Question about Harman Kardon HS 200 Theater System
The problem is that the system doesn't play any DVD the result is always NO DISC after i installed the last system upgrade and to be honest after i have tried to make my HS 200 region free with tips from internet to use the code 3141590. The HS200 plays music CD's as always but DVD's no way. Can you help me to fix it?
Phillips BDP5100 not play BD (unknown disc) but DVD read and play no problem How can i do pls Help me ????
The player detects that the discs contains unauthorized copies of movie titles.
The disc is with a new format which is not yet supported by the player. Some newly released Blu-ray titles in the market apply new disc format which did not exist when the player was manufactured. This leads to playability problem with these discs. This is not a defect of the player and can possibly be solved by firmware upgrade.
The Philips technical team is constantly working on the firmware development to enable the player to play such discs. Installing the latest firmware in your player helps to ensure optimal playback performance. Please visit the support website of your player regularly to check out new firmware release.
Before you update, read the Firmware Upgrade Readme File on the Software and Drivers page. It contains information on playability resolution on discs of particular movie titles.
If the latest firmware is installed in the player and only one disc can't be played, there may be some problems with the disc. It may be defective/scratched.
Another possibility is that the lens of the player is dirty. Try cleaning the disc and the lens with a lens cleaning kit which is available at electronics stores
Mar 31, 2013 | Philips BDP5110 Blu-Ray Player
My dvd rom is no longer playing
Always check the connections and power supply first. if this doesn't work and everything is connected, you might try to update the DVD Rom firmware. a program (free) called Imgburn will allow you to check and find any firmware available. If this still doesn't fix it you may need a new drive (they don't last forever).
Apr 14, 2012 | HP Computers & Internet
I have HP 7700 system,with Vista Operating System. It had issue which resulted to me formating it. Now I cant activate it even online. I keep reinstalling the Vista OS every 30 days. Pls how can I freeze...
Vista sucks anyway, and anything that can run Vista should be able to run Windows 7. This is a blessing in disguise. Buy Windows 7 Home Premium Upgrade and install it.You legally qualify for the upgrade version if your computer came with Vista. You can use instructions here to make the upgrade version work on a clean disk:http://windowssecrets.com/top-story/clean-install-windows-7-from-the-upgrade-disc/
Jan 27, 2012 | HP Computers & Internet
Will not play blue ray disc
Hi
All u need to do is to visit the manufacturer website,you will see a link "download driver upgrade". Download this upgrade and store it in a flash (if your player has a usb port) or just burn it on an empty CD.
Insert the CD or flash drive into your player,the system recognizes the upgrade and automatically installs it..and you are good to go
Good luck
Apr 23, 2010 | Sharp AQUOS Blu-ray Disc Player
Disc error "playback feature may not be available on this disc"
I have a DVD and VHS player in 1 and it was working well then all of a sudden the DVD player part just stopped playing. I stick in a disk and then it would read: disk error play back feature may not be available on this disk. And this disk is fine it plays in my daughters room in her 2 in 1 player. so What can I do? The VHS player works well. Help! I dont really want to buy a new one!
Nov 30, 2008 | Sylvania SSD803 DVD Player/VCR
Upgrade to vista ultimate
If you have a full version of Windows Vista Ultimate, you can just insert the DVD when you logged in your laptop and go to Computer(My Computer) and lauch the installer for Windows on DVD icon (Double Click DVD icon). It will give you the main window for installing Windows and along the way, you should find an Upgrade option. Click that one and it will install windows Ultimate on your system. It Will not format the laptop but installer will just add system files and features to the laptop to run Vista Ultimate.
**If you haven't purhcase a Windows Vista Ultimate Disc, check this link to to purchase just an upgrade Disc (only) of Vista Ultimate.
http://www.microsoft.com/windows/windows-vista/get/anytime-upgrade-overview.aspx
An upgrade disc will also not format the laptop instead it will just install additional features and add additional files on the system to run Windows Vista Ultimate
Oct 28, 2008 | Sony VAIO Digital Studio VGN-AR320E...
I have a Bush DVD 2051 DIVX and it will not recognise that a DVD has been inserted and just states 'no disc'. The DVD has hardly been used so cannot see it is wear and tear.Can you please help?
Simple really!
I had same problem but very carefully cleaned DVD surface with soft specs cloth -played straight away!
Obviously very sensitive to surface imperfections.
Interestingly - playing DVDs via a new Panasonic Viera TX32 LXD 85 gives quite a remarkable upgrade in itself -to be honest I can't see the benefit of spending on a very bulky Blu-ray player until they come down in price and size.
For me the quality is quite good enough for total enjoyment!
jonathanwilson3@btinternet.com
Sep 17, 2008 | Televison & Video
Dvd will not play in dvd player but will play in computer
I don't know if I really find the solution but several burned discs I decide to burn a poor disc 8x instead my emtec 16x and voil'a the disc go on my SC-HT70. I suppose it doesn't support new type of discs with higher velocities even burned at a lower velocity (4x). If any one have another solution please let me know.
Also I know we can upgrade firmware of Panasonic but it can only be done by a technician and it's very expensive.
Thks
May 18, 2008 | Panasonic SC-HT70 System
SAMSUNG SV-DVD440 Combo
how old is the player, it sounds like the lazer has gone down if it reads cds and not dvds
Feb 09, 2008 | Samsung SV-DVD440 DVD Player/VCR
Dvd recorder won't play disc
your recorder will normally give you 5 changes at different regions, and on the last region change that is the one that it stays on, although if you you have never changed the region go to> my computer>right click on your dvd drive>properties and on the hardware tab, your hard drive and dvd drive will show, highlight your dvd drive and click properties and click the dvd regions tab and look at the region to see wot its set at, if you still have 5 changes, it should be set at your region one, if there are no changes left you need to search and download a region free dvd programme to allow any region dvd to be played programme
Jun 10, 2007 | LG GCC 4320B CD-RW/DVD-ROM Burner
Harman Kardon HS 200 Theater System Logo
62 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
