Question about Hoover Dryers
Dryer wont start by it self. needs a spin or two with the hand first.
Probably needs motor start capacitor replacing.
Posted on Jul 30, 2008
Electrolux 7kg sensor dryer stopped starting to spin unless you started it by hand now nothing works at all.
what do you mean start it by hand,do you mean if you spin the drum by hand helping it to spin it starts if so you have a bad motor.also next time send the full model number off of the dryer.
Nov 30, 2017 | Electrolux Dryers
Dryer motor hums but doesn't spin
Sounds like the motor has gone bad.
May 10, 2015 | Amana Dryers
My Maytag Performa Dryer model PYG3360AWW wont turn on it just buzzes when I push the start button. what do I do to fix it?
See if you can turn the drum by hand, there should be some resistance. If its locked you will need to disassembly the dryer and see what is binding. If everything(motor,rollers,pullys)spins freely they you most likely have a faulty motor winding and will need to replace it.
Dec 21, 2014 | Maytag Dryers
Frigidaire dryer gallery series wont spin
Hello Hannah Kottman - Sounds like the tub is unbalanced from either a bearing/pulley suspension problem or the unit has broken something off in between the tub and outer portion of the unit. This is not a typical DIY job since the entire back panel of the unit needs to be pulled off and diagnosed. Contact a professional to move forward accurately.
Jan 14, 2013 | Frigidaire Electric Dryer
My kenmore 87872800 dryer wont spin. everything else is working but drum wont spin.
Left the top of the dryer top, check to see if the belt isn't broke or loose, if that is in tact try turning the drum by hand to see if it turns easily. if not, the bearing in the back of the drum needs replaced. this is easy to replace, remove the drum by removing the dryer top and then remove the belt, and the drum slides up out of the machine. replace the bearing then reassemble dryer.
Jun 16, 2011 | Dryers
Dryer wont start, makes humming noise and thats all
sounds like you have abad motor,try spinning the drum by hand,if it moves most likely it's the motor,or the belt broke and is jammed in the motor stopping it from spinning,or if it's hard to turn something could be stuck in the blower wheel but it's the motor making the noise.you need to get in there and check it out.the motors are easy to change out on a kenmore dryer,also next time send the model number.let me know what you find
Aug 20, 2010 | Amana Dryers
During the spin cycle, the machine, had been making alot of noise, and now wont spin at all
I would assume from what you say that the drum bearing has locked up
Open the door and try to turn the drum by hand if it make a sharp cracking nioise or a heavy rumble then the bearings have gone and you need a new unit
Jan 17, 2010 | Washing Machines
Whirlpool electric dryer leq7030kq1 wont turn without help
Sounds like you have a dead zone in your motor...could be a replacement motor is called for. or continue to spin the drum by hand till the motor goes kaput...its cheaper
Sep 26, 2009 | Whirlpool LEQ9858P Electric Dryer
When you press the start button the dryer hums and doesnt turn
first thing you need to do is open the door and try to rotate drum by hand it it is not turn by hand that mean there is some thing stack in your blower fan. if you can turn the drum by hand you need two people to check this problem..one open the door there is one push button, push that button and hold now second person need to push the start button when you heard hums sound the turn the drum by hand again if your dryer stat spin that mean you have bad motor. (forgive me for my english)
Apr 18, 2009 | Dryers
Dryer drum wont start spinning after pushing the start button
the problem is with the start winding on your dryer motor.it is centrifical switch,so if a lint build up gets in that motor switch area it stays on the run winding.pop the top .remove the frount.pull drum.vacume motor out if then starts on own great.other wise you need new motor.parts about 100$God bless,tom
Jan 02, 2009 | Whirlpool ET8CHEXSQ Dryer
Dryers Logo
105 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
