Question about Sony Playstation 3 (PS3) Console
Output from the av multi out is not working.
Hi. hdmi out works fine. But av multi out does not. what is wrong?
  • davidleelee Jul 30, 2008
    This fix absolutely works! Thanks a lot!
  • 344 Answers
Hello. There are a few causes for this. I will list acouple solutions for you.
1. Reset the Video Output Settings. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings. Once you turn it back on, it should work fine.
2. If option 1 does not work call Sony because the video out chip has blown or come unsoldered.
I hope this helps. Good luck to you.
Posted on Jul 30, 2008
  • 1 more comment
  • Wes Sydenstricker
    Wes Sydenstricker Jul 30, 2008
    You are very welcome!! Happy gaming!!
  • thefighternb
    thefighternb Feb 24, 2013
    how do you tell if its need to be rest or if its blown up
  • thefighternb
    never mind it worked Tanks man YouTube didn't even have this advice.
This works thanks dude
Posted on Sep 01, 2008
Thanks a lot, it works
Posted on Aug 12, 2008
I had this same problem, your post helped solve my AV Multi Output not working..so great...thanks! :-)
Posted on Aug 06, 2008
    Problem Solver:
Any link or advice on obtaining video out chip? Also have you actually had to replace them in some units?
Posted on Aug 19, 2008
Cant get ps4 to pass signal thru avr to projector.
Possible PS4 HDMI Handshake Output Problem - AVS Forum ' Home ...
www.avsforum.com/.../1508885-possible-ps4-hdmi-handshake-output-p...
Dec 31, 2013 - 20 posts - ‎15 authors
Nothing seems to make the PS4 pass a signal through the AVR. .... can output videothrough the Integra, why can't Sony get the HDMI working? PS4 - 3D Playback Not Working :-(
Aug 12, 2014
Run HDMI Directly to TV or A/V Receiver?
Dec 19, 2013
AV receiver problem with Xbox One
Nov 23, 2013
Solution to HDMI @ 1080p receiver/display HDCP ...
Dec 14, 2008
More results from www.avsforum.com
My Denon AVR-X4000 won't output video signal from attached HDMI ...
forum.blu-ray.com > Audio > Receivers
Dec 21, 2015 | Denon AVR-3311CI 7.2 Channel Networking...
Do you have to have a HD cable to hook up a PS3?
There are two ways you can connect your PS3 to your VIzio. First, you can do it with HDMI cable. Here the HDMI output from PS3 goes to HDMI input of the TV. Second, you can do it with the AV multi out cable.Here the multi output from the PS goes to AV input of the TV. After doing this please select the source accordingly. Good luck.
Dec 30, 2013 | Vizio E320-Ao 32 Class Led Hdtv - 720P,...
I'm trying to plug my ps-3 to my panasonic viera th-50pz80u with an AV multi-out but i have no signal. No sounds, no images. Please help me
In your PS3 configuration you'll likely have to set the PS3 so that it is using the multi-AV rather than HDMI.(In Video Output Settings) Also on the TV input you'll have to select composite in rather than HDMI.
https://support.us.playstation.com/app/answers/detail/a_id/788
http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Hope this helps,
Jeff
Nov 03, 2013 | Panasonic Viera TH-42PZ80U Plasma TV
Hi our PS3 has no sound or picture. It does have the green power light on.
What is probably happening, is your PS3 is set for the wrong type of output. If you are using an HDMI cord, try switching to the AV cables that came with your PS3, and set your TV at the appropriate input to correspond with the AV hookups, and see if the picture works then.
If you are using the AV cables, it may have been set to HDMI accidentally. You need to use an HDMI cord, and hook the PS3 up to an HDMI compatible TV or monitor, and select the HDMI input. Once you get the picture working, go to Settings>Display Settings and set the display you wish to use.
May 16, 2011 | Sony Playstation 3 (PS3) Console
Hello, my playstation 3 digital output is no longer emitting a light. I tried the cable with another playstation 3 (slim version)and the audio works fine. I turned the not working ps3 off and unplugged it...
make sure your audio output settings are correct,
Settings > Sound settings> [Audio Output Settings] > Select the input connector on the audio device. (Channel numbers and audio formats that are supported vary depending on the connector in use.)
  • HDMI
  • Digital Out
  • Audio input connector/ scart/ av multi
Jan 17, 2011 | Video Game Consoles & Games
My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
1.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
2.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
3.
Select [Audio Output Settings].
4.
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
Hints
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
Nov 18, 2009 | Sony Playstation 3 (PS3) Console
No hdmi output
hmm.. it could be ur tv.. or u playstation, its most likely its ur tv because it plays on AV, open the back up and take the memory catrage out then put back in. (this does not break any waranty u have on it because ps3 incourages u to open it up and get a higher gb mem pack)
Jul 23, 2009 | Sony PlayStation® 3 (80GB) Console
AV multi out
when the power is off press and hold the power button until you hear two beeps
May 14, 2008 | Sony Playstation 3 (PS3) Console
Bad AV Multiout on a Japanese PS3
Copied from another forum: "On the PS3 from Standby (red light on) depress the power button till you hear two beeps. That will reset the resolution and you should get a picture." MANY THANKS to the original poster!
Dec 14, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
2,452 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
