Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Micro2GB Cruzer usb not working at all!
after I inserted few files, and then 'safely removing' it, my scandisk is not working at all! i tried it into different laptops and it is simply not working! can you please help me about it?
Thanks.
  • akib123 Jul 30, 2008
    there's no flash of light or anything on the scan disk at all. the pc/laptop can not detect the usb at all either.
    Scholar:
  • 180 Answers
If there is just a flash of light on the san disk and then no detection in my computer it means the power supply ic has been blown off. if you cant solve this problem there .. let me know.
Posted on Jul 30, 2008
  • Arora Singh
    Arora Singh Jul 30, 2008
    so i am dead sure your ic needs a replacment
    its a six pin and its not expensive ,, may be a total charge of just 5 usd can repair it in india.
Remove the usb safely???
click start right click on your usb scandisk select remove scan disk safely
or in the bottom task bar there should be a green tick or a small white triangle click on them you will see to remove hardware safely tab
this will vary depending on your operating system
hope this helps
Oct 10, 2012 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I have nothing on my scandisk, but it is showing it is full. What can I do about this?
I would try reformatting it. Go to My Computer and rigt click on the thumb drive ( e: for example) and select format
Mar 01, 2011 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Hardware installation not success , while inserting the Sandissk Cruzer Blade pendrive.
How's it going? The Sandisc Cruzer is a nice pendrive. Try this. On your computer, Turn off all "auto run" & save any files from the cruzer you want. click start>computer, Insert the cruzer in a usb drive. Watch the screen & see what drive it installs in. Let it complete this process. Right click on the cruzer, Go down & click on "properties." Click on tools>error checking. scan for errors. When done, click, okay. Right click on cruzer again & click, format. This will delete any files you have in there that's why we saved files earlier, right? Formatting will Right any Wrong so to speak & get your cruzer for use. When you download, download to your computer, Save it. You could scan it for viruses etc at this point. Then you got three choices, You can send it to cruzer,(right click on the file & go down to send, & sent it to the drive cruzer is in.) or, you could, "copy & Paste," it on over to cruzer. And last but not least, you could, "drag" it on over to cruzer. Once you got it over there & you are ready to leave. Right click on cruzer, go down to, "eject," or, "remove." & wait until cruzer tells you it's okay to safe to remove. This is most important because if you just yank it out, you could be ruining some files on the cruz-miester. So try this & Good Luck! BRUTUS X
Aug 03, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My sandisk icon does not come up when I insert the disk. I have a program on the disk in U# that I cannot get to. what do I do? I shut my computer down without removing the flash drive.
Try inserting the Scandisk in another computer to see if you can retrieve your files. If you can then backup your data.
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
Nov 28, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Scandisk Cruzer has loaded but can't be seen in My Computer
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Apr 04, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Viewsat Ultra USB port
Ultra could be clone.
Dec 17, 2007 | Belkin (F5U304)
Cruzer Scandisk 2.0 titanium
Hi, Not unless you are using Windows98, your PC should automatically recognize the SanDisk Cruzer Titanium as a "Removable Storage/Device". Driver is not required for Windows ME, W2k or XP. If for some reason the SanDisk Cruzer Titanium (non-U3 devices) is not recognizable, then perhaps it is not a problem with the PC but with the SanDisk. Pls try all other USB ports of your PC (front and back). The SanDisk website provides utilities/software for this kind of eventuality. They are Sansa Firmware Updater and Sansa Connect Recovery Tool. Both are available at http://www.sandisk.com/Retail/DriverDownloads.aspx. Pls be forwarned that some utilities can and will reset your SanDisk to default and any or all data can and may be deleted. Hope this be of some help/idea. Pls post back how things are or should you need additional information. Good luck and kind regards.
Sep 30, 2007 | SanDisk 1GB Cruzer Titanium USB Flash...
Stopped working COMPLETELY!!!!
Had same problem.
I wiggled back and forth the part that goes into the USB port and the drive was recognized and I could copy my files onto my hard drive.
I had this problem with a different make USB flash drive and used the same procedure to get the files back.
I think that some connection inside the flash drive works loose after a while.
I am not going to trust these drives for files storage, but only to transfer files.
Jul 27, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
76 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
