it?
Is it plugged into a good power source?
If it's plugged into a surge protector, do any other the other items plugged into the surge protector do the same power on and off?
Has it sustained any damage recently (lightening storms, power surges in the house etc).
Posted on Jul 30, 2008
My d-link 1016d problem has a power but no connection in all hub ports? and no lights in indicator that has to be transmitting the data..
It may be fried. But try to do a reset. Look for a recessed button in a hole, usually close to the power input plug. Use tooth pick or pen tip etc; to push and hold reset button for upto 30 seconds with power unplugged. This restore it to factory settings and you may have to re-enter any settings required, IF it works after the reset. If it don't work, not worth fixing.. Buy replacement.
Mar 11, 2012 | D-Link DES 1016D (DES-1016D) 16x10/100...
How can l make settings l have D-LINK DES-10160
This is a non managed switch. There are no settings you can do in it. Sorry.
Oct 10, 2010 | D-Link DES-1024D Express EtherNetwork...
I have a wireless router, my vista laptop is upstairs in my room, my wireless network connection is working. but the "local area connection" says that there is a network cable unplugged. but i have...
"local area connection" is the wired connection, which in your case is "unplugged" If you go to control panel and look in connections, you will see that you are connected with the wireless, if you right click on the wireless there is a checkbox to display the status on your toolbar along side of the "Local Area Connection" Hope that clears it up a little
Aug 29, 2010 | Computers & Internet
I interconnect a D-Link DES-10160 with D-Link Gigabit Switch DGS-1024D network and my network becomes slow
connect only DGS -1024D to your network....it will be faster...
because DGS supports 10/100/1000 speed.... but DES supports only 10/100 speed...
connect DGS directly to your network and work with that... if you wish to extend the number of ports then connect the DES to one of the ports of DGS
and dont connect DGS to one of the ports of DES
May 10, 2010 | D-Link DES-1024D Express EtherNetwork...
Internet explorer cannot display the webpage
That error means the network cable that runs from the modem or network hub is unplugged from your network or lan card on the back of your machine. If you need further help please repost with the type of internet connection you have (dial up, network, or cable, satelite etc..)
Feb 14, 2010 | eMachines ET1161-05 PC Desktop
Its always show at the the monitor the " A network cable is unplugged".
If you are connecting to the Internet using a wireless connection and your LAN card in the computer does not have a LAN cable connecting it to a hub or router then you will get a message "A network cable is unplugged".
If you don't use a wireless connection and you only connect to the your network/Internet then the problem is either the LAN cable has come loose in the computer's LAN card or at the router or the LAN cable is faulty.
Nov 17, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
I need to ask about my problem. I just bought a D-Link DES-1008D and a D-Link DIR-300 Wireless-G Router my problem is after I attach 7 computers on my switch hub. I only have limited local network...
Make sure you're using a crossover ethernet cable to connect the router to the switch. Also make sure that the router has it's DHCP server up and running.
Nov 03, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
Network Connections missing icon. Plus others problems.
XP tags "Local Area Connection #" with your Network Adapter. If you have a built-in LAN, it will take Local Area Conn 1" and when you disabled it and plugged in a new network adapter, it will be named Local Area Conn 2 and so on in that pattern. Your Local Area Connection will only be back when you plug the original Network adapter that XP tagged as Local Area Connection. It is not "variable" where you can choose how to name it.
Jul 31, 2009 | Computers & Internet
Message tells me to plug cable into local area connection. Nothing is unplugged but cannot get internet.
try resetting (turning off and turning on after 3 min) your modem or router or hub (whichever you're using). Then right click the little icon in the task bar that represents your network connection and select 'Repair'
May 10, 2009 | HP W2007 Desktop Monitor
Local area connection
If it says that your local area connection is unplugged then you cant have a cable plugged into the ethernet socket on your pc into a router or there is a break in the cable.
Feb 10, 2008 | NetGear WGT624 Wireless Router
D-Link DES-1024D Express EtherNetwork 24-Port 10/100 Switch (S2299467) Logo
1,617 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
