Question about True T-49 Side by Side Refrigerator Commercial
T-49 Relay Aloha. I am looking for a relay for a True refridgerator that the inscription under the relay cover reads: MODEL T-49 TM-52, TS-49 T-35, TS-35 W/ Danfoss Control / Relay White I just got assigned to teach a food service class at the high school and the refridgerator for the class is broken, so I took the plate off of the wiring cover behind the front vent and noticed the relay was burnt out. I identified the part that was burnt out by the diagram on the back of the plate. It has four wires going to it (2 black, pink and white). Where do I find one of these? My email is gofiojoe@yahoo.com Mahalo, Joseph Nielsen Hana High School Food Service Teacher
  • 943 Answers
Hi thanks for the question you gan get the relay at kemet electronics thanks the appliance doc
Posted on Sep 16, 2008
What is the standard setting defrost timer control of ts-49f
our freezer is set to defrost every 8 hours for 15 min. this seem to do the trick. we have a true t-49f reach in freezer. try this setting and see if it works for your situation.
Mar 30, 2015 | True TS-49F Stainless Steel Freezer 2...
T-49 warm in the morniing, but then works fine all day
Sounds like you are letting the refrigerator sit in an unheated space at night. Those refrigerators have minimum temperature ratings as well as maximum temps. True Mfg. Can be more specific but I say not under 60deg F. Good luck hope this helps.
Apr 09, 2014 | True T-49 Side by Side Refrigerator...
True t-49 Freezer not getting below 10 degrees
is his garage as hot as yours?
Be sure the condenser coil is real clean. Best place to start. Freon levels, door seals are another place to look.
Let me know if I can help any further.
Jun 26, 2010 | True 52 cu. ft. / 1472 liter Commercial...
No power to the fuel pump (used electrical circuit tester down at the pump) fuse blocks under hood seem ok 40 engine quit suddenly. spark ok.
Check the fuel pump relay which is under the hood behind the battery. You'll see 2 turn clips to remove the cover. It should be the 2nd relay as your looking at the car.
Mar 31, 2010 | 1988 Jeep Cherokee
I have a True Freezer Model T-49. It works fine but every 3 or 4
This sounds like a stuck relay to me. I have seen this problem before. The defrost clock kills power to the compressor relay coil during defrost. If the contacts in the relay are welded together the compressor runs while unit is trying to defrost. On newer units this relay is mounted in base of unit on the side or back of the electrical box near center bottom of unit. The compressor relay is a small rectangular box with 4 wires attached. It can be replaced with a single pole 20 amp contactor with a 120 volt coil/ or 240 volt. Check the units name plate voltage rating and ratings on old relay! ;)
Mar 14, 2009 | True 49 cu. ft. / 1388 liter Commercial...
Breeze ceiling fan not working
We were able to get 3 fans running again by replacing the capacitor which had melted in all 3 fans. On one of the fan's the casing around the motor was extremely hot, which prompted us to act quickly. I suppose the fan had been trying to start itself. We purchased the capacitors at an electrical supplier at a cost of $15 each. We were not able to locate the type of capacitors which came with the fan. I am now looking for replacement capacitors at a lower cost if possible. Does anyoe have suggestions of a reputable online dealer for capacitors at a reasonable cost? I would like to keep some on hand.
Apr 29, 2008 | Aloha Housewares (93645) Ceiling Fan
True T-49 Side by Side Refrigerator Commercial Logo
322 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
