Question about Canon PIXMA iP1600 Printer
Printer won't accept paper to print when starting to go though it just stops..
  • 446 Answers
Pls check the ff:
- leading edge of your paper, must be straight
- clean the feed rollers, w moistened cloth, maybe dirty thats why it is slipping
- check paper orientation, must be leveled to the tray
- did you changed any configuration under properties?? check also
we can start from this
pls mark my solutions if it does any help
Posted on Jul 30, 2008
Doesn't want to print
Try unplugging from the wall for 5 minutes / plug in and retry, cancels / resets printer memory.
Feb 17, 2010 | Canon BJC 3000 InkJet Printer
The printer says it is out of paper, even though it is loaded
clean your paper rollers in side printer and make sure spring on paper loader isn't sprung
Jul 27, 2009 | Dell Inkjet 720 Printer
Won't accept photo paper
Only load photo paper do not mix it with plain paper, this will happen on all printers.
May 03, 2017 | Brother MFC-260C All-In-One InkJet Printer
Lexmark 642 printer on network will not print to tray three. When anything is sent to tray 3 it goes to tray 2 even though we set it up in our application to trigger $C(27)_?&15H?
I have found that if the print job needs a certain paper size and the tray is reporting a different size loaded into it then the job will pull from the next tray with an acceptable size. Lexmark's paper stops in the trays are easily moved by the wieght of paper loaded in it. If the job requires "Letter" checnk the size tabs on the left side of the tray, they are on the outside of the tray. For "Letter" just the buttom 2 tabs should be sticking out, adjust the green back stop until just the bottom 2 tabs are sticking out and try your print job again.
Jan 22, 2008 | Lexmark T642 Laser Printer
Check paper size message even though paper size is correct
Make sure when you send the print job, that manual duplex options are NOT selected.
Jan 16, 2008 | Epson Aculaser C1100 Printer
My printer display incorrect paper size and stop printing
Try checking that the paper size settings in your printer driver ar set to either 'AUTO' or to the paper size that is being fed thru the printer. Let me know?
Nov 22, 2007 | Canon imageCLASS D320 Digital Copier
Will not stop printing
As above my printer will not stop printing. As long as it as paper it continues to run paper though.
Sep 11, 2007 | Compaq Inkjet Ij300 Printer
Canon PIXMA iP1600 Printer Logo
old marine
old marine
