Hi again, I'm sorry to say I did what you said and it did not help. It
takes the paper through, it sounds like it's printing normally but
there is no trace of ink. The ink was replaced only a few days ago.
However the printer has not been used for awhile and I had to download
the software myself (- if that makes a difference). It did print out
the word 'contents' in blue (from the help contents) with a question
mark below it, however the colored ink has not been replaced and should
be pretty much dried up, I tried doing that again but it wouldn't.
Thanks for your time, Oly
Sorry I was out of town today for a doctor's appointment in the big city.
We can figure this out and get you fixed if you are willing to work through this with me.
First, I need to know just a few things.
Lets start with how your printer is connected to your computer. Is this connected using a USB cable? Forgive me, but I'm not sure what your level of knowledge is so I don't me to patronize you. A USB cable is small and round. A paralelle cable is much thinker and round and connects to the pinkish red port on your computer whereas the USB inserts into a thin rectangular plug.
This information is quite important if you downloaded and installed the software yourself.
If your printer has two cartridges, one for black and the other color and you are only getting some blue ink That would be indicitive of your color cartridge being dried up.
When you state the ink was replaced a few days ago, this is the black ink? Yes? Can you open up the cover and the cartridges move to the center for removal do that. If it doesn't is there a function button you press to Change Ink? In either case, do this and remove the black cartridge, and bear with me here, check to ensure you've actually removed the clear tape from the bottom of the black cartridge. This happens all the time so if you wouldn't mind checking this I'd appreciate that and with that information and the type of cable you use to connect to your computer I can get you back in business by end of the day or night, tomorrow.
I've read that inkjets are best for home photos. But I really want a color laser printer ( fax not...
(More)
I've read that inkjets are best for home photos. But I really want a color laser printer ( fax not necessary)for my home that at least does decent photos for my personal use. Any suggestions?
print out dirty with new or old toner when changed the scanner unit it was clear on sumsung ml 1610...
(More)
print out dirty with new or old toner when changed the scanner unit it was clear on sumsung ml 1610 printer
